Mintor 22cc engine    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> Mintor 22cc engine
Page: [1] 2   next >   >>
Login
Mintor 22cc engine - 1/18/2013 3:33 PM
captinjohn
Score: 247
Last Login: 5/21/2013
Status: online
I was just wondering if there was any Mintor 22cc owners out there and can you share anything about them?
Thanks   Capt,n
_____________________________
I never met a engine I did not like !
Hide Signatures
       Post #: 1
RE: Mintor 22cc engine - 1/18/2013 4:02 PM
karolh
Score: 310
Last Login: 5/22/2013
Status: offline
They are out there but it seems as if they only visit that other site.
Karol
When inverted always remember that down is up and visa versa
Hide Signatures
(in reply to captinjohn)
       Post #: 2
RE: Mintor 22cc engine - 1/18/2013 8:41 PM
pe reivers
Score: 646
Status: offline
That's what you get when only political correct answers are allowed, and no mention can be made of other valuable forums.
Pe, (www.mvvs.nl), MVVS, MOKImotor, RCexl, MTW, Xoar, Mejzlik.
Blessing in ignorance? There is sanctuary in analysis.
Hide Signatures
(in reply to karolh)
       Post #: 3
RE: Mintor 22cc engine - 1/18/2013 11:35 PM
TimBle
Score: 162
Status: offline
I own one and it runs great. No compression issues as others have reported. Its mounted in a H9 Showtime 90. I am extremely pleased with its flight performance with this engine. I do wish it could cure the twitchy nature of this bird but its a practice pattern plane so live and let live.
Hide Signatures
(in reply to pe reivers)
       Post #: 4
RE: Mintor 22cc engine - 1/19/2013 12:13 AM
karolh
Score: 310
Status: offline
quote:
ORIGINAL: pe reivers
Such a pity.
Karol
Hide Signatures
       Post #: 5
RE: Mintor 22cc engine - 1/19/2013 2:04 AM
captinjohn
Score: 247
Status: online
The Mintor 22cc engine not only looks good on the outside,  it has good looking parts on the inside.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 6
RE: Mintor 22cc engine - 1/19/2013 2:51 AM
karolh
Score: 310
Status: offline
Yes it really does, and it's a pity that installing some inferior quality rings almost spoilt the package for a few of us.
Karol
Hide Signatures
       Post #: 7
RE: Mintor 22cc engine - 1/20/2013 9:41 PM
mrbigg
Score: 155
Last Login: 4/24/2013
Status: offline
Wasn't there problems on the factories end? I'm thinking they are sorted out by now but don't know for sure. This engine is at the top of my list for a 20cc engine. I'll be ordering one soon for my Mojo 65 kit. That's as long as there are none of them issues still going on.
Smooth, like Keith Stone.
Hide Signatures
       Post #: 8
RE: Mintor 22cc engine - 1/20/2013 10:11 PM
karolh
Score: 310
Status: offline
Yes there was a problem as some of the engines were supplied with undersized pistons and inferior quality rings obtained from third party suppliers, but Mintor finally recognised the problem and ceased production until everything was sorted out. They are now back in operation, and you can check that other ** site for more information on it.
Karol
Hide Signatures
(in reply to mrbigg)
       Post #: 9
RE: Mintor 22cc engine - 1/20/2013 10:44 PM
mrbigg
Score: 155
Status: offline
I remember the ring issue, but don't remember the piston deal.
Hide Signatures
       Post #: 10
RE: Mintor 22cc engine - 1/20/2013 10:45 PM
TimBle
Score: 162
Status: offline
one of two engines had an undersize piston issue. Mostly it was poor piston rings that caused the biggest headaches
Hide Signatures
       Post #: 11
RE: Mintor 22cc engine - 1/22/2013 6:32 AM
bcchi
Score: 650
Status: offline
quote:
ORIGINAL: captinjohn
Don't look so good to me.Why is the engine mounts worn so bad where the washers were on the mounting bolts.Piston maybe a question also.
BC
Hide Signatures
       Post #: 12
RE: Mintor 22cc engine - 1/22/2013 3:54 PM
karolh
Score: 310
Status: offline
quote:
ORIGINAL: bcchi
BC
Those are not wear marks on the engine mounts but a shallow machined recess for the mounting washers.
Karol
< Message edited by karolh -- 1/22/2013 9:36 PM >
Hide Signatures
(in reply to bcchi)
       Post #: 13
RE: Mintor 22cc engine - 1/22/2013 8:11 PM
captinjohn
Score: 247
Status: online
The rod is of good size on both ends.  You can still see every lathe mark on the piston all the way around.  This was after about 2 gallons.  The only thing I see not good was a area of the piston ring that was not getting the correct shiny contact look.  Like the ring was void of material in that area.  Fix... a new F Bowman ring.  Also a .012 end gap...too big.   Capt,n
Hide Signatures
       Post #: 14
RE: Mintor 22cc engine - 1/22/2013 9:46 PM
karolh
Score: 310
Status: offline
I found a similar situation with the stock ring in my engine which had an end gap of .011". Mostly out of curiousity I measured my piston and it turned out to be exactly what Frank had suggested it should be, 1.336", and with one of his rings installed the gap is .004"...... good enough for me.
Karol
Hide Signatures
       Post #: 15
RE: Mintor 22cc engine - 1/23/2013 7:05 AM
bcchi
Score: 650
Status: offline
quote:
ORIGINAL: karolh
quote:
ORIGINAL: bcchi
BC
Karol
Your kidding me.Bet it's not minus 27 below where you live. Good time to get some airplane work done.
BCCHI Grumpy no two.
Hide Signatures
       Post #: 16
RE: Mintor 22cc engine - 1/23/2013 10:55 AM
pe reivers
Score: 646
Status: offline
Cold and snow works wonders with a man's idle mind.
Hide Signatures
(in reply to bcchi)
       Post #: 17
RE: Mintor 22cc engine - 1/23/2013 2:25 PM
karolh
Score: 310
Status: offline
No cold or snow here, this is the Caribbean with year round sunshine. Pity I am unable to share it with you guys.
Karol
Hide Signatures
       Post #: 18
RE: Mintor 22cc engine - 1/23/2013 4:26 PM
TimBle
Score: 162
Status: offline
Plenty sunshine in Cape Town this week. Loads of wind too, perfect for those planes that don;t attract the "What Oil for my XYZ123" question
Hide Signatures
       Post #: 19
RE: Mintor 22cc engine - 1/23/2013 5:57 PM
captinjohn
Score: 247
Status: online
Nice here in Florida...I may fly my Carl G  330 Extreme Pofile...not gas....just a junker!!!!!!!!!
Hide Signatures
(in reply to TimBle)
       Post #: 20
RE: Mintor 22cc engine - 1/23/2013 6:50 PM
Truckracer
Score: 304
Status: offline
Hmmm, I fear the open ported cylinder is starting to take its toll on the piston skirt. Note how good the piston skirt looks below the port window in the skirt ... and how it is showing skuffing on either side of the clear part of the skirt? Like many engine designs these days, the piston is not well supported on that side. Once wear starts, it will only progress from there. I believe there are more open ported cylinders these days as a compromise between ease of production and desired performance. In the process, piston wear is accelerated.
Hide Signatures
       Post #: 21
RE: Mintor 22cc engine - 1/23/2013 10:51 PM
pe reivers
Score: 646
Status: offline
open ported pistons are there for a reason. The reason is that many model pilots neglect engine cooling, in which case the open ported piston saves their day at the field. So it reduces engine life a little bit? How many of us run their engines in excess of 200 hours without overhaul?
Hide Signatures
(in reply to Truckracer)
       Post #: 22
RE: Mintor 22cc engine - 1/24/2013 12:48 AM
captinjohn
Score: 247
Status: online
I am sure with that big port in the side of the piston will allow a lot of incoming air/fuel flowing through the piston will cool it real good.  I seen a photo of one ran on the rich side and the top of the piston had lots of carbon with a oil gue residue.  A rich mixture probably should be avoided on this type of engine.  My thoughts anyway.  Capt,n
Click for fullsize
Hide Signatures
       Post #: 23
RE: Mintor 22cc engine - 1/24/2013 1:01 AM
Truckracer
Score: 304
Status: offline
While I certainly agree with you regarding piston porting, I feel open cylinder porting is more a matter of easier production. For example, the classic DA50 / 100 cylinder has a closed bottom port opposite the exhaust port and as a result, there is minimal piston skirt wear because the skirt is supported through most of the stroke and especially at the top and bottom of the stroke. DA pistons don't seem to show a lot of wear on either piston skirt. Early DLE cylinders had a closed intake port on the port opposite the exhaust but later versions went to open porting on all intake ports. There has been reports of excessive piston wear as a result. The Jedi in another forum even posted some photos to support this. It was also indicated that when these cylinders are used on a twin, due to different thrust angles, one piston tends to wear where the other one does not.
This is not a criticism of these engines at all, just an observation. As you say Pe, most of these engines will never run to their limits before overhaul or repair anyway. I thought it interesting that the condition was so easily viewed in the posted photos though.
Hide Signatures
       Post #: 24
RE: Mintor 22cc engine - 1/24/2013 3:56 AM
Mikola
Score: 106
Last Login: 5/8/2013
Status: offline
quote:
ORIGINAL: mrbigg
http://tinyurl.com/9wupob8
Hide Signatures
       Post #: 25
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> Mintor 22cc engine
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.609RCU1
