Diff upgrades for Hurricane XTR    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> Diff upgrades for Hurricane XTR
Page: [1]
Login
Diff upgrades for Hurricane XTR - 1/19/2013 5:15 AM
davidgp
Score: 100
Last Login: 2/13/2013
Status: offline
All three differentails in my Hurricane XTR are slipping. Total run time is less than 1 hour, and I've never opened the diff cases before. I can rebuild the diffs if necessary, but I'm afraid they will just wear out again. Are there any upgrades available? I guess I could just use the grub screw to lock the diffs also.
Thanks.
David
Hide Signatures
       Post #: 1
RE: Diff upgrades for Hurricane XTR - 1/19/2013 12:41 PM
Dads like rc too
Score: 540
Last Login: 6/18/2013
Status: offline
quote:
ORIGINAL: davidgp
Thanks.
David
What do mean when you say the diffs are slipping? Are you saying the diff gears have stripped or that the wheels are moving independently of each other.
_____________________________
Caldera 10e : Volcano EPX : Monsoon XTR : Sumo x2 :
Hide Signatures
(in reply to davidgp)
       Post #: 2
RE: Diff upgrades for Hurricane XTR - 1/19/2013 4:54 PM
nitrosportsandrunner
Score: 296
Last Login: 6/19/2013
Status: offline
when these diffs go, you know it. It will make loud grinding or clicking sounds!
If the power just isnt getting to either the front/rear wheels right, then suspect the center diff. If it goes, the power wont get to the front or rear.
Also wanna make sure none of the driveshaft slug screws are loose (center shaft input cups)
if they are bad, buy the gears you need AND buy part # 81069
its a shim kit. Sometimes the input pinion shaft or even the ring gear's mounts have a bit of play. Shimming them with the parts in the shim kit will make them last alot longer.
Simillar issue happens with some of the XTE and 8e models. The shim kit has any/all shims needed to get everything meshed well.
SC10 brushless, Thunder Tiger Phoenix XB Brushless, 1/5 custom rock crawler, Slash 4x4, Atomik Barbwire
Hide Signatures
(in reply to Dads like rc too)
       Post #: 3
RE: Diff upgrades for Hurricane XTR - 1/22/2013 12:27 PM
lifeismuddy
Score: 100
Last Login: 6/13/2013
Status: offline
I keep a hurricane here in the store as a demo and have sold several and have yet to have any dif issues, check the cup set screws they are prone to coming loose.
Denny
Big Boys RC Toys
Hide Signatures
(in reply to nitrosportsandrunner)
       Post #: 4
RE: Diff upgrades for Hurricane XTR - 1/22/2013 4:04 PM
Score: 296
Status: offline
quote:
ORIGINAL: lifeismuddy
agreed. I dont see all 3 diffs failing at the same time. Once one goes, there wont be much stress on the others...and the truck wont go as fast.
And as mentioned, bad diffs are pretty loud.
Hide Signatures
(in reply to lifeismuddy)
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.141RCU1
