RE: Gas tank - two line plumbing plan    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: Gas tank - two line plumbing plan
Page: <<   < prev  1 2 [3]
Login
RE: Gas tank - two line plumbing plan - 1/15/2013 1:21 AM
Ernie Misner
Score: 130
Last Login: 5/22/2013
Status: offline
Any problems with the Dubro type filter that has a gasket in the middle, and gasoline?
Hide Signatures
(in reply to rmh)
       Post #: 51
RE: Gas tank - two line plumbing plan - 1/15/2013 12:04 PM
av8tor1977
Score: 665
Last Login: 5/23/2013
Status: offline
bump...
_____________________________
If it is not SCARY, it is NO WHERE NEAR powerful enough!!
Hide Signatures
(in reply to Ernie Misner)
       Post #: 52
RE: Gas tank - two line plumbing plan - 1/18/2013 3:17 AM
giddyuperic
Score: 110
Status: offline
I use three lines too no problems here. I bought a brand new Gold Wing Extra 300 LM and would like to know on a 30cc DLE do you think a 11 and 3/4 oz is enough gas or I should I swap out the one they put in it? It cam with a 330cc tank and if my math is right that is a tad over 11 and half oz right correct me if I am wrong and shouild I go bigger??? Thanks Eric
F9, hunter hawker,F-22,yak55 30% DLE55,Extra260,300.sabre F86,bae hawk,Cessna 182. GoldWing extra300LM 30CC Velox20cc
Hide Signatures
(in reply to Lightspeed1551)
       Post #: 53
RE: Gas tank - two line plumbing plan - 1/18/2013 4:18 AM
MTK
Score: 203
Status: online
quote:
ORIGINAL: giddyuperic
How long do you wantto fly each flight? A 16 oz will give you at least 22 minutes. A 12 ozs will give you about 15 minutes at 2/3rds-3/4ths throttle. I use a 330 cc in my OS GT33 powered plane and I fly 15 minutes (timer set at 15). I have about 1-2 ozs left in the tank at landing.
Regards,
MattK
Hide Signatures
(in reply to giddyuperic)
       Post #: 54
RE: Gas tank - two line plumbing plan - 1/18/2013 5:16 AM
giddyuperic
Score: 110
Status: offline
That sounds good to me I have a bigger tank in my 50cc gold wing yak55m and never burn all the fuel.. So you have the same tank as I do and it should do just fine. I can always swap it out later if thats not long enough. Thank you for your time.
Hide Signatures
(in reply to MTK)
       Post #: 55
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> RE: Gas tank - two line plumbing plan
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.250RCU1
