volcano s30 carb adjustment    Gallery
Logged in as Guest
    Search This Thread
Printable Version
More Resources on the
Volcano S30
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> volcano s30 carb adjustment
    Page: [1]
    Login
    volcano s30 carb adjustment - 1/19/2013 3:48 AM
    steamfitter602
    Score: 100
    Last Login: 1/19/2013
    Status: offline
     I have a new volcano s30.  I sucsessfully completed the 5 tank break in process.The next time i went to use the the truck the Idle was out of control. I found that the carb needle screw for the idle had vibrated loose and the carb had actually slid over inside the barrell. how do i get all the needle screws back to a "default" position so I can star over?
    Hide Signatures
           Post #: 1
    RE: volcano s30 carb adjustment - 1/19/2013 4:04 AM
    Dads like rc too
    Score: 540
    Last Login: 5/25/2013
    Status: offline
    quote:
    ORIGINAL: steamfitter602
     I have a new volcano s30.  I sucsessfully completed the 5 tank break in process.The next time i went to use the the truck the Idle was out of control. I found that the carb needle screw for the idle had vibrated loose and the carb had actually slid over inside the barrell. how do i get all the needle screws back to a ''default'' position so I can star over?
    When you say "the carb actually slid over inside the barrel", did you mean the barrel slid over? The idle screw fits into a little notch in the barrel. If the idle screw is all that came loose you just have to pull the barrel back to where the idle screw will fit back into the little groove or notch in the barrel and screw the idle screw back into place. You can take the air filter off and turn your electronics and radio on and set it back up. Look into the carb and set you idle so the barrel has a tiny gap in it, as you turn the idle screw in, the gap gets bigger. You just want it it enough so it isn't closed all the way. Then when you brake the idle screw also keeps the barrel from fully closing and causing the engine to stall. You can also test this by looking in the carb with the engine off. You shouldn't have to touch your low or high speed needle if the idle screw was your only issue.
    _____________________________
    Caldera 10e : Volcano EPX : Monsoon XTR : Sumo x2 :
    Hide Signatures
    (in reply to steamfitter602)
           Post #: 2
    RE: volcano s30 carb adjustment - 1/19/2013 4:15 AM
    steamfitter602
    Score: 100
    Status: offline
    I did mean the barrel slid over. I think I got the screw back in like you said but I also tried adjusting the high and low needle after breaking in the motor. it was very fat out of the box wich was good for break in but caused it to be sluggish and bog down when going from idle to full throttle. is there a way to reset the high and low needles? Im new to gas rc but on larger engine you can usually adjust all the way in and count turns back out to get a starting point.
    Hide Signatures
    (in reply to Dads like rc too)
           Post #: 3
    RE: volcano s30 carb adjustment - 1/19/2013 4:27 AM
    Dads like rc too
    Score: 540
    Status: offline
    There are different opinions on the how many turns out question. You will find 3.5 to 4 turns out to be most common on the forum. Personally I run the needles out unlit they are just beyond flush with the sleave they are in. Get it good and rich, then it's easy from there to adjust in as necessary.
    Hide Signatures
           Post #: 4
    RE: volcano s30 carb adjustment - 1/19/2013 4:33 AM
    steamfitter602
    Score: 100
    Status: offline
    Thanks for the help. I'll give that a try and let you know how it goes. Hopefully the idle adjustment screw doesnt come loose again. I was lucky to find it in the bottom of the chasis! Thanks again
    Hide Signatures
           Post #: 5
    Page:   [1]
    Page: [1]
    Volcano S30
  • See User Ratings
  • Jump to:
    Google
    SITE MAP!   : :   FORUM RULES
    0.266RCU1
