Dremel vs 26cc CY    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Giant Scale Cars >> Dremel vs 26cc CY
Page: [1]
Login
Dremel vs 26cc CY - 1/14/2013 3:40 AM
phmaximus
Score: 627
Last Login: 5/24/2013
Status: offline
Hey guys, I'm really keen to learn about modifying these little engines, so I thought why not learn from doing it?
I've got my motor all striped down, iPad set to google and dremel in hand, wish me luck
_____________________________
Losi Micro SCT,5IVE,8IGHTe
Tamiya BajaKing,TA01R,TL01B
Hide Signatures
       Post #: 1
RE: Dremel vs 26cc CY - 1/14/2013 4:13 PM
i8tweety
Score: 133
Status: offline
Just remember that removing too little material is always better than removing too much.
1 Bad Puddy Tat
Hide Signatures
(in reply to phmaximus)
       Post #: 2
RE: Dremel vs 26cc CY - 1/15/2013 10:34 AM
phmaximus
Score: 627
Status: offline
Well I've been having fun, so far I've polished both halfs of the crankcase, turbo modded the crank, blended the case into the ports for turbo mod, Champhered bottom of the piston to force more air into the transfer passages, removed excess metal from the piston, And blended transfer passages to crank case...
About 1/2 way through doing that my brand new Dremel stopped working, so I had to pop down and get it replaced under warranty.
I'm hoping it was a freak thing. Because they only replace it if it's under 30 days old other wise it has to be sent of to be repaired.
I'll get some pics up after
Hide Signatures
(in reply to i8tweety)
       Post #: 3
RE: Dremel vs 26cc CY - 1/15/2013 12:49 PM
phmaximus
Score: 627
Status: offline
pics as promised, problary should of cleaned everything before the pic, its cvered in dust from a polishing pad oh well, ive been using tape over the bearing to keep them nice and clean
Hide Signatures
       Post #: 4
RE: Dremel vs 26cc CY - 1/16/2013 6:10 PM
savagecommander
Score: 171
Last Login: 5/12/2013
Status: offline
a good pipe will show better gains than a trick port job any day. Focus on that first. I went through about fifteen heads before i stopped the impulse to grind and mod them.
Hide Signatures
       Post #: 5
RE: Dremel vs 26cc CY - 1/17/2013 1:20 AM
mooman007uk
Score: 105
Status: offline
i'd leave the crankcases, ports, transfers unpolished for better fuel atomization...polishing off the rough surface decreases performance...
Bringing hurrax to N.America & beyond.
hurraxracing.com
Hide Signatures
(in reply to savagecommander)
       Post #: 6
RE: Dremel vs 26cc CY - 1/18/2013 2:21 AM
phmaximus
Score: 627
Status: offline
quote:
ORIGINAL: savagecommander
ive been reading that about pipes, im planing to get one mid this year, just cant squeez it at the moment. at the moment im saving for a new turtle racing cluch bell and open clutch bell carrier.
im very interested in ur experance with those heads? preformance gains vs effort
Hide Signatures
       Post #: 7
RE: Dremel vs 26cc CY - 1/18/2013 2:29 AM
phmaximus
Score: 627
Status: offline
quote:
ORIGINAL: mooman007uk
ive allways wondered that, but for some strang reson I posished the crankcase, seemed like a good idea at the time
im keen for any tips u guys have. some day I wanna look into a 30.5cc for some more lowend power
the main things ive focused with the motor is the turbo crank mod, turbo case mod, blending the case into the head and posishing the exhaust port...
does that sound about right?
Hide Signatures
(in reply to mooman007uk)
       Post #: 8
RE: Dremel vs 26cc CY - 1/18/2013 1:38 PM
savagecommander
Score: 171
Status: offline
any modification that increases the volume of the case or transfer port runners will hurt low end- so when you blend the case its important to remove as little as possible. you are really just trying to knock down any sudden changes or sharp casting flaws. as far as the discussion of performance gains vs effort, You'd be surprised at how little needs to be done to see power gains. IME the full mod motors only have those high eye popping numbers for a few thousand rpm, so all the extra cash to me isnt worth it. I have one and i know i wont ever buy a motor like that again.
Hide Signatures
       Post #: 9
RE: Dremel vs 26cc CY - 1/18/2013 6:27 PM
Ttowntoolman
Score: 159
Last Login: 5/23/2013
Status: offline
quote:
ORIGINAL: phmaximus
If you know someone with a sandblaster or a bead blaster, it works pretty good to put the texture back into the case after you removed what you wanted to. Thats what I used to do with my Quad engines. Best to take bearings out though.......I used to chuck my engines in the wifes oven to get the cases to split, and to remove bearings. She was never real amused with me.....
Hide Signatures
       Post #: 10
RE: Dremel vs 26cc CY - 1/23/2013 3:38 PM
phmaximus
Score: 627
Status: offline
lol cheerz guys for the tips, keep em comming lol
Hide Signatures
(in reply to Ttowntoolman)
       Post #: 11
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.422RCU1
