PAW 06 fuel draw question    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Everything Diesel >> PAW 06 fuel draw question
Page: [1]
Login
PAW 06 fuel draw question - 1/20/2013 9:08 PM
AMB
Score: 110
Last Login: 5/19/2013
Status: offline
OK group Have started the Polk tiger moth with the PAW 06, really cannot pressurize the tank with a fitting on the muffler such as other engines
Do you think the PAW will have a problem if fuel pickup in tank 3/4" below carb center
If has to go up will require quite a bit of work to modify fus. to do this, to get tank higher if we do we do but would like to avoid martin
Hide Signatures
       Post #: 1
RE: PAW 06 fuel draw question - 1/20/2013 9:24 PM
AMB
Score: 110
Status: offline
I may just put the engine back on the bench lower the tank 3/4" and see what happens just thought of this martin
Hide Signatures
(in reply to AMB)
       Post #: 2
RE: PAW 06 fuel draw question - 1/20/2013 9:42 PM
Mr Cox
Score: 102
Status: offline
It should be fine, low end might get a little lean at the end of a run but diesels don't stop as easily as glow engines do.
Hide Signatures
(in reply to AMB)
       Post #: 3
RE: PAW 06 fuel draw question - 1/20/2013 10:09 PM
AMB
Score: 110
Status: offline
Mr Cox THX to get the tank higher would have to do a total rebuild front of the plane cut off the whole top forward of the windscreen to firewall and its glued over a piece of curved foam
martin
A 2oz tank for an 06 is big, would most likely fly off only about 1/2 before landing and refueling
Hide Signatures
(in reply to Mr Cox)
       Post #: 4
RE: PAW 06 fuel draw question - 1/20/2013 10:23 PM
greggles47
Score: 100
Status: offline
Martin,
What about an external FF style tank.
Dave Owen lists them, sorry I can't extract the pic but here's the link. http://oea.modelenginenews.org/pricelist_2011-04.pdf
Greg
Hide Signatures
(in reply to AMB)
       Post #: 5
RE: PAW 06 fuel draw question - 1/20/2013 10:59 PM
AMB
Score: 110
Status: offline
Greg that is a thought a couple of rubber bands and I would be in biz martin
Hide Signatures
(in reply to greggles47)
       Post #: 6
RE: PAW 06 fuel draw question - 1/20/2013 11:21 PM
Recycled Flyer
Score: 101
Last Login: 5/17/2013
Status: offline
Here you go Greg.
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 7
RE: PAW 06 fuel draw question - 1/20/2013 11:27 PM
Recycled Flyer
Score: 101
Status: offline
quote:
ORIGINAL: AMB
Martin,
from the PAW web site-
"Fuel level in tank during starting procedure MUST NOT BE HIGHER than in the same horizontal plane as jet. A little lower (up to 1cm) is alright. "
As to pressuring the fuel tank have you looked at crankcase pressure? Perhaps the back plate is thick enough to accept a pressure nipple.
P.S. just looking at your other post on this it would seem that you have quite a bit of tank space behind the engine on the radial mount .
Hide Signatures
(in reply to AMB)
       Post #: 8
RE: PAW 06 fuel draw question - 1/20/2013 11:58 PM
AMB
Score: 110
Status: offline
Greg pulled backplate very thin a no go on that one, one other thought smaller tank, whats the approx run time on the PAW 06 on one oz fuel martin
guess at least 10 minutes at around 10K
guess I could go to the source and call PAW
Hide Signatures
(in reply to Recycled Flyer)
       Post #: 9
RE: PAW 06 fuel draw question - 1/21/2013 12:13 AM
fiery
Score: 100
Status: offline
One of these would make a nice tank ... if the bung can take diesel fuel
www.ebay.com/itm/390403868791?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Hide Signatures
(in reply to AMB)
       Post #: 10
RE: PAW 06 fuel draw question - 1/21/2013 12:39 AM
AMB
Score: 110
Status: offline
OK Hayes does make a 1 oz round tank #s 077 ok fro diesel of course as is martin
whoops header tank will it work on its own??
it should orient so tubes are vertical bottom plugged anyhow , center draw on clunk line upper vent just lead higher than tank (vent ine)
Fiery cheap too only $4 the E bay one twice the price THX for the search and check
< Message edited by AMB -- 1/21/2013 1:46 AM >
Hide Signatures
(in reply to AMB)
       Post #: 11
RE: PAW 06 fuel draw question - 1/21/2013 1:45 AM
steve111
Score: 100
Status: offline
For what it's worth, I had one in a little CL stunter. It would still draw quite ok with the nose pointed straight up, and the pickup a good 2 1/2 or 3 inches below the level of the spraybar.
Hide Signatures
(in reply to AMB)
       Post #: 12
RE: PAW 06 fuel draw question - 1/21/2013 1:48 AM
AMB
Score: 110
Status: offline
Steve THX you just relieved my anxiety on this one martin
I really did not want to do a hack thing on the moth plenty of room for the 2 ouncer just need a little opening up on the bulkhead wit dremel and drum sander on it
Hide Signatures
(in reply to steve111)
       Post #: 13
RE: PAW 06 fuel draw question - 1/21/2013 3:08 AM
Recycled Flyer
Score: 101
Status: offline
Steve,
         what was the inverted stunt run like with the spray bar now 2 1/2 inches below the fuel feed pipe?
Hide Signatures
(in reply to AMB)
       Post #: 14
RE: PAW 06 fuel draw question - 1/21/2013 3:29 AM
steve111
Score: 100
Status: offline
Sorry Chris, I think you've misunderstood me. I was referring to when the nose was pointing straight up. Inverted, the pickup is naturally level with the spraybar again.
Hide Signatures
       Post #: 15
RE: PAW 06 fuel draw question - 1/21/2013 3:30 AM
Recycled Flyer
Score: 101
Status: offline
Gottcha! Thanks.
Hide Signatures
       Post #: 16
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Everything Diesel >> PAW 06 fuel draw question
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.516RCU1
