Wheel brakes on 1/3 scale and up    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Wheel brakes on 1/3 scale and up
Page: [1]
Login
Wheel brakes on 1/3 scale and up - 1/12/2013 5:05 PM
Subzeroedge
Score: 100
Last Login: 4/28/2013
Status: offline
 So I'm looking to put pneumatic wheel brakes on an IMAC style plane, has anyone seen a brakes system that would work in this application? I have many friends with jets and the thought crossed my mind that it would be nice to be able to stop my plane on some of those "hot" landings before running off the end of the pavement.  I realize you would not want to ing age them until you were able to stick the tail to the ground, but I think it would be cool to be able to stop the plane from rolling away, or having to do the s turns at the end of the runway to bleed speed to turn around.  Just a thought.
_____________________________
Save an airframe, fly Futaba.
Hide Signatures
       Post #: 1
RE: Wheel brakes on 1/3 scale and up - 1/12/2013 7:46 PM
rafeeki
Score: 101
Last Login: 6/18/2013
Status: offline
I dont reccomend them on a taildragger...
Hide Signatures
(in reply to Subzeroedge)
       Post #: 2
RE: Wheel brakes on 1/3 scale and up - 1/12/2013 9:00 PM
BarracudaHockey
Score: 280
Last Login: 6/17/2013
Status: offline
Exactly, you'll spend more on props
That and IMAC planes don't land all that fast anyways.
Andy - Helicopter Forum Moderator
AMA 77227 Leader Member- Contest Director
www.JaxRC.com
Hide Signatures
(in reply to rafeeki)
       Post #: 3
RE: Wheel brakes on 1/3 scale and up - 1/12/2013 9:03 PM
gene6029
Score: 120
Status: offline
I agree, brakes dont sound like a good idea on a tail dragger. Heres something that works though, try putting both your ailerons on a switch that when activated they both go to 30 degrees or more full UP. On the grass my CARF Yak only rolls a few feet once deployed. It seems the faster you land, the more effective they are. Just be sure you are on the ground when you deploy them. Try it, it may be what you are looking for, it worked for me....Gene
Hide Signatures
       Post #: 4
RE: Wheel brakes on 1/3 scale and up - 1/12/2013 9:44 PM
rafeeki
Score: 101
Status: offline
Not reccomended on taildragger unless they are anti lock brakes
Hide Signatures
       Post #: 5
RE: Wheel brakes on 1/3 scale and up - 1/17/2013 5:55 AM
Subzero edge
Score: 100
Last Login: 1/23/2013
Status: offline
Thanks guys, I'll try the reflex in the ailerons.
Hide Signatures
       Post #: 6
RE: Wheel brakes on 1/3 scale and up - 1/17/2013 2:25 PM
zacharyR
Score: 105
Status: offline
Hide Signatures
(in reply to Subzero edge)
       Post #: 7
RE: Wheel brakes on 1/3 scale and up - 1/18/2013 8:01 AM
Airbike
Score: 100
Status: offline
here you go:
http://www.whiteroseeng.com/products/Maingearwheels.html
disc brake system for the main wheels. Basically just a drag system that's adjustable by how tight the magnets are to the disk. Pricey$$$ but I've seen them on a plane locally and it seems to work well for the pilot.
I would just suggest landing slower. Just think how slow you get the plane to go before the stall/spin maneuver. Pitch the nose up to slow down and use throttle to control altitude/descent rate.
The more you put into living, the more you get out of life.
Revver #150
Hide Signatures
(in reply to zacharyR)
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.422RCU1
