GallopingGhostler
Score: 133 Joined: 10/26/2004 Last Login: 6/19/2013 From: Clovis,
NM, USA Status: online
quote:
ORIGINAL: Mr Cox quote:
ORIGINAL: GallopingGhostler Regardless, it works, and works well. The engine is one of the most easiest starting and reliably running engines I've used. It idles reliably and transition to full power is smooth. How they accomplish this matters little to me. The engine has a lot of torque, is a good way to hop up a margin half-A to sparkling performance. That is most important. I don't agree, there is no way that OS can know what type of fuel, nitro level, prop size and tank installation you will have. It is the same problem with Norvels and PAW engines etc too. You do need a low end-adjustment, anything else is just a compromise. On the OS .10 you can put a OS .15 carb in as these do have an adjustable airbleed. On PAW engines I've put in Enya 09 carbs (with adjustable airbleeds) and the Norvel .074 really improves with a low end adjustment too. Not offering a low end adjustment is just a way of saving some money in the manufacturing, while offering a mediocre product. Try using an inverted engine setup and you'll soon see the problem with not having a low end adjustment... Well Mr Cox, I'm not lying to you, and have plainly told you that the engine operates fine without an idle mixture screw, and also quoted Peter Chinn's test report, which also concurred with my experiences. Here is what the owner's manual states about the engine's purpose: quote:
The MAX-10R/C engine has been designed specially for single channel radio control rhodels and is notable for its easy handling, excellent throttling characteristics and light weight. It is manufactured by skilled craftsmen to strict tolerances using modern precision machinery and carefully selected top quality materials, to ensure consistent performance and long life. You seem to forget Mr Cox, this mid 1960's technology engine was targeted for those mostly flying single channel airplanes with auxiliary throttles. You also seem to forget that the OS engine manual stipulates the recommended fuel mixtures, the methyl alcohol, nitro, and Castor oil proportions. It states, quote:
FUEL: Break-in - 70% methanol, 30% Castor oil; General - 75% methanol, 25% Castor oil; Contest - 70% methanol, 25% Castor oil, 5% nitromethane. Therefore, as long as a user follows the manufacturer's recommendations, will have acceptable performance with the engine. In addition, I have used fuels with both 15% and 25% nitro content, and the engine performed acceptably. This was in the upright position, which nearly all rudder only planes of the day had the engine oriented. This type orientation was also preferable for rudder only, because with no elevator, it was common to come in at too steep an angle or stall the plane at the last minute. Under the engine was block balsa formed to blend with the nose, and this protected the engine. Also, designers used break away plywood mounts to which the engine was mounted, which in turn were mounted to hardwood rails. A severe enough crash would cause the plywood to break, freeing the engine and hopefully preventing further damage to it. Also, the manual further states, quote:
Propellers Suggested propellers are 7x4, 8x3 or 8x4 but, as the suitability of the propeller varies according to size and weight of the model, make your final selection after practical experiment. Thus, the manufacturer based their design on the intended purpose of single channel flying, with the mentioned fuel mixes and suggested propellers in mind. As long as one doesn't depart severely from those recommendations should have a fine, operating engine. So as far as not having an idle mixture adjustment, as Peter Chin stated in his test report, the fact it lacks it did not deter it from performing well. I've successfully flown 1 to 3 channel sport planes with that engine many times, and it performed well as it should.
_____________________________
George Hostler Clovis MADS AMA Club, Vintage R/C Society (VRCS)
Hide Signatures
