Gemini GT-40 build    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Twin & Multi Engine RC Aircraft >> Gemini GT-40 build
Page: [1]
Login
Gemini GT-40 build - 1/22/2013 3:36 AM
jim19
Score: 100
Last Login: 6/13/2013
Status: offline
I am in the process of building a Gemini GT-40 and decided to post a thread on the construction of this model. The one being built will be powered by 2 OS .45 engines and will be using SpringAir retracts. First pic shows the layout of the basic fuselage components with doublers glued to the fuselage sides and bulkheads. Pic 2 shows the fuselage assembly beginning with the main bulkheads epoxied in and the wing mounts installed (fuselage has been taken off jig for theses pics). Pic 3 shows the remaining bulkheads, stabilizer saddle and nosegear mount installed. Pic 4 shows the fuselage top sheet installed. Pic 5 shows the elevator and rudder pushrod outer tubes installed. Pic 6 shows the aft fuselage bottom sheeting, forward fuselage sheeting and nose block installed.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 1
RE: Gemini GT-40 build - 1/23/2013 12:04 AM
jim19
Score: 100
Status: offline
Pic 1 shows the basic wing components. doublers are glued to the nacelles and wing ribs as required. Pic 2 shows the wing structurally built and taken off the jig. This wing is built in three sections. Center section is ready to align to the fuselage. Pic 3 shows the flag jigs in place with the airframe side flap hinges epoxied in place. Pic 4 shows the main gear mount installed and the cutouts for the wheel well. Pic 5 shows the inner sheeting installed for shaping the wheel well. Rib is also cutout for serrvo installation and lower cap strips installed.
Hide Signatures
(in reply to jim19)
       Post #: 2
RE: Gemini GT-40 build - 1/23/2013 12:08 AM
jim19
Score: 100
Status: offline
Don't know why the pics didn't show up in the last post, but here they are.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to jim19)
       Post #: 3
RE: Gemini GT-40 build - 1/24/2013 4:17 AM
jim19
Score: 100
Status: offline
Pic 1 shows whell well lining (1/16" balsa) installed and bottom of wing sheeted. Pic 2 shows forward nacelle top installed and top of wing sheeted. Pic 3 shows tank and servo access cover in place and botom aft nacelle assembled. Pic 4 shows top aft nacelle assembled.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to jim19)
       Post #: 4
RE: Gemini GT-40 build - 1/24/2013 4:19 AM
jim19
Score: 100
Status: offline
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to jim19)
       Post #: 5
RE: Gemini GT-40 build - 1/25/2013 4:26 AM
jim19
Score: 100
Status: offline
Pic 1 shows aileron hinged (not glued in) and set in place. Pic 2 shows flap guide wire in place and surface side flap hinges in place. Guide wire aligns these hinges. Pic 3 shows flap set in place and hinges epoxied in flap. Pic 4 shows wingtip installed.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to jim19)
       Post #: 6
RE: Gemini GT-40 build - 1/26/2013 10:23 PM
jim19
Score: 100
Status: offline
Simple cowling assembly. Pic 1 shows cowl mounts installed and engine temp mounted. Spinner backplate is tack glued to spinner ring using 3/32" balsa spacers. Pic 2 shows cowl side attached to nacelle and glued to spinner ring. Pic 3 shows cowl top and bottom attached to cowl and glued to spinner ring and cowl side. Once glue has cured, spinner backplate and engine are removed. Pic 4 shows balsa triangle fillers in place. Pic 5 shows cowl sanded to shape.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to jim19)
       Post #: 7
RE: Gemini GT-40 build - 1/30/2013 10:16 PM
jim19
Score: 100
Status: offline
Pic 1 shows wing center section in place on the fuselage, forward wing pegs and wing mount bolts installed. Pic 2 show bottom sheeting installed and wing bolt holes counterbored for recessed bolts. Pic 3 shows center section top sheeting installed and cut out for flap servo and servo wiring. Pic 4 shows main turtledeck bulkheads and turtledeck sides glued in. Pic 5 shows remaining bulkheads glued in and side pulled together for proper contour. Pic 6 show turtledeck top sheeting installed.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to jim19)
       Post #: 8
RE: Gemini GT-40 build - 1/30/2013 10:20 PM
jim19
Score: 100
Status: offline
Pic 1 shows empennage assembly assembled, rudder and elevators sanded to taper at trailing edge. Hinges are in place but not glued in. Pic 2 shows ventral fin installed. Pic 3 shows empennage set in place for check fit. Model is now ready for filler (light-weight spackiling compound) where needed and final sand, then covering.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to jim19)
       Post #: 9
RE: Gemini GT-40 build - 1/31/2013 3:07 AM
hoops
Score: 100
Last Login: 6/6/2013
Status: offline
Jim, you make it all look so simple and straight forward.
Nice work.
Hide Signatures
(in reply to jim19)
       Post #: 10
RE: Gemini GT-40 build - 2/4/2013 11:34 PM
jim19
Score: 100
Status: offline
This Gemini GT-40 is finished. Model is assembled, engines, retracts and radio installed.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to hoops)
       Post #: 11
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.422RCU1
