HL Panther hull fit a TAM Jagdpanther lower hull?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Tanks >> HL Panther hull fit a TAM Jagdpanther lower hull?
Page: [1] 2   next >   >>
Login
HL Panther hull fit a TAM Jagdpanther lower hull? - 1/14/2013 5:08 PM
mazzsgp2
Score: 100
Last Login: 4/8/2013
Status: offline
Hi guys,
Ive been battling with my Tamiya Jagdpanther with the local club for a few years now, I was wondering of opening up a whole new experience of battling with a turreted tank without a heavy $ investment. And was pondering if the HL Panther upper hull can be modified relatively easily to fit a Tam panther/ jagpanther lower hull,
any guys here with a similar experience?
thanks in advance!
Hide Signatures
       Post #: 1
RE: HL Panther hull fit a TAM Jagdpanther lower hull? - 1/14/2013 5:27 PM
wsn123
Score: 104
Last Login: 5/25/2013
Status: offline
Yes it fits very good
I had similair  problem  - an old HL Panther and Tamiya Jagdpanther lower hull
I added metal road wheels from rctank.de (for Tamiya Panther), metal tracks from Matorro, ball bearing axle support, stronger  black M02 long cans  motors to Tamiya gearboxes , Tamiya recoil,  Elmod ECO and Benedini TBS Mini sound . The upper hull and rear side  was taken from Heng Long Panther  The tank is not finished yet.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by wsn123 -- 1/14/2013 7:50 PM >
Hide Signatures
(in reply to mazzsgp2)
       Post #: 2
RE: HL Panther hull fit a TAM Jagdpanther lower hull? - 1/14/2013 5:30 PM
wsn123
Score: 104
Status: offline
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to wsn123)
       Post #: 3
RE: HL Panther hull fit a TAM Jagdpanther lower hull? - 1/15/2013 10:04 AM
sollie
Score: 110
Status: offline
WSN: Did the matorro belt fit good with the tamiya P/JP sprockets , ore did you have to do some modifications ? And were did you buy them ? Rctank.de ?
thanks
_____________________________
Drammen Rock City
Tamiya KT
Hide Signatures
       Post #: 4
RE: HL Panther hull fit a TAM Jagdpanther lower hull? - 1/15/2013 3:52 PM
wsn123
Score: 104
Status: offline
quote:
ORIGINAL: sollie
thanks
As I mentioned in another thread I used  Tamiya Panther/Jagdpanther  metal sprockets with Matorro metal tracks without any modifications
http://www.rcuniverse.com/forum/m_11345122/anchors_11353740/mpage_2/key_/anchor/tm.htm#11353740
I've bought those  metal tracks from another tank modeler - I asked him were he had bought them -  but he didnt answer.  He said only that there are Matorro tracks.
In rctank.de Ive bought earlier Taigen metal tracks for Panther  but they didnt fit my Tamiya Panther sprockets and Ive send them back .
I supoose that it should be  this  Mattoro tracks
Page no 2 - Panther tank
http://www.matorro.com/metalparts_45.html#2
http://www.ebay.de/itm/PANTHER-METALLKETTEN-SET-KETTEN-LEIT-TREIBRADER-/260287770577?pt=RC_Modellbau&hash=item3c9a5c2fd1
< Message edited by wsn123 -- 1/15/2013 5:06 PM >
Hide Signatures
(in reply to sollie)
       Post #: 5
RE: HL Panther hull fit a TAM Jagdpanther lower hull? - 1/15/2013 4:59 PM
MAUS45
Score: 100
Status: offline
Hi Piotr,
What bearing assembly did you use on your gearbox drive shaft to give it support on the outside of your lower hull see your photo?
I would like to do the same for my Tamiya Panther G lower hull.
Rudy
Click for fullsize
3 Tamiya''s Tiger I, Tiger II, Panther G, 3 HL Stug III G, 1 HL Panzer III M, 1 Jagdpanzer IV L/70, 1 1/8 Tiger II
Hide Signatures
       Post #: 6
RE: HL Panther hull fit a TAM Jagdpanther lower hull? - 1/15/2013 5:25 PM
wsn123
Score: 104
Status: offline
quote:
ORIGINAL: MAUS45
Hi Piotr,
Rudy
Hello Rudy
I used in my Panther 7,99 mm axle supportswith ball bearings from rctank.de
Panther G axle supports with ball bearings (7,99mm)
http://www.rctank.de/product_info.php?cPath=23_75&products_id=1141
Hide Signatures
(in reply to MAUS45)
       Post #: 7
RE: HL Panther hull fit a TAM Jagdpanther lower hull? - 1/15/2013 6:22 PM
MAUS45
Score: 100
Status: offline
Thanks Piotr,
you are using the stock Tamiya drive gear boxes as well?
Rudy
Hide Signatures
       Post #: 8
RE: HL Panther hull fit a TAM Jagdpanther lower hull? - 1/15/2013 7:55 PM
CHIEFSONN
Score: 100
Status: offline
Sollie http://www.ebay.de/itm/PANTHER-METALLKETTEN-SET-KETTEN-LEIT-TREIBRADER-/260287770577?pt=RC_Modellbau&hash=item3c9a5c2fd1 these tracks mentioned are for the heng long Pantiger,not sure if they will fit the tamiya sprocket,they do not fit the heng long panther sprocket. the teeth are spaced at a greater distance apart <> if you have a tiger you will see the difference in the space across from the inner sprocket to the outer one.
"Wenn ich ''''Kultur'''' höre, nehme ich meine Pistole."
Herman Goring
Hide Signatures
       Post #: 9
RE: HL Panther hull fit a TAM Jagdpanther lower hull? - 1/15/2013 8:24 PM
wsn123
Score: 104
Status: offline
quote:
ORIGINAL: MAUS45
Thanks Piotr,
Rudy
Yes, I used standard  Tamiya Panther gearboxes + black M02  motors
Hide Signatures
       Post #: 10
RE: HL Panther hull fit a TAM Jagdpanther lower hull? - 1/15/2013 8:40 PM
sollie
Score: 110
Status: offline
quote:
ORIGINAL: MAUS45
Hi Piotr,
Rudy
Hey maus. I did like this on my JP build.
wsn123: thanks for the info. I read(and commented) in the other tread, I thought maybe you had heard back fro mthe seller, but it seems that the tracks from Domeniq is a 'no go' then.
CHIEFSONN : thanks for the heads up. Now I'm confused on what to get. Seems like the only safe way is impackt tracks , if not wsn123 can confirm that the tracks that works are the same as the ones in the ebay link :-)
Click for fullsize
Click for fullsize
Click for fullsize
Drammen Rock City
Tamiya KT
Hide Signatures
       Post #: 11
RE: HL Panther hull fit a TAM Jagdpanther lower hull? - 1/15/2013 10:52 PM
MAUS45
Score: 100
Status: offline
Hi Sollie,
I have that same transmission cover, I think? Is the HL metal cover from Asiatam? If so what size bearing did you use?
Rudy
Hide Signatures
       Post #: 12
RE: HL Panther hull fit a TAM Jagdpanther lower hull? - 1/16/2013 3:30 AM
mazzsgp2
Score: 100
Status: offline
WSN123,
may I ask how did you secure or screw down the HL panther hull onto the Tamiya hull? I dont see any posts or screw holes ?
thanks!
As an open question to all, has anyone with experience on how to wire the HL recoil to be compatible with the Tamiua MFU DMD units? or did you guys have to swap to the tamiya recoil too?
Hide Signatures
       Post #: 13
RE: HL Panther hull fit a TAM Jagdpanther lower hull? - 1/16/2013 8:56 AM
sollie
Score: 110
Status: offline
quote:
ORIGINAL: MAUS45
Hi Sollie,
Rudy
I bought some 8X22X7MM from a skate shop on ebay. 2 part epoxy and in they went :-)
Drammen Rock City
Tamiya KT
Hide Signatures
       Post #: 14
RE: HL Panther hull fit a TAM Jagdpanther lower hull? - 1/17/2013 2:36 AM
MAUS45
Score: 100
Status: offline
Thanks Sollie, I am going to use your method for the bearings. Did you epoxy the transmission housing to the side of the hull as well? I know that it is held in place partially by the small return/backlash roller on the transmission housing. Just looks like it would need some extra support/epoxy or screws to take the stress of the drive axle.
Hide Signatures
       Post #: 15
RE: HL Panther hull fit a TAM Jagdpanther lower hull? - 1/17/2013 8:18 AM
sollie
Score: 110
Status: offline
Well that pic is just a dry test. I did grind of those small standoffs and are using the roller wheel screw to hold it in place, and will glue it down with 2 part . I only do backyard driving, and no hardcore battle so it should hold up with just the screw + glue.
the bearing is also glued in place, taking care not to spill any one the inner part of the bearing :-)
Drammen Rock City
Tamiya KT
Hide Signatures
       Post #: 16
RE: HL Panther hull fit a TAM Jagdpanther lower hull? - 1/21/2013 11:58 AM
philipat
Score: 104
Status: offline
quote:
ORIGINAL: wsn123
How do you connect the top to the bottom hull?  The rear is from Heng Long?  Does that mean that you cut the back of the lower hull off the HL tank?  Why not use the rear of the Tamiya?
Looks like a good project...do you have a detailed build thread somewhere?
It''s been said that politics is the second-oldest profession...it bears a great similarity to the first. -Ronald Reagan
Hide Signatures
       Post #: 17
RE: HL Panther hull fit a TAM Jagdpanther lower hull? - 1/21/2013 8:47 PM
wsn123
Score: 104
Status: offline
quote:
ORIGINAL: philipat
Yes the rear is from Heng Long Panther -  cutting back of the lower hull wasn't needed, in HL Panther the whole rear is mounted using two screws only. I  bought  "second hand" Tamiya Panther lower hull only  without any  rear , so I used this part   from my Heng Long Panther.
The front plate of HL upper hull slips  into two front sides  of Tamiya lower hull perfecly -   in  the similair way  as in Tamiya King Tiger .
The end of HL upper hull  is lying freeely on the rear side taken from HL too -  I plan to use additional screw or magnet to attached them stronger.
Hide Signatures
(in reply to philipat)
       Post #: 18
RE: HL Panther hull fit a TAM Jagdpanther lower hull? - 1/21/2013 9:27 PM
tomhugill
Score: 118
Last Login: 5/26/2013
Status: offline
 You lucky devil getting your hands on a Tamiya panther lower hull! It's great that the HL hill with clocked springs is so good, but some times I wish it was slightly flawed so some one would release a reasonable metal lower with torsion bars.
Tamiya:leopard 2a6, king tiger, Porsche king tiger, panther g, jagdpanther. Hooben: elefant, t-55. HL panther f, Jagdpanthe
Hide Signatures
       Post #: 19
RE: HL Panther hull fit a TAM Jagdpanther lower hull? - 1/22/2013 12:11 PM
philipat
Score: 104
Status: offline
quote:
ORIGINAL: wsn123
quote:
ORIGINAL: philipat
Cool...nice way to take advantage of a deal and an opportunity.  Any pictures of how the two hulls fit together?
Hide Signatures
       Post #: 20
RE: HL Panther hull fit a TAM Jagdpanther lower hull? - 1/24/2013 8:44 PM
wsn123
Score: 104
Status: offline
Of course some pictures - I used  Tamiya Panther gearbox and  ETO long can M02 motors and Elmod with Benedini TBS Mini
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 21
RE: HL Panther hull fit a TAM Jagdpanther lower hull? - 1/26/2013 8:33 AM
wsn123
Score: 104
Status: offline
And more photos..
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 22
RE: HL Panther hull fit a TAM Jagdpanther lower hull? - 1/26/2013 9:20 AM
sollie
Score: 110
Status: offline
nice. do you have a quick video of the performance ? and how it sounds ?
Drammen Rock City
Tamiya KT
Hide Signatures
       Post #: 23
RE: HL Panther hull fit a TAM Jagdpanther lower hull? - 1/26/2013 10:15 AM
tomhugill
Score: 118
Status: offline
On the subject of tracks I'd have to avoid the asiatam ones, the only sprockets they fit ate the HL metal ones ad plastic ones. Tamiya don't work and neither do asiatam!
Hide Signatures
       Post #: 24
RE: HL Panther hull fit a TAM Jagdpanther lower hull? - 1/26/2013 1:34 PM
sollie
Score: 110
Status: offline
good to know Tom.thanks
Drammen Rock City
Tamiya KT
Hide Signatures
(in reply to tomhugill)
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.578RCU1
