Pro Boats 1/8 scale Miss Budweiser    Gallery
Logged in as Guest
    Search This Thread
Printable Version
More Resources on the
Miss Bud 1/8 Scale
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • All Forums >> RC Boats >> Speed - RC Gas Boats >> Pro Boats 1/8 scale Miss Budweiser
    Page: [1]
    Login
    Pro Boats 1/8 scale Miss Budweiser - 1/20/2013 10:41 PM
    jdmartin
    Score: 100
    Last Login: 3/23/2013
    Status: offline
    I just picked up a mint PB 1/8 Gas Hydro from my LHS,  minus the motor and drive system.  I want to build this boat up and present it to my grandson for his birthday.  Obviously no problem locating a new Zenoah G26PUM motor,  but I'm striking out trying to locate the flex drive system  (part number PRB2265 and the collet PRB2263.
    Does anyone here have any ideas as to where I might be able to locate one?  Ebay searches are futile,  as well as numerous online parts houses.
    Thank you...
    Jim
    Hide Signatures
           Post #: 1
    RE: Pro Boats 1/8 scale Miss Budweiser - 1/21/2013 4:24 AM
    Hydro Junkie
    Score: 121
    Last Login: 6/18/2013
    Status: offline
    Aeromarine Laminates would have the parts you need. While they're not Pro Boat parts per se, you just have to cut the cable to length The website is down at the moment for maintenance, but when it comes up, here is the address:
    http://www.aeromarinerc.com
    Hide Signatures
    (in reply to jdmartin)
           Post #: 2
    RE: Pro Boats 1/8 scale Miss Budweiser - 1/21/2013 12:05 PM
    jdmartin
    Score: 100
    Status: offline
    Thank you very much for the reply.  I had tried their site a few days ago,  and noticed it was down at that time also.
    Sure hope the maintenance outage doesn't last too long!
    Hide Signatures
    (in reply to Hydro Junkie)
           Post #: 3
    RE: Pro Boats 1/8 scale Miss Budweiser - 1/22/2013 3:24 AM
    tapkoote
    Score: 122
    Last Login: 6/16/2013
    Status: offline
    WareHouse Hobbies has cables and hardware also
    http://www.whobbies.com/
    Hide Signatures
           Post #: 4
    RE: Pro Boats 1/8 scale Miss Budweiser - 1/22/2013 4:22 AM
    Ron Olson
    Score: 1175
    Last Login: 6/17/2013
    Status: offline
    Just don't buy the Zenoah from ProBoat as you can get it a lot cheaper elsewhere. www.gizmomotors.com has one of the best prices around for one. He also carries everything else that you may need.
    _____________________________
    Member, Southwest Michigan Model Boat Club and the IMPBA.
    269 Racing Team
    Hide Signatures
    (in reply to tapkoote)
           Post #: 5
    RE: Pro Boats 1/8 scale Miss Budweiser - 1/22/2013 7:17 PM
    jdmartin
    Score: 100
    Status: offline
    Thank you VERY much for the links and replies.  Do any of you know what the size is of the stock flex cable?  Is it a 1/4" square on both ends or just one,  and what is the total overall length?
    It appears that I can get a custom cable manufactured by Enforcer Direct,  but I can't find any info on the original flex cable....
    As always,  any info at all is greatly appreciated...
    Jim
    Hide Signatures
    (in reply to Ron Olson)
           Post #: 6
    RE: Pro Boats 1/8 scale Miss Budweiser - 1/23/2013 4:21 AM
    TheFridge189
    Score: 100
    Last Login: 5/2/2013
    Status: offline
    It depends on what motor you end up going with. The original Zenoah with a clutch had a square end and a round ferrule. I'm not sure about the non-clutched model. Here is a link, not sure if it's the correct length. If all the gasser proboats have the same length then this is what you want if you end up going with the orignal clutch:
    www.bonzisports.com/store/product_info.php
    Hide Signatures
           Post #: 7
    RE: Pro Boats 1/8 scale Miss Budweiser - 1/23/2013 7:34 AM
    stevo7896
    Score: 105
    Last Login: 5/12/2013
    Status: offline
    That's going to be a great gift for your grandson.You both will have a blast. If you order stock parts ,it going to be designed for the clutch installed.I would strongly advise to do without the clutch .Its still easy to bring it in without a clutch and it will perform much better. When ordering parts from gizmos ,wharehouse hobbies or zippkits, three great suppliers, call them and they should be able to get what you need .Its a fun starter boat and looks great out on the water. Stephen
    Hide Signatures
    (in reply to TheFridge189)
           Post #: 8
    RE: Pro Boats 1/8 scale Miss Budweiser - 1/23/2013 12:40 PM
    jdmartin
    Score: 100
    Status: offline
    Thank you Fridge and Stevo.....another great link for parts that will work on this boat.
    Fridge,  the original 1/8 Miss Budweiser did not come with a clutch.  I know there was a clutch on the later 1/8 Formula,  and possibly the Elam and Llumar,  but not the Bud.  That's a great link you posted,  so thanks again.
    Stevo,  yes, the grandson is going to be shocked when he realizes that Granpa actually bought  this boat for him !!  Can't wait to see the expression on his face...
    Jim
    Hide Signatures
    (in reply to stevo7896)
           Post #: 9
    RE: Pro Boats 1/8 scale Miss Budweiser - 4/2/2013 4:11 AM
    redjeep
    Score: 100
    Status: offline
    Do you have the manuals for the boat? And is there ant chance of getting a copy?
    Jjohn
    Hide Signatures
           Post #: 10
    RE: Pro Boats 1/8 scale Miss Budweiser - 4/2/2013 10:52 AM
    Hydro Junkie
    Score: 121
    Status: offline
    In all honesty, you can get better help here than you can with the manual as several of the people here have knowledge of your boat or with building and running scale hydros themselves.
    Hide Signatures
    (in reply to redjeep)
           Post #: 11
    Page:   [1]
    Page: [1]
    Miss Bud 1/8 Scale
  • See User Ratings
  • Jump to:
    Google
    SITE MAP!   : :   FORUM RULES
    0.313RCU1
