asp engines    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> asp engines
Page: [1]
Login
asp engines - 1/19/2013 6:12 PM
cubkadet
Score: 100
Last Login: 5/17/2013
Status: offline
any comments or opinions on the asp airplane engines?
Hide Signatures
       Post #: 1
RE: asp engines - 1/19/2013 6:20 PM
Prairie Mike
Score: 105
Last Login: 5/18/2013
Status: offline
They seem okay. I've got a 160 twin and have not had any problems. It's supposed to be an OS clone.
_____________________________
Tejas Mic
I want to go peacefully in my sleep like Grand Pa...... Not screaming like the passengers in his plane
Hide Signatures
(in reply to cubkadet)
       Post #: 2
RE: asp engines - 1/19/2013 6:23 PM
jeffie8696
Score: 120
Last Login: 5/15/2013
Status: offline
Hit and miss quality control, if you get a good one its a good deal. Also know as Magnum brand engines.
Club Saito # 677 , Team Boca Bearings and Star Collectibles Muscatine
Hide Signatures
(in reply to Prairie Mike)
       Post #: 3
RE: asp engines - 1/19/2013 7:03 PM
AMB
Score: 110
Last Login: 5/19/2013
Status: offline
I have 12s thru 52s no issue ASP/Mag 2 or 4 strk all the 2 strk and one 52 4 strk converted to diesel excellent carbs no issues, even with the increased compression with the diesel heads no failures or issues at all martin
Hide Signatures
(in reply to jeffie8696)
       Post #: 4
RE: asp engines - 1/19/2013 7:37 PM
hugger-4641
Score: 229
Status: offline
I have a new ASP .61 two stroke with maybe a gallon or two of fuel through it, no problems so far, runs just like every other Magnum two stroke I've got. Very dependable. Just like the other Magnums I've got, when I first set it up and broke in, I did have a little trouble getting the thing to stop. The barrel has to be closed tighter than most engines to shut it off.
Jerry
AMA -922698 Nomal people scare me, but not as much as I scare them...
Hide Signatures
       Post #: 5
RE: asp engines - 1/19/2013 7:38 PM
Dick T.
Score: 136
Status: offline
Good running engines overall if using 5-10% nitro, castor/synthetic blend fuel. I have run .46 through 1.08 this way with no problems. Some require more break in time than others but start easily and tune well.
These engines will run hot if using pure synthetic oil fuels.
Dick Tristao
ModelGrafix
Hide Signatures
       Post #: 6
RE: asp engines - 1/19/2013 11:34 PM
AJsToyz
Score: 304
Status: offline
I had a Magnum 70 four stroke with bad valve springs from the factory, sent it in to Hobby People for warranty and it ran perfect when I got it back.
www.Deathbychina.com
Hide Signatures
(in reply to Dick T.)
       Post #: 7
RE: asp engines - 1/20/2013 2:30 AM
earlwb
Score: 584
Status: offline
It used to be that the engine itself was pretty much OK, but they had trouble making decent carburetors though. usually a person had to replace the carb to get the engine to run OK.  But for the last few years they seem to be making better carbs though. So the engines tend to work OK.  But usually parts are hard to get, so if you wear something out or break something, you'll have to buy a new engine instead of repairing it. That is one main reason the engines are so much more inexpensive though.  But the engines are made for a low price point, so quality can be off so they can still be hit and miss on getting a good one. Being made for a low price point means a low profit margin, so the manufacturer had to do something to cut costs, such as cheaper metal alloys, cheaper bearings, and so on.
I have played with some of the engines and they are working out Ok for me. I just can't say for how long they'll last though.
Club Saito #722, Sig Kadet Brotherhood #80
AMA # 928076
Hide Signatures
(in reply to AJsToyz)
       Post #: 8
RE: asp engines - 1/20/2013 8:28 AM
fiery
Score: 100
Status: offline
Sanye engines have come along way in 20 years.
Modern Sanye carburettors work very well and are built to tight tolerances.
I opened an old ASP .46 to replace a worn piston and liner. I acquired it second hand. It had never been disassembled. It was made in 1990. It had Japanese NSK bearings in it.
The carburettor on it was not the best. This is where the early engines are a lottery. I replaced it with a carburettor from a GMS .32. It now throttles perfectly on nil nitro fuel.
I have an ASP .40 of the same era. It's original carburettor performs as well as any I have handled. It will idle at 2,200 RPM all day on nil nitro fuel and transition cleanly.
Hide Signatures
(in reply to earlwb)
       Post #: 9
RE: asp engines - 1/20/2013 10:28 AM
Mr Cox
Score: 102
Status: offline
The latest .12 and .15 engines are very nice engines too, with good carbs. But the quality control is not the best, or they simply let things through that should never have gone through...
I have a .15 engine that had a leak in the crank case (straight from the box), it was a little tricky to find as it was leaking between the transfer ports and the exhaust port. The liner was not tight enough in the case, but a thin layer of JB weld fixed it.
Hide Signatures
(in reply to fiery)
       Post #: 10
RE: asp engines - 1/20/2013 11:25 AM
Altered1
Score: 106
Status: offline
I got a ASP 52 A II  last year.
I've put a few litres through it, and she's been a solid powerfull performer.   I had a leak from the mixture needle o'ring not seating properly, but a bit of fuel tubing fixed that.  for the price......  it's a great performer.
Hide Signatures
(in reply to Mr Cox)
       Post #: 11
RE: asp engines - 1/20/2013 12:10 PM
mike109
Score: 148
Status: offline
G'day
I have had quite a few ASPs and Magnums (essentially the same in recent times). I still have a couple of four strokes.
I have only owned a couple of two strokes but I have seen quite a few at my club. On this basis, I would probably not recommend an ASP two stroke to a beginner. They can be good for experienced flyers but not so good for the less experienced.
The four strokes have been better though the spread of quality is far wider than the Japanese brands. I had two 30 four strokes intended for a twin but they ran so differently I gave up on them and sold them to a friend. He also tried them in a twin but they were inconsistent and worse, they liked to dead stick.
I still have an ASP 61 four stroke. It came to me in a plane. Its head leaked. I tried to fix it but ended up with a new replacement head and it is now fine. I also bought a 70 four stroke which also had head problems and again, a new head fixed it although the new head also leaked at first until I cleaned the valves.
My most recent was a 91 four stroke which I bought but did not use. A friend bought it from me and it has been fine since we ran it in and tuned it. Its "out of the box" settings were way too lean especially the Low Speed Needle. It was so lean it initially would not start.
So .... They are fine if you know what you are doing and are prepared to fix little problems. They can be hard to tune (especially the two strokes) and so I would not recommend them to a beginner going it on his own. If he has help, it may be a different story.
Mike in Oz
"I just had no control. Must be the radio." Club Saito #597 Kadet Brotherhood #66
Hide Signatures
(in reply to Altered1)
       Post #: 12
RE: asp engines - 1/20/2013 1:21 PM
oneaew@msn.com
Score: 122
Status: offline
i got 2 61 size start easy run very good try one you might like it
Hide Signatures
       Post #: 13
RE: asp engines - 1/20/2013 4:04 PM
geeter
Score: 108
Status: offline
i believe you can get asp engines from hobbyking. very reasonable prices and not a bad engine for the price...........RON
Hide Signatures
(in reply to oneaew@msn.com)
       Post #: 14
RE: asp engines - 1/20/2013 4:14 PM
oneaew@msn.com
Score: 122
Status: offline
try to buy thins from the usa if you can
Hide Signatures
(in reply to geeter)
       Post #: 15
RE: asp engines - 1/20/2013 4:36 PM
tony0707
Score: 115
Last Login: 5/14/2013
Status: offline
The 75 ASP -ABC with an OS 1.08 carb ( 7 D )was my favorite engine for my 60 size airframes for about 10 years , turns a 13/6 APC
The 75 AX is now my favorite powerhouse 75 , turning a 14 /6 APC
You can run a little more oil in your fuel if you desire with an ASP to protect the engine a bit more
I was flying 20 plus years ago when the ASP line of engines came out
They do not produce as much power as some other engines of the same size displacement , but they will perform well if handled by experienced hands
ENJOY TONY
" The power and performance glo fuel , 15 % Morgan Omega "
Hide Signatures
       Post #: 16
RE: asp engines - 1/20/2013 4:37 PM
oneaew@msn.com
Score: 122
Status: offline
RIGHT ON
Hide Signatures
(in reply to tony0707)
       Post #: 17
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Glow Engines >> asp engines
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.438RCU1
