To Support Strap/Bracket or Not to Support Strap/Bracket a Wrap Around Pitts Muffler    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Questions and Answers >> To Support Strap/Bracket or Not to Support Strap/Bracket a Wrap Around Pitts Muffler
Page: [1]
Login
To Support Strap/Bracket or Not to Support Strap/Bracke... - 1/11/2013 9:52 PM
dasintex
Score: 126
Last Login: 5/25/2013
Status: offline
Here's what I have and know, A DLE55 with a 'JTEC WRAP AROUND PITTS' Muffler on a TF Giant P-40; the Muffler features Long Exhaust Tubes, my thought was, the Vibration and shaking of the Engine will shake the Muffler to a point the Muffler will crack and fall apart, despite how solid the engine feels mounted on the Standoffs, the Engine still Vibrates, Flexes and Shakes, no more than normal and what would be expected, Firewall Flexing, etc,.
A few Guys have stated their Wrap Around Pitts Mufflers have failed this way and they were using Jtec, in assuming that my Muffler does not come loose which some have stated has happened and probably contributed to the Muffler Cracks and Failure, I will be using Wire Lockable Bolts. Is using a Support Strap, mounted to the Muffler End Plate and secured between the Engine Mounting Bolts and Standoff; Overkill, Not Recommended, etc?
JTEC does not recommend Support Straps and states that using one Voids the Warranty, besides voiding the Warranty what will it Hurt?
Thanks.
_____________________________
P-40 Brotherhood #3
Spitfire Brotherhood #29
Hide Signatures
       Post #: 1
RE: To Support Strap/Bracket or Not to Support Strap/Br... - 1/12/2013 1:51 AM
jetmech05
Score: 133
Status: offline
safety wire the screws will end the coming loose problem....if the manufactuer say a bracker voids the warrenty...don't use one
Hide Signatures
(in reply to dasintex)
       Post #: 2
RE: To Support Strap/Bracket or Not to Support Strap/Br... - 1/12/2013 3:25 AM
speedracerntrixie
Score: 189
Status: offline
Get a Slimline pitts muffler instead of the Jtech and use a strap if you have to use a pitts type muffler. I have used Jtech mufflers once in the 15 years I have been running gassers, I hope you pick up on the hint.
Hide Signatures
(in reply to jetmech05)
       Post #: 3
RE: To Support Strap/Bracket or Not to Support Strap/Br... - 1/12/2013 2:06 PM
Lnewqban
Score: 163
Last Login: 5/6/2013
Status: offline
quote:
ORIGINAL: dasintex
Aluminum will crack eventually, specially at the welds.
I would support the end of the manifold and the exhaust pipes with blocks of neoprene against the firewall.
The manufacturer forbids the use of straps, because they will produce vibration related perforations and metal to metal corrosion.
Lnewqban - "The recipe for perpetual ignorance is: be satisfied with your opinions and content with your knowledge." - E. H.
Hide Signatures
       Post #: 4
RE: To Support Strap/Bracket or Not to Support Strap/Br... - 1/12/2013 6:02 PM
speedracerntrixie
Score: 189
Status: offline
I find it curious that Jtech advises against a strap and Slimline comes with one. Everytime I have seen someone use a pitts type muffler without a strap they have had issues with bolts coming loose. Too bad a stock muffler wouldn't work as it is the best for reliability.
Hide Signatures
(in reply to Lnewqban)
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.172RCU1
