RE: what mixture of fuel do you guys use?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Car Engines >> Car Nitro & Gas Engines >> RE: what mixture of fuel do you guys use? Page: <<   < prev  1 2 [3]
Login
RE: what mixture of fuel do you guys use? - 1/22/2013 3:28 AM
downunder
Score: 123
Last Login: 5/20/2013
Status: offline
quote:
ORIGINAL: supertib
what are you guys running ? RTR small blocks or something ? you obviously don't race 1/8th scale or use any engine resembling a 1/8th race engine
The engine was a Mach 28 in a Hyper 7 as were some of the other competitors.
quote:
Also have you dyno tested said small engines ? do you have facts to backup your claims of them being the most powerful ?
Here's an ad for an off-the-shelf engine of the type I said were the most powerful. A .21 equivalent would need to be making roughly 3.2HP to match it. World class engines of this type develop around 2.5-2.7HP but they aren't an off-the-shelf being specially set up for perfection. A good production engine will set you back around $1000.
If you want to see one being used to set a world speed record then have a look here.
Hide Signatures
(in reply to supertib)
       Post #: 51
RE: what mixture of fuel do you guys use? - 1/22/2013 4:22 AM
bikeordie092
Score: 100
Last Login: 2/2/2013
Status: offline
holy crap, that is awesome! that motor is absolutely SCREAMING!
Hide Signatures
(in reply to downunder)
       Post #: 52
RE: what mixture of fuel do you guys use? - 1/22/2013 6:57 AM
supertib
Score: 302
Status: offline
quote:
ORIGINAL: downunder
quote:
ORIGINAL: supertib
I would love to dyno a couple of those engines just to see for myself what kind of juice they have and how they compare to my race .21's, I am always skeptical of any power claims not backed by actual dyno tests with known references I can relate too..... I have a feeling our modern race .21's on 30% are far more powerful then you realize.....
_____________________________
Neal Smith..owner Clockwork Racing Engines
Hide Signatures
       Post #: 53
RE: what mixture of fuel do you guys use? - 1/22/2013 7:03 AM
supertib
Score: 302
Status: offline
quote:
ORIGINAL: Nitrovein
quote:
ORIGINAL: supertib
quote:
ORIGINAL: Nitrovein
quote:
ORIGINAL: supertib
40 years ago they ran chainsaws with 5 to1 oil mix...now they run 100 to 1 oil mix...go figure...
That has nothing to do about oil, it was just that they kept getting lost in the woods due to fog!
All jokes aside, many things has gotten better over the years, oil, metal, design and so on. It´s just the users that´s left behind in yesterday sometimes...
Plenty has to do with application... I run modified 1/8th race engines in high stress race environments....
True, the everyday basher that´s not running high end mills and pushing it to the limit can be plenty happy with a slightly greasier fuel.
But running the extremely high oil content fuel is not helping the beginner either... So when they get that as a recommendation from the LHS it´s not helping the newcomer...
the worst advice a hobby store can give a newcomer to the hobby is to tell them to run some high oil content swill like Sidewinder's backyard basher................. it will do far more harm to the engine then if they recommended a low oil fuel like Werks..........It just chokes at how bad the old school information was and how bad it messes with people success in the hobby...The tuning difference between Werks and Backyard Basher is ridiculous.....a high end race engine will be nearly impossible to even run on a 16% oil swill..........
Just thinking here...on a no nitro fuel I guess they need to run a much higher oil content as they just can't pump the volume of liquid thru the engine that we can with 30%............... We have tested 30% nitro with as low as 4.5% oil and had excellent results ......Very shortly we are going to test an even lower oil content...in the range of 2% oil..........But I should say we have some very high grade oils that you normally don't see in the industry...
Hide Signatures
(in reply to Nitrovein)
       Post #: 54
fgdsfg
Score: 100
Last Login: 1/25/2013
Status: offline
it seems that your experience would help me.would try ,thanks.
Robust Buys
Toys and Hobbies , Radio Control Toys , RC Heli
Hide Signatures
(in reply to Argess)
       Post #: 55
RE: what mixture of fuel do you guys use? - 1/22/2013 10:23 AM
1QwkSport2.5r
Score: 155
Last Login: 5/21/2013
Status: offline
quote:
ORIGINAL: supertib
quote:
ORIGINAL: downunder
quote:
ORIGINAL: supertib
Taking tachometer readings from the engine and using that data along with air temp, fuel, prop design/load, etc into a prop power calculator will give you real world HP numbers. Without the prop on it, the aircraft engines would overheat quickly. These engines could be ran on less oil if they weren't loaded all the time with the prop.
My little barstock .35 will turn 21,000rpm on the break in prop easily, but I'm sure it would go 45,000+ with less load and enjoy it. Most "sport" engines will turn the same prop in the 17,000rpm area, and this is on 15% nitro and 20% oil! Beyond 15-20% nitro is blown glow plug territory without a set of head shims.
Here is a link to the prop power calculator: http://mvvs.nl/prop-power-calculator.xls
It's in Excel format. This is the closest you'll get to a dyno for an aircraft engine.
*Real* glow fuel is made with Methanol, Nitromethane, and Castor oil.
Hide Signatures
       Post #: 56
RE: what mixture of fuel do you guys use? - 1/22/2013 1:20 PM
Nitrovein
Score: 100
Status: offline
quote:
ORIGINAL: supertib
quote:
ORIGINAL: Nitrovein
quote:
ORIGINAL: supertib
quote:
ORIGINAL: Nitrovein
quote:
ORIGINAL: supertib
My own approach to mixing fuels was to (in a subjective manner) look at; Spool-time ( low load response), Torque (spool without ability to pull is useless), rpm (sort of comes by it self if the engine can spool quickly and not misfiring), tune-ability (there should be no significant difference between low and high temp span), knocking/pinging should not occur (often result from burning oil) and when that is tested I let it idle until there is no more fuel and look at whats left in the crankcase. There are more things I listen and look for, but the main things I looked for are what I listed above.
When there is less oil and a near 100% tune you put a completely different load on the oil during combustion, so some oil will burn without interference and some will interfere.
I made a couple of mixes that worked well in the range between 10.5-11%, they were not as crisp, but would work well for buggy in lower range of racing.
I have seen a couple of RTR engine ruined due to low oil, the poor fitment of parts would develop air leaks as the oil couldn't seal properly. One could argue for days if it was the fuel or the engine that was to blame...
So if I were to blend fuel to a RTR engine, I would use the most oil that´s possible without getting to bad behavior as in difficult tuning and high temp etc, my Guess is 10-12%... (depending on oil used and owner using it)
I think you're on to something there supertib, I have been thinking about what different fuel will do to pumping also. Air is compressible, fluid not so much...
As long as the engine is "on pipe" i doubt there is much difference, but it might affect how the engine picks up...
It sort of gets to a "flow vs pressure" thing... Just thinking out loud...
Hide Signatures
       Post #: 57
RE: what mixture of fuel do you guys use? - 1/22/2013 1:38 PM
supertib
Score: 302
Status: offline
quote:
ORIGINAL: 1QwkSport2.5r
quote:
ORIGINAL: supertib
quote:
ORIGINAL: downunder
quote:
ORIGINAL: supertib
My little barstock .35 will turn 21,000rpm on the break in prop easily, but I'm sure it would go 45,000+ with less load and enjoy it. Most ''sport'' engines will turn the same prop in the 17,000rpm area, and this is on 15% nitro and 20% oil! Beyond 15-20% nitro is blown glow plug territory without a set of head shims.
I can dyno a aircraft engine no issue.....I don't use any cooling on my dyno and often times have the wrap the engine......
in the past I tried using props for calculating power but found it very limited on what it could show.......so after messing wit pops for a bit I decided to build a real dyno and the rest is history
Hide Signatures
(in reply to 1QwkSport2.5r)
       Post #: 58
RE: what mixture of fuel do you guys use? - 1/22/2013 3:55 PM
1QwkSport2.5r
Score: 155
Status: offline
Is there an industry standard as to how a R/C glow engine dynamometer determines its data? I mean, will your dyno give the same numbers (with climate taken into account) as someone else's? Last I checked, there was no standard for measuring power output of engines this small.... I am not beating you up just so you know. I'm just asking the question.
Hide Signatures
       Post #: 59
RE: what mixture of fuel do you guys use? - 1/22/2013 5:38 PM
bikeordie092
Score: 100
Status: offline
i am new in the hobby, but with every engine i read specs on, the power readings are all in horsepower so i would assume his dyno is reading in hp just like the rest....
Hide Signatures
       Post #: 60
RE: what mixture of fuel do you guys use? - 1/22/2013 8:32 PM
supertib
Score: 302
Status: offline
There is a standardized measure of what a horsepower is....However it would be nearly impossible to create a standardized dyno that would be accurate for all engine in all applications..........especially so for 2 stroke engines running tuned pipes......... You see the power a engine creates is very dependent on the load that is placed upon the engine.....To a certain point the power the engine produces will increase as the load placed upon it increases...So the more we load the engine the more power it will generate....Sort of like covering the top of a pop bottle with your thumb and then shaking the bottle, the longer you hold your thumb over the opening the more pressure is built up inside....... The power these engines produce is directly related to the pressure that is generated inside the combustion chamber....back load the engine and it can produce more pressure in the chamber then if it isn't loaded....... So this brings up some very big challenges when it comes to building a dyno......For a dyno to give any relevant information it has to replicate the load that will be placed upon it during its service life..... Not only do we have to replicate the load, we also have to replicate the spool rate...As in the rate the engine would accelerate during its service life....... So if a car took 5 seconds to go from idle to peak RPM the dyno needs to replicate a load that will take the engine 5 seconds to go from idle to peak RPM...........Now for aircraft the spool rate is much less of a concern, but for cars it is extremely critical for the dyno's spool rate to match the spool rate the engine will see in its service life..........Aircraft engines usually operate against a such a load that the engine is working against a dead stall usually at a near fixxed RPM........... So for testing aircraft engines we would want to use a brake style dyno that could could stall out a engine and give us the ability to measure the force it creates, by contrast for a car engine we would want to use a inertial dyno that can match the spool rate the engine would see during its service life........... typically speaking a engine will make more power working against a dead stall then it will during a spool up.......the dead stall load gives the engine more to work against.....So even tho the measure of a horsepower is clearly defined , how we measure and test that horsepower can give us very different readings........Dyno's really are a tuning tool and not always and absolute measure.... Only results from the same dyno system should be compared to each other.....As the mechanical involve can greatly affect the readings we see....especially so with inertial dynoes......
Hide Signatures
       Post #: 61
RE: what mixture of fuel do you guys use? - 1/23/2013 12:05 AM
1QwkSport2.5r
Score: 155
Status: offline
quote:
ORIGINAL: supertib
Well said. Thanks for the explanation.
I know there is a standard measure of horsepower, but as to how it would apply to something running in the ounce-inch scale as opposed to pound-feet scale is what I was concerned with. I've ran an engine here in Minnesota that netted 1,000-1,500rpm less than the original owner got with it in California. Turns out nearly 1,000 feet above sea level needs extra nitro.
I wouldnt mind comparing power numbers between a dyno and the prop-power calculator. In the aircraft community, nobody cares about how much horsepower the engine makes but the rpm it turns a given prop at. Of course one can extrapolate how much horsepower the engine makes with a +/- allowance.
Hide Signatures
       Post #: 62
RE: what mixture of fuel do you guys use? - 1/23/2013 12:37 AM
Nitrovein
Score: 100
Status: offline
Great reply supetib!
I know that some uses data log from on-road testing and program the dyno to replicate that, so they can run each gear on the dyno for development and testing. But this is full scale!
But it´s cool to see how the same engine would do on different cars etc...
As I have a couple of thousand hours my self on dyno runs I know that static rpm braking is a killer for most engines, kind of like running a boat.
Do you (supertib) think it´s possible do subject a car engine to say.. 40.000 rpm under sustained braking? I understand that is a rather vague question, if no one has actually tested it, but what´s your thought...
And I do agree that it would be fun to see what a airplane engine is actually putting out, might give some insight to how accurate a prop reading is.
Hide Signatures
       Post #: 63
RE: what mixture of fuel do you guys use? - 1/23/2013 1:33 AM
supertib
Score: 302
Status: offline
I am actually working on building another dyno...this time I want to add transducers that can data log the engines systolic cycle during operation....... I feel with that data I can better develop the engines efficiency...But right now it is only a theory.......... A few years back I had read an article about a Speedline guy from Germany who had built such a device to read the systolic cycle of the engines during operation...... I Am also looking to setup a very accurate RPM scales that will allow me to see the engines accelerations thru its rotational cycle..I believe I can better develop the balance of the engines with this data....Seeing how it accelerates and decelerates thru its rotational cycle would be quite interesting....................
Hide Signatures
       Post #: 64
RE: what mixture of fuel do you guys use? - 1/23/2013 6:28 AM
bikeordie092
Score: 100
Status: offline
Ok.. I may be off-topic again, but what generally makes a glow plug go bad? I got a hotter plug and it went bad within about 10 minutes or less, I switched back to the other plug I had, which was a mid range plug but had also been previously used and probably on its way out anyways, and it quit as well... should I go to a "cold" plug?
The only thing that has changed on the car is that I put a new pipe and yesterday I switched the fuel from 20%/14% to 30%/11%. Is there anything I did that would have made this happen?
Hide Signatures
       Post #: 65
RE: what mixture of fuel do you guys use? - 1/23/2013 7:41 AM
downunder
Score: 123
Status: offline
quote:
ORIGINAL: supertib
This was done on an engine back in 1979 by a modeller called Scott Bair who did it as an engineering project at his university. His project actually was just to determine (via a pressure transducer) what the actual pressures on the piston were when an engine was in 4 cycling mode. A fellow modeller (an actual rocket scientist, believe it or not ) then took his pressure and crank rotation figures and converted them to a graph which showed torque at all periods of crankshaft rotation. These calculations of course had to take into account both rod length and rod angularity. Peak torque is amazingly high when compared to the average torque which is the figure always quoted for all engines. You can see the torque graph here which I've just put up on my web page.
The next thing that was done was to determine the angular momentum of the prop used and when this was combined with the torque figures it gave a graph of the change in revs of the prop for all angles of crank rotation.
Hide Signatures
       Post #: 66
RE: what mixture of fuel do you guys use? - 1/23/2013 8:44 AM
Nitrovein
Score: 100
Status: offline
quote:
ORIGINAL: supertib
This gets me thinking on Moto-GP, when they changed from "screamers" to "big-bang" engines. They most likely did a whole lot of research that´s available today.
I have been looking for some other devices for doing testing in car, like getting good readings on crankcase pressure/vacuum during operation.
But I´m having trouble finding anything good enough for that high cycling rate, while not breaking the bank...
Many of the old test regarding delivery ratio might be worth testing again in CFD, well that my idea... Not that it has anything to do with dyno or fuel...
Hide Signatures
       Post #: 67
RE: what mixture of fuel do you guys use? - 1/23/2013 1:35 PM
supertib
Score: 302
Status: offline
quote:
ORIGINAL: downunder
quote:
ORIGINAL: supertib
thanks for that info...I have been unable to track that down........gotta love how how high the instantaneous torque is......its like we are running tiny impact drivers.....
Hide Signatures
       Post #: 68
RE: what mixture of fuel do you guys use? - 1/23/2013 6:08 PM
Anthoop
Score: 121
Status: offline
quote:
ORIGINAL: bikeordie092
Ok.. I may be off-topic again, but what generally makes a glow plug go bad? I got a hotter plug and it went bad within about 10 minutes or less, I switched back to the other plug I had, which was a mid range plug but had also been previously used and probably on its way out anyways, and it quit as well... should I go to a ''cold'' plug?
A lean mixture will blow plugs, did you adjust the needles when you changed fuel? Compression ratio too high will also blow plugs, is the engine capable of running 30% without alteration? Also wear in the rod/crank pin will blow plugs.
A hotter plug has a thinner wire so is more susceptable to damage if used incorrectly...but that is not to say you should use a cold plug. Use the correct plug for your engine/conditions/fuel. Here is a general plug guide- http://www.osengines.com/glowplugs/index.html
When I die, I want to go in my sleep like my grandfather,not screaming
like the passengers in his car at the time.
Hide Signatures
(in reply to bikeordie092)
       Post #: 69
RE: what mixture of fuel do you guys use? - 1/24/2013 4:39 AM
bikeordie092
Score: 100
Status: offline
Yeah, actually the idle was a little too rich... I switched to a cooler plug and adjusted adequately, and now to motor runs much better than it ever has, at least in the time I've had it. Runs right around 225-230°f and idles smoothly with a crisp throttle response, not to mention its pretty quick, plan on really getting to open it up tomorrow at my buddys house... that's if I can find a set screw for the front d-cup since the one that was in there rattled out while I was messing around earlier.
P.S.- I am running byrons 30%nitro/11%lubrication fuel.. the car runs much better on it than the "black ops" fuel I had been running that was 20%nitro/14%lubrication.
Hide Signatures
(in reply to Anthoop)
       Post #: 70
RE: what mixture of fuel do you guys use? - 1/24/2013 5:07 AM
JoeMaxx
Score: 105
Last Login: 5/17/2013
Status: offline
http://www.rcuniverse.com/magazine/article_display.cfm?article_id=284
We can always revert back to this
I live in a High Altitude region of the country Rocky Mountains and it really does not matter what manufacure fuel I am running tuning is almost daily thing but  the air temps vary mostly in the spring and fall.   Summer time I can almost run the same tune between the weekends I go out to play and way up here it is almost aways means a richer fuel mix because to the lack of oxygen.   When the temps drop or rise I have sometimes had to make a 1/2 turn in my adjustments to the fuel air mix.    I use a temp guage as a reference point only because I do not want my engines to over heat.    Like to run an engine between 220 to 260 degrees and feel out the sound and smoke trail in between these temp ranges.   I fry glow plugs if it hits 300 degrees in most cases from past experience.
I have found in my area the higher oil content fuels keep the engines cooler where I live.   This is not the same everywhere. When I lived in Georgia I used to love Byron Fuels and of course the Trinity Monster HP.
I started out running Trinity Monster HP Fuel 30 % when I first moved out here 8 years ago and they do not sell it anymore from what I can tell because I cannot find it on the shelf anymore.   It was my favorite fuel.  I used a few others up here like SideWinder and my engines just ran too hot because they had less oil content or less Castor oils.
I tried other fuels and my LHS only carries two fuel blends Traxxas Top Fuel and  Losi Nitrotane these days.   They used to carry all kinds of different fuels and it would change all the time now they standerized on what they have on the shelf.    I am going to try the Losi Nitrotane this spring to see how it runs.
I do not see much of a performance difference between 20% and 30% nitro and recently dropped down to 20 % nitro because the fuel prices were a huge difference almost $10.00 per gallon.
I always have run Medium heat plugs and that is a totally different discussion but you can read this link if your interested found it a very good read.
http://www.oneten.co.za/showthread.php?1381-For-the-nitro-guys-Glow-plugs-explained
< Message edited by JoeMaxx -- 1/24/2013 5:30 AM >
Revo, TMaxx, HPI Trophy, RC10T4SE, RC10B4SE, RC10GT2, MTX-3, TC4, RC10T3, Grasshopper, JR, Spektrum
Hide Signatures
(in reply to HerrSavage)
       Post #: 71
Jump to:
Google
SITE MAP!   : :   FORUM RULES
2.266RCU1
