To many volts?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> To many volts? Page: [1]
Login
To many volts? - 1/12/2013 11:28 AM
Cougar-RCU
Score: 100
Last Login: 4/6/2013
Status: offline
Hi gang. I am getting a starter that says it can handle 12 to 18 volts.
would a LiFe 19.8 Volt hurt the Starter buy just being 1.8 volts over?
http://www.hobbyking.com/hobbyking/store/__17823__Turnigy_4500mAh_6S2P_30C_LiFePo4_Pack_USA_Warehouse_.html
There is also another type that is 16.6 volts as well that I could get. I thought about running two 7.2 in series but found these other one's
So why bother with two battery's? or does running them like that give you a better option?
Thanks for any help.
_____________________________
** CUB BROTHERHOOD ** #90
Hide Signatures
       Post #: 1
RE: To many volts? - 1/12/2013 12:41 PM
Goldenduff
Score: 114
Last Login: 5/18/2013
Status: offline
I would say it would be fine using the life. Amps not volts is the big killer ad the starter will draw the amps it requires.
Hello, the IMAX b6 quattro fits the bill?
Hide Signatures
(in reply to Cougar-RCU)
       Post #: 2
RE: To many volts? - 1/12/2013 12:44 PM
Cougar-RCU
Score: 100
Status: offline
Thanks very much for the info,
Hide Signatures
(in reply to Goldenduff)
       Post #: 3
RE: To many volts? - 1/12/2013 1:55 PM
Cougar-RCU
Score: 100
Status: offline
Another Question as I am still confused a bit LOL
Like the above 19.8 volt $$$ and these below are a bit cheaper
This starter I am getting is a 6.1 geared ratio. from 12 to 18 volts.
So I am also looking at the LiFe 4200 MAH @ 30C @ 13.2 volts
and also the LiFe 4200 MAH @ 30 C @ 16.5 volts.
So what Will the diff be between all 3 of these for a days use? or power ?
Would I be just fine with the lesser volts?
Or maybe the better thing to do, is ask what one would you use?
Not sure if I am even asking my question right. Sorry.
Hide Signatures
       Post #: 4
RE: To many volts? - 1/12/2013 2:52 PM
JNorton
Score: 149
Last Login: 5/17/2013
Status: offline
The higher voltage you supply to a DC motor the faster it spins and the more current drawn. More current less battery life. All your batteries have the same capacity. Seriously - anything you've listed should work. I'd use the highest "C" rated batteries with the highest capacity that will physically fit and stay within the voltage rating of the motor. I never like to push voltage limits.
John
Have desk ... Will Fly.... Saito Member #467
Ultimate Brotherhood #11, Ultra Sport Brotherhood #90
Hide Signatures
       Post #: 5
RE: To many volts? - 1/12/2013 3:52 PM
Cougar-RCU
Score: 100
Status: offline
Thank You John.
Hide Signatures
(in reply to JNorton)
       Post #: 6
RE: To many volts? - 1/12/2013 4:36 PM
pilotpete2
Score: 120
Status: offline
Also, remember that the nominal voltage for a lipo (3.7V per cell) is when it's almost outa gas. You should really make your choice based on the fully charged voltage. A 4S pack is 16.8 fully charged, so a good choice for this application, a 6S pack would be 25.2V! Spin baby spin!!! Also, since that's a geared starter, you may even be good on 3S.
As John said, the lower the voltage that's able to do the job, the longer your starter will last.
Cheers,
Pete
"If the woman don''''''''t find you handsome, they should at least find you handy"
Hide Signatures
       Post #: 7
RE: To many volts? - 1/12/2013 5:07 PM
Cougar-RCU
Score: 100
Status: offline
Thanks Pete,
So I think I will go with this one then?
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idproduct=24190
Good Choice? Remember the starter is already geared at 6.1
this one is at 16.5 volts ( 30C constant and 40C burst )
Jeff
Hide Signatures
(in reply to pilotpete2)
       Post #: 8
RE: To many volts? - 1/12/2013 8:42 PM
pilotpete2
Score: 120
Status: offline
not really 16.5V, but actually 21V fully charged. Don't be misled by the nominal voltage rating of batteries
Pete
Hide Signatures
       Post #: 9
RE: To many volts? - 2/3/2013 8:46 PM
Cougar-RCU
Score: 100
Status: offline
Got'Er Done.... Thanks Guys.. even used the project box.
Kicks BUTT !
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 10
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.828RCU1
