EDF Kits suitable for turbines    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> EDF Kits suitable for turbines
Page: [1]
Login
EDF Kits suitable for turbines - 1/12/2013 1:55 PM
warbirdfanatic
Score: 100
Last Login: 5/25/2013
Status: offline
Hi Guys
Does anyone have a good list of EDF birds that are 1600mm or wider wingspan? I'm just thinking about converting an EDF kit for pure laziness, Hobbyking do a large F86 which looks like it would be good enough to convert or even make a mould from to put a 15lbs turbine in!
Or, if anyone has any links to free EDF plans or turbine plans that would also be handy!!!!
Hide Signatures
       Post #: 1
RE: EDF Kits suitable for turbines - 1/12/2013 2:27 PM
Henke Torphammar
Score: 100
Last Login: 5/26/2013
Status: offline
Hobbytopgun Mig15
Really good performer but very slow to turn. When doing a 4 point roll as fast as you can it still takes the whole flight line. Knifedges comfortable too, but with alot of coupling. A little too big and flexes too much I think.
A couple of short clips of the Mig15 at 0:55, 2:30 and 5:25
http://www.rcuniverse.com/forum/m_10644917/anchors_10644917/mpage_1/key_/anchor/tm.htm#10644917
Ready2fly Venom (turbine convertion kit are just about ready to ship)
Great flying plane which is a bit faster to turn and better for aerobatics. This is the best flying foamy I have tried.
_____________________________
/Henke
www.youtube.com/henke2
Swist F5D, Lambert Kolibri T25 - 310mph 2012
Hide Signatures
(in reply to warbirdfanatic)
       Post #: 2
RE: EDF Kits suitable for turbines - 1/12/2013 3:00 PM
ModellbauUK
Score: 101
Last Login: 5/23/2013
Status: offline
I agree. The ReadyToFly Venom is a superb plane. They had a stand next to us at Jetpower and fitted P20 in one. Flew brilliantly.
The other EDF converted to Turbine worth considering is the Savex L39 fitted with a Wren44. These fly really well and there's loads of posts on RCU regarding this little beauty.
http://www.savex.cz/prod.php?lang=en&id=10
Ian
www.modellbauuk.com
The Aurora Project
The Kestrel Project
FCT Kevlar & Hopper Tanks
Hide Signatures
(in reply to Henke Torphammar)
       Post #: 3
RE: EDF Kits suitable for turbines - 1/12/2013 3:03 PM
corndog2
Score: 100
Last Login: 1/19/2013
Status: offline
Hobby King Mig 15 with P20 in it
http://www.youtube.com/watch?v=4MIfnaHiEl8
Ideal
Hide Signatures
(in reply to ModellbauUK)
       Post #: 4
RE: EDF Kits suitable for turbines - 1/12/2013 3:08 PM
corndog2
Score: 100
Status: offline
So how do you guys embed a youtube it wont seem to work for me ?
Hide Signatures
(in reply to corndog2)
       Post #: 5
RE: EDF Kits suitable for turbines - 1/12/2013 3:17 PM
Robrow
Score: 100
Status: offline
quote:
ORIGINAL: corndog2
Click the YouTube button then paste the full link in the middle.
UK distributor: Jets Munt Merlin 90, 140 & 160. Jet Central UK. FADEC ECU''''s UK
Hide Signatures
       Post #: 6
RE: EDF Kits suitable for turbines - 1/12/2013 3:27 PM
corndog2
Score: 100
Status: offline
Now I got it. Mind you they wont play embedded on my computer odd that
Hide Signatures
(in reply to Robrow)
       Post #: 7
RE: EDF Kits suitable for turbines - 1/12/2013 4:51 PM
Henke Torphammar
Score: 100
Status: offline
In my opinion most cheap china GF kits turn out too heavy. Sure they do fly, but not in a relaxing way. When buying a turbine in this class costing atleast $1900 you should really choose an airframe with care too. It's not the money but rather getting a plane that flies good without bad habits and that are not under powerd. I think you are way better of with any of the 90mm foamies then the GF kits unless spending enough to buy a Savex or even better a Schübeler.
Compare my video of the Venom with the Mig15 just posted above. Lighter more powerful turbine vs heavier and less power. These pretty much represent the two opposite ends of the scale.
Again, this is how I think and others have diffrent preferences.
/Henke
Hide Signatures
       Post #: 8
RE: EDF Kits suitable for turbines - 1/12/2013 5:14 PM
DominicM
Score: 101
Status: online
"EDF birds that are 1600mm or wider wingspan"
Very limited choice if you want composite kit. These are close. CARF Spark? JTENG range? JTM XXX Sport Jet? Tomahawk Stinger? Habu32?
Then you have TopGun or FlyFly foamies and those already mentioned but you wouldn't want to put a 15lb turbine in one of those!
...and forgot to mention there is a 90mm EPO Yak 130 coming out soon but again turbine and foamie...probably best not.
www.youtube.com/watch?v=gQ7uQp9VcLY
Hide Signatures
       Post #: 9
RE: EDF Kits suitable for turbines - 1/12/2013 5:57 PM
warbirdfanatic
Score: 100
Status: offline
Cheers for the responses guys, looks like they're too small for me then! a 15lbs will be wayyy too much plus once you've added the weight of the engine, fuel etc they'll fly a bit awkwardly! any clue as to other designs? I really want to do an F35 but the plans I've found are foamies and they just don't support the strengths that I require etc! I emailed Oakdale about their plan but I've had no response after 8 days :-(
Hide Signatures
(in reply to DominicM)
       Post #: 10
RE: EDF Kits suitable for turbines - 1/12/2013 7:31 PM
Henke Torphammar
Score: 100
Status: offline
quote:
ORIGINAL: warbirdfanatic
If you have a 15lb thrust engine on hand you need to look for 120-127mm sized EDFs. But then you are looking at a standard turbine size where there are alot of choices. The pros of chooseing an EDF airframe is that it's usually much lighter, the con is that they always add oversized inlets to get enough air for the often weak EDF setups...
/Henke
Hide Signatures
       Post #: 11
RE: EDF Kits suitable for turbines - 1/12/2013 10:22 PM
corndog2
Score: 100
Status: offline
quote:
ORIGINAL: Henke Torphammar
Most of the flight of the HK Mig 15 posted above was at just over half throttle and I can assure you that it flys an absolute dream
Hide Signatures
       Post #: 12
RE: EDF Kits suitable for turbines - 1/12/2013 10:39 PM
Henke Torphammar
Score: 100
Status: offline
quote:
ORIGINAL: corndog2
Half throttle of these turbines are about 1/3 of the maximum thrust. In that case it does well. Still I think those airframes are to heavy.
Compared with a Schübelrer Hawk. Again I think the Hawk has plenty of power while the Mig is a bit slow, but I'm sure both do fly with no problems.
/Henke
Hide Signatures
       Post #: 13
RE: EDF Kits suitable for turbines - 1/12/2013 11:56 PM
bem
Score: 115
Last Login: 5/24/2013
Status: offline
Hi,
This maybe, for 120 mm EDF or 8 kg thrust turbine, Italian C&C Models BAE Hawk. Wingspan 1900 mm / 74.8 inch.
http://www.cmodels.it/modelli_jet/baehawk%20c&c.htm
EDF powered flight video of the plane:
http://www.youtube.com/watch?v=srkDHNXt-BI
http://www.youtube.com/watch?v=g5L83p-YZr8
/Bo
Hide Signatures
       Post #: 14
RE: EDF Kits suitable for turbines - 1/13/2013 1:56 PM
lrb75
Score: 100
Status: offline
The HK fiberglass MIG-15 flies great on EDF. Mine weighed right around 7lbs before I dumb thumbed it into the trees. I got a new one but the paint on the wings is not sticking very well to the covering. Also the internal formers are not the same so it will be alittle more work to get this one in the air.
But I don't think any of the HK EDF kits will be suitable for a 15lb turbine. They would really only be good for something like a P20 or a kolibri turbine. You need to look at something from Yellow, Jet Hangar or Century Jet.
Hide Signatures
(in reply to bem)
       Post #: 15
RE: EDF Kits suitable for turbines - 1/13/2013 4:32 PM
vonRaB
Score: 100
Last Login: 5/11/2013
Status: offline
Hello,
I convert the FlyFly F-86  to JetCat P20SX. .Fly very well
Video about conversion and flight is there: http://www.youtube.com/user/GrapoAirTech
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to lrb75)
       Post #: 16
RE: EDF Kits suitable for turbines - 1/13/2013 11:17 PM
Vettster
Score: 105
Status: offline
Hi Guys
If its a 15lber you intend to use..most of the planes already mentioned are only good for a P20 or Wren44.
Sounds like you want to use a P-60
This is what Im doing after my Byron F-16.
SU 37 from the King. They dont sell them anymore but that might be found at the manufactuors website. Prodesign.
Im placing a P-60 between the engines. Fuel tanks will most likly be installed in the intakes.
Specs:
Wingspan: 1200mm
Length: 1737mm
about 15lbs flying weight.
Click for fullsize
Click for fullsize
Club NO MAX! No boarder..No Limits..No POLITICS! NO "MAX"
Hide Signatures
       Post #: 17
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.688RCU1
