R/C Twist for C/L??    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Control Lines >> R/C Twist for C/L??
Page: [1]
Login
R/C Twist for C/L?? - 1/17/2013 11:52 AM
gene6029
Score: 120
Last Login: 5/23/2013
Status: offline
I was in the shop last weekend straightening up & came across an R/C Twist model i had crashed & repaired, but never flew again. It got me wondering how it would perform if i converted it over to C/L. Any thoughts or suggestions on this ? I'm not looking for a stellar performer, just something to let the grandson play with & possibly re-ignite his interest. I flew it originally with an os .40 & it lugged the R/C equipment around Ok. It would get us in the air fast if you think its feesible???......Gene
Hide Signatures
       Post #: 1
RE: R/C Twist for C/L?? - 1/17/2013 12:05 PM
controlliner
Score: 100
Status: offline
As a U/C model, I would use a .45 or a .51 on it.
_____________________________
"Keep it clean and not too lean" Duke Fox
Hide Signatures
(in reply to gene6029)
       Post #: 2
RE: R/C Twist for C/L?? - 1/19/2013 1:55 PM
clscale-RCU
Score: 100
Last Login: 2/1/2013
Status: offline
I have converted lots of RC models to CL, the largest being the 1/4 scale Sig Morrisey Bravo, most of them are in the 36" to 60" span. Install a bellcrank, leadout guide and the motor and you are good to go. The leadout guide and the CG location determines the line tension, the bellcrank location is not as critical as the leadout position.
Now that the AMA has approved 2.4 Ghz for CL, you could even install a 2.4 Ghz reciever for the throttle if you so desire. All of my CL scale models are converted RC models with 2.4 Ghz controls for the flaps, throttle, retracts, etc. The elevator is controlled by a bellcrank.
You might need some wiingtip weight, but I have ommitted that on some models with no problems.
Fred Cronenwett
Fred Cronenwett
Float flying and scale
Hide Signatures
(in reply to controlliner)
       Post #: 3
RE: R/C Twist for C/L?? - 1/19/2013 9:15 PM
PWF63
Score: 100
Status: offline
As you say Fred, the position of the bellcrank isn't that critical as long as you have the front leadout on the CG.
Is that what you would do? I do this on all my CL models wether they be CL or converted RC models
Fredo
(Fred Pearson)
Hide Signatures
(in reply to clscale-RCU)
       Post #: 4
RE: R/C Twist for C/L?? - 1/19/2013 10:13 PM
gene6029
Score: 120
Status: offline
Guys,Thats the type of information i was hopeing to hear. I was concerned about the position of the bell crank & leadouts. I plan on putting in a bit of rudder too. I'll put a weight box in the outboard wing & couple the flaps ( with minimal movement) opposite the elevator movement. Any suggestions on line length? Its been over 30 years since i flew anything larger that .049 models & that was just teaching the grandson how to fly.......Gene
Hide Signatures
(in reply to PWF63)
       Post #: 5
RE: R/C Twist for C/L?? - 1/19/2013 10:41 PM
R8893
Score: 100
Status: online
A guy in my R/C club has a very similar model converted. I flew it on New Years day and had a good time. It looped real well and flew inverted nice. C/L models generally take a bit bigger engine to deal with the line drag. 60' lines (0.018" diameter)are pretty standard with engines in the suggested range.
Hide Signatures
       Post #: 6
RE: R/C Twist for C/L?? - 1/20/2013 12:24 AM
gene6029
Score: 120
Status: offline
Thanks for the feed back once again. I was talking about this project at the field today with some of the members & got them pumped up about it! Seems they havent flown C/L in 30 years or so too. It would be neat to get a resurgance going .....Gene
Hide Signatures
(in reply to R8893)
       Post #: 7
RE: R/C Twist for C/L?? - 1/20/2013 7:26 PM
Rubbernecker
Score: 105
Status: offline
Sounds fun Gene. Make an adjustable leadout so you can adjust it or just purchase one from Brodak. Start with 60 foot lines and shorten if needed. A friend of mine and I few the heck out of U-control this summer. I have a Goldberg Buster covered in silk with an OS FP 20 on it. Flies great however I stuffed it while flying inverted. Not much damage. He and I are coming to the Vintage Fly-in in NC this year. I have a Veco Chief on the building board that I hope to be done with by then.
Take Care,
John
Hide Signatures
       Post #: 8
RE: R/C Twist for C/L?? - 1/20/2013 8:41 PM
gene6029
Score: 120
Status: offline
Kool John! Looking foreward to the event myself. Just trying to get the grandson back interested again, who knows maybe I'll be flying C/L again by then .....Gene
Hide Signatures
(in reply to Rubbernecker)
       Post #: 9
RE: R/C Twist for C/L?? - 1/21/2013 8:09 AM
JohnBuckner
Score: 342
Status: online
Hi Gene maybe something over a year ago I came up with with a control line traner using what had been a RC Quickee pylon racer and The transition went from a Nelson .40 to a little magnum .15 and as an intro airplane that flys on fairly long line its been pretty successful.
I built it for a friends 15 year old daughter. That airplane is her prized possesion. We have also kitted up four more But here is the full story and also I choose to use a quick adjustable leadout that you can see in the pictures:
http://www.rcuniverse.com/forum/m_10752510/tm.htm
John
"Keep your controllines tight"
Hide Signatures
       Post #: 10
RE: R/C Twist for C/L?? - 1/22/2013 5:53 PM
gene6029
Score: 120
Status: offline
Thanks John. That was interesting & got my wheels turning.....Gene
Hide Signatures
(in reply to JohnBuckner)
       Post #: 11
RE: R/C Twist for C/L?? - 1/23/2013 3:07 AM
clscale-RCU
Score: 100
Status: offline
I have two models with absolutely no rudder, and they fly great. So you don't have to have a rudder for CL.
Fred C.
Fred Cronenwett
Hide Signatures
       Post #: 12
RE: R/C Twist for C/L?? - 2/2/2013 5:07 PM
JohnBuckner
Score: 342
Status: online
Hi Gene sorry I am late getting back. Yes what fred is saying right rudder is not normally even required. I choose to use all the tricks avalible on that airplane because it mission is strickly an introductory airplane and the whole idea was to give it the ability to fly on the longest lines possible with a .15 engine and it was and is successful flys sixty footers well even in light breezes.
I also would like to add that clscale-RCU fred above was my inspiration quite a few years back when he wrote an artical on over the wire throttle systems I suppose it was around eighteen years ago and think it was model aviation. I did end up with a Bill Young system and it was the miracle that allowed me to continue actively flying in my wheelchair. That system is dated now and has its own special set of problem and I have been in the process of converting over to 2.4 throttles as I beleve fred may have.
Fred I loved the pictures you made of yourself with that large converted stick airplane in the air a long time back at the basin.
John
Hide Signatures
       Post #: 13
RE: R/C Twist for C/L?? - 4/9/2013 9:45 AM
tokpilot
Score: 100
Last Login: 5/13/2013
Status: offline
Currently I have a CAP kit from Great Britan of the SBD and doing it C/L
This is going to have flaps, throtle ,retract landing gear,trimable airelons,and a trimable rudder operated by RC.
I like to build scale and put these items in them.
I get the best of both I have the feel of my airplane in my hand and control everything but the elevator by RC
Once I have all my jigs built I will start a build log.
Airplane has a 69 inch wing span and I have a NOS Fox 78 I plan to use Radio is a Airtronics Stylist
Hide Signatures
       Post #: 14
RE: R/C Twist for C/L?? - 4/10/2013 12:13 AM
gene6029
Score: 120
Status: offline
I think that allowing R/C to control multiple functions (other than the elevator) is a huge move foreward for C/L. I have been reading and have seen many homebuilt handles with R/C systems built in & think thats its great. Thanks for all the help guys....Gene
Hide Signatures
(in reply to tokpilot)
       Post #: 15
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.328RCU1
