50cc missing    Gallery
Logged in as Guest
    Search This Thread
Printable Version
RCexl ignition for most any engine
Seller:  BadAzzMaxx
Details:   $54.95   |  4/26/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> 50cc missing
Page: [1]
Login
50cc missing - 1/11/2013 7:36 PM
flybyme
Score: 100
Last Login: 4/1/2013
Status: offline
What is a common cause of a 50cc gas engine missing...sputtering after a crash. Mixture, iginiton, pickup?
Hide Signatures
       Post #: 1
RE: 50cc missing - 1/11/2013 7:57 PM
mrbigg
Score: 155
Last Login: 4/24/2013
Status: offline
Do the simple first- replace the spark plug.
_____________________________
Smooth, like Keith Stone.
Hide Signatures
(in reply to flybyme)
       Post #: 2
RE: 50cc missing - 1/11/2013 8:15 PM
All Day Dan
Score: 151
Last Login: 5/26/2013
Status: offline
second, replace the ignition.
third, replace the pick up.
Dan.
Dan
Hide Signatures
(in reply to mrbigg)
       Post #: 3
RE: 50cc missing - 1/11/2013 9:54 PM
Checklst
Score: 115
Last Login: 5/25/2013
Status: offline
Does the prop hub have a key way on the crank..................prop hitting the ground in a crash could move hub if a key is what holds it to the crank starts to shear off.....would change the trimming if the key moved.
Hide Signatures
(in reply to All Day Dan)
       Post #: 4
RE: 50cc missing - 1/11/2013 10:26 PM
pe reivers
Score: 646
Status: offline
Too early ignition timing also causes occasional misses.
Pe, (www.mvvs.nl), MVVS, MOKImotor, RCexl, MTW, Xoar, Mejzlik.
Blessing in ignorance? There is sanctuary in analysis.
Hide Signatures
(in reply to Checklst)
       Post #: 5
RE: 50cc missing - 1/12/2013 8:25 AM
flybyme
Score: 100
Status: offline
Thanks for the replies, will address them all.
Hide Signatures
(in reply to pe reivers)
       Post #: 6
RE: 50cc missing - 1/12/2013 1:49 PM
captinjohn
Score: 247
Status: offline
RE 50cc missing yet?  Just keep looking & you will find it.
I never met a engine I did not like !
Hide Signatures
       Post #: 7
RE: 50cc missing - 1/20/2013 3:43 AM
flybyme
Score: 100
Status: offline
Knocking down a good spark, where do I go next, the woodruff key, or carb....?
Hide Signatures
(in reply to captinjohn)
       Post #: 8
RE: 50cc missing - 1/20/2013 1:28 PM  1 votes
ahicks
Score: 669
Status: offline
The spark plug boots will often leak when under compression only. Spark looks fine when not installed? If it was damaged at all in your accident, I'd replace the ignition if you have one you can swap into it. If that works, order out a new boot and just replace that?
Hide Signatures
       Post #: 9
RE: 50cc missing - 1/20/2013 7:08 PM  1 votes
apalsson
Score: 168
Status: offline
I have seen the same symptoms on a club mate's plane where the spark plug cap wasn't properly on the plug.
He had loosened up the spring clup on the boot too much so you could see the cap moving up and down on the plug
MVVS Australia
MVVS Engines, Mejzlik Props, Accessories.
www.mvvs-australia.com.au
Hide Signatures
(in reply to ahicks)
       Post #: 10
RE: 50cc missing - 1/20/2013 7:33 PM
TimBle
Score: 162
Status: offline
quote:
ORIGINAL: captinjohn
LOL, A club mate was also complaining about his RCGF 55 missing in flight. So I said I'd take a look at it.
So I walked over to the plane and paced around it in circles 2 closckwise and once counterclockwise and exclaimed EUREKA!!! and walked back.
After I sat down he looked at me and Said: I thought you were going to look at my engine?
I replied: I did, but not just that, you'll be pleased to know I found it under the cowl....
Hide Signatures
       Post #: 11
RE: 50cc missing - 1/22/2013 7:05 AM
bcchi
Score: 650
Status: offline
quote:
ORIGINAL: TimBle
O-Boy LOL
BCCHI
Hide Signatures
(in reply to TimBle)
       Post #: 12
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> 50cc missing
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.656RCU1
