HK Rotating Retracts TF Corsair 60 ARF    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Scale Mustang Exhaust - Kit
Seller:  tony-howard
Details:   $35.00   |  5/1/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> ARF or RTF >> HK Rotating Retracts TF Corsair 60 ARF
Page: [1] 2   next >   >>
Login
HK Rotating Retracts TF Corsair 60 ARF - 1/17/2013 11:56 AM
Tony Iannucelli
Score: 115
Last Login: 5/11/2013
Status: offline
Here's an 18 second video showing Hobby King rotators in the center section of a Top Flite Corsair 60 ARF.
http://youtu.be/xplUdKgenKs
Hide Signatures
       Post #: 1
RE: HK Rotating Retracts TF Corsair 60 ARF - 1/17/2013 12:45 PM
Tony Iannucelli
Score: 115
Status: offline
In response to questions: these retracts cost $29 for the pair, plus about $5 shipping. They include 5mm struts which are heavier than 3/16", and they also include all hardware and axles. They have metal trunions. I used H9 warbird wheels in the video and will use them on the plane. I've cycled them at least 40 times. They do not heat up, they don't use a lot of battery, have built in electronic safeguards, and overall seem like a real bargain to me. I use the non-rotators in several other planes with great success. I think they are a real break thru on cost and dependability. Very easy to install too.
Hide Signatures
(in reply to Tony Iannucelli)
       Post #: 2
RE: HK Rotating Retracts TF Corsair 60 ARF - 1/17/2013 4:22 PM
Chad Veich
Score: 265
Last Login: 5/25/2013
Status: offline
Keep us informed Tony and thanks for the vid. Very interesting if they hold up in actual operation. At that price you could have a couple sets of spares! I've got a TF Corsair ARF on the shelf and may consider these. Thanks again!
Hide Signatures
       Post #: 3
RE: HK Rotating Retracts TF Corsair 60 ARF - 1/17/2013 6:54 PM
opjose
Score: 280
Last Login: 5/24/2013
Status: offline
Yes please let us know.
Also let us know how the 5mm wire supplied with the retracts fares.
_____________________________
Don''t worry, be happy and fly something!
Hide Signatures
(in reply to Chad Veich)
       Post #: 4
RE: HK Rotating Retracts TF Corsair 60 ARF - 1/18/2013 12:27 AM
SkyPilot101
Score: 125
Status: offline
Delete
< Message edited by SkyPilot101 -- 1/26/2013 12:35 PM >
Hide Signatures
(in reply to opjose)
       Post #: 5
RE: HK Rotating Retracts TF Corsair 60 ARF - 1/18/2013 1:20 AM
LDM
Score: 174
Last Login: 5/22/2013
Status: offline
Guys , I hate to rain on your parade but i started what turned out to be about a 30 page forum in another website on these retracts.
My goal at the time was to compare them to the $89 retracts from horizon as far as overall electronics , strength ect .
The good news is that for $29 they are great and hands down they beat the Horizon $89 version with zero problems .
But just like the Horizon gear sold at $89 , they are not suitable for planes over 6 lbs (long term ) .
The problem is in the worm gear , it simply is to weak to handle the load of planes long term over 6 lbs .
Again , I am not an advocate of the more expensive gear , just matching the right hear with the correct weight of the plane
LDM
Hide Signatures
(in reply to SkyPilot101)
       Post #: 6
RE: HK Rotating Retracts TF Corsair 60 ARF - 1/18/2013 3:12 AM
Tony Iannucelli
Score: 115
Status: offline
I've got 40+ flights on my Spitfire, probably 60-80 on my AT-6, and never a problem. There have been a few hard landings and a couple of nose-overs. The gear always has held up. My piloting skills are not always on the money and the AT-6 struts have been tweaked more than once, but the retract units remain perfect. I re-bend the struts and fly some more. Electronics stay good. The struts on the Spitfire are 5mm and are very strong. They are Top Flite P-47 struts. These are 10 pound airframes. I've used Robarts on them also. They lift the extra weight no problem. These are the SAME units as the ones labeled "46" size (7.7 pounds) on one HK listing, and are rated for ten pounds on another. The rotators actually have metal trunnion blocks and 5mm struts where the 90 degree units are composite trunnions. My money is on the rotators to be just as strong or stronger. That being said, the wheel landings will be controlled and not crashed into the ground (hopefully). Time will tell. My last Corsair was "fun" especially in cross winds.
Given the cost of these, I'm sure there will be worn out parts after a while, but can't imagine I won't get my money's worth five times over any others. HK sells a lot of them. Get them when you can if you are going to try them.
We all need to go with the experiences we've had. Mine have been good. Actually, couldn't ask for better. If you try them, I hope you have good luck too. -Tony
Hide Signatures
(in reply to LDM)
       Post #: 7
RE: HK Rotating Retracts TF Corsair 60 ARF - 1/18/2013 4:16 AM
LDM
Score: 174
Status: offline
Tony , I think its great and I am very glad that you are getting great results . Perhaps they introduced a heavier version then the ones we tested . I am 100% in your camp and my original thread was started because I could not understand why I would pay $89 for retracts that I could get at the time for $ 7.00 a unit ($14.00 ) in total . and they worked great and equal to the $89 .
Then it dawned on me that between the USA distributor mark up and build in margin for warranty they needed to build all those things into the cost .
If you visit RC Castle , you can get a set of rotating gear with a scale corsair wheels, aluminum struct covered in a plastic scale looking corsair gear leg for $69 bucks . I will try to post a picture
LDM
Hide Signatures
       Post #: 8
RE: HK Rotating Retracts TF Corsair 60 ARF - 1/18/2013 4:18 AM
LDM
Score: 174
Status: offline
Could not find my pics on the corsair ones that I have , I will take some on Friday , this is the same type offered but P51 style
Click to see fullsize image.
Click for fullsize
LDM
Hide Signatures
(in reply to LDM)
       Post #: 9
RE: HK Rotating Retracts TF Corsair 60 ARF - 1/18/2013 4:33 AM
LDM
Score: 174
Status: offline
Ok , this is the FMS corsair gear , sold by RC Castle with wheels , struts ect, designed for the 67" FMS corsair
Click for fullsize
LDM
Hide Signatures
(in reply to LDM)
       Post #: 10
RE: HK Rotating Retracts TF Corsair 60 ARF - 1/19/2013 1:33 AM
Tony Iannucelli
Score: 115
Status: offline
Those look neat. Since they include functioning struts and wheels too the price is fair. One thing I don't like about those and the HKs is that the footprint is small, almost square. I have some fear those big tires will act like the end of a lever on a hard landing and since the struts are strong they will pull the screws out of the mounting rails or worse. The shock absorbers would be a real bonus in a bad landing. (Not that we have bad landings occasionally, oh no). The worry will go away after some less than perfect landings will prove no damage. In fact, I'm counting on it. The rails in the wing look pretty strong too. I can see there's enough glue in there and the wood is hard. I'm really slow on the build, so it will be a while before the test flights. Thanks for the information. It's always good to learn new stuff even after 40 years in R/C. Yikes, that's a long time.
PS, I wish the Robarts were electric and about 1/3rd the price. They have a footprint that looks proper for this plane. But I'm finished with pneumatic retracts, and paying high prices. Tony
Hide Signatures
(in reply to LDM)
       Post #: 11
RE: HK Rotating Retracts TF Corsair 60 ARF - 1/19/2013 3:55 AM
LDM
Score: 174
Status: offline
Thats a long time Tony , hahah , just kidding buddy , by the way Hello from another Itialian "DiMarco" !!
52 years of age , been dreaming about rc when I was a teen , could not afford it , but had a great dad who always tried to make it happen . Then college , marrage , great kids , and the last 4 years back in RC .Good news , I can afford it now lol , so I to be careful not to spend on silly rc whims , like you I look for great values.
I am useing Turnegy 80 degree retracts in my Platt dora kit , there not bad , all medal ect but the circuit board has some gaps and that creates slop in the retracts .
If anyone stumbles on the Turnegy rotating all medal gear retracts , dont buy them , the motor is infront of the assembly and will force you to cut into the leading edge of your plane to get the retracts to fit !!!
Have a great weekend !!!
LDM
Hide Signatures
       Post #: 12
RE: HK Rotating Retracts TF Corsair 60 ARF - 1/20/2013 3:01 PM
WindGap
Score: 105
Status: offline
http://www.hobbyking.com/hobbyking/store/__20969__0_46_Servoless_Retractable_Landing_Gear_w_Metal_Trunnion_fixed_90_deg_Rotate_Pair_.html
Hide Signatures
(in reply to LDM)
       Post #: 13
RE: HK Rotating Retracts TF Corsair 60 ARF - 1/20/2013 3:59 PM
Tony Iannucelli
Score: 115
Status: offline
Here they are in action, no cutting necessary.
Hide Signatures
(in reply to WindGap)
       Post #: 14
RE: HK Rotating Retracts TF Corsair 60 ARF - 1/21/2013 3:37 AM
m3_express
Score: 100
Status: offline
LDM,
Interesting. I didn't know these existed. I looked up the FMS 1.7M Corsair and it seems the AUW is about 9.5 lbs... So, it seems these retracts could hold up work well with the TF Corsair. Just need to find the specs on the strut length and wheel diameter....
M3
Hide Signatures
(in reply to LDM)
       Post #: 15
RE: HK Rotating Retracts TF Corsair 60 ARF - 1/21/2013 4:08 AM
LDM
Score: 174
Status: offline
i have an extra set and will measure them for you, i bought them for my red box P40
LDM
Hide Signatures
(in reply to m3_express)
       Post #: 16
RE: HK Rotating Retracts TF Corsair 60 ARF - 1/21/2013 4:39 AM
m3_express
Score: 100
Status: offline
LDM,
That would be great if you would do so. I have the TF Corsair .60 ARF and was going to go the Lado route but I'd love to save ~$200 by using these if possible.
M3.
Hide Signatures
(in reply to LDM)
       Post #: 17
RE: HK Rotating Retracts TF Corsair 60 ARF - 1/21/2013 4:45 AM
LDM
Score: 174
Status: offline
m3 no problem we soon as i return home from work on Monday will post pics and get you the measurments ,possibly post a video
LDM
Hide Signatures
       Post #: 18
RE: HK Rotating Retracts TF Corsair 60 ARF - 1/22/2013 10:57 AM
LDM
Score: 174
Status: offline
M3 this is the retracts and there size
http://youtu.be/tbfQCXcqf2I
LDM
Hide Signatures
(in reply to LDM)
       Post #: 19
RE: HK Rotating Retracts TF Corsair 60 ARF - 1/23/2013 6:11 AM
m3_express
Score: 100
Status: offline
LDM,
Awesome vid. Thanks for taking the time to make the video. So it seems the measurement is 6.5" from top of retract housing to center of the wheel and about 3.75" for the wheel diameter.
You state that they seem fairly robust; but I'm still concerned about the fact the strut housing is made out of plastic.... How does the rotating mechanism appear? From the video, it looks like there is a pin used to rotate the gear. I wonder how stout this method will be in preventing the gear to twist out on a less-than-perfect landing.
M3
Hide Signatures
(in reply to LDM)
       Post #: 20
RE: HK Rotating Retracts TF Corsair 60 ARF - 1/24/2013 6:45 AM
LDM
Score: 174
Status: offline
m3 the gear unit is very very stout .THe FMS corsair is in the 9 to 11 pound range .
The least of the concern is the mechanism , the legs do not have to be purchased and you can add struts of your choice .
So far those using them on the FMS corsair have had zero issues .
All of the Electric units have a linear type drive screw that rides over a circuit board .
The ones used on the FMS gear is very heavy duty and the compression strut takes mush of the load .A Robart strut, VQ , Shindig , RC Ski lite etc will only add to the durability.
I am going to draw the footprint of the gear and take better closeups on Thursday night
LDM
Hide Signatures
       Post #: 21
RE: HK Rotating Retracts TF Corsair 60 ARF - 1/26/2013 3:20 AM
raptureboy
Score: 178
Status: offline
Well I just ordered a set of these tonight http://www.sonicelectric.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=LD-MERS-AM100&Category_Code=NEW&Product_Count=0  even though the motor is in the front the dimensions will fit inside the opening of my Top Flite P-40 ARF without modifications. They look pretty solid and only cost $112 shipped. When I get them I will do a report and let you all Know. Thanks LDM for your video again and your help.
This is the real task before us: to reassert our commitment as a nation to a law higher than our own.
Hide Signatures
(in reply to LDM)
       Post #: 22
RE: HK Rotating Retracts TF Corsair 60 ARF - 1/26/2013 3:44 AM
LDM
Score: 174
Status: offline
Hi Raptureboy , that gear in the pic is the RC lander gear . I hope they will work for you but in most cases the motor is prohibitive as you stated because it will cut into the leading edge.
I do see the great forward rake so perhaps they will allow you to install them far enought back so that the motor will clear the leaging edge .
Keep us posted and good luck
LDM
Hide Signatures
(in reply to raptureboy)
       Post #: 23
RE: HK Rotating Retracts TF Corsair 60 ARF - 1/26/2013 11:42 PM
raptureboy
Score: 178
Status: offline
LDM, thanks. I know what about the motor but looking at the total length of the unit and the size of the opening in the wing of my P-40 I know they will fit, but my only concern will be where the strut will fall as it crosses over the spar.I really like that they are made of metal so cross our fingers and hope fro the best
Hide Signatures
(in reply to LDM)
       Post #: 24
RE: HK Rotating Retracts TF Corsair 60 ARF - 1/31/2013 10:54 PM
raptureboy
Score: 178
Status: offline
Well the new retracts came in today, I will have to say that they seem very well made and operate without issue. I don't think they will work for the corsair and hellcats without some major changes to your setup because the motor is mounted in the front, but because I am using them in a P-40 which has the retract covers it should not be a problem. I will post some pics and video in a day or so.
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.633RCU1
