3GX FBL rudder problem    Gallery
Logged in as Guest
    Search This Thread
Printable Version
More Resources on the
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • All Forums >> RC Helicopters >> Electric RC Helis >> T-Rex heli >> 3GX FBL rudder problem
    Page: [1]
    Login
    3GX FBL rudder problem - 1/22/2013 6:34 PM
    wcfung
    Score: 100
    Last Login: 4/26/2013
    Status: offline
    I have had my 450 Trex Pro FBL for over 9 months. It has been flying without problem until recently, upon lifting off the ground, the heli drifted quickly to one side, so I cut off the throllte quickly and stripped the TT front drive gear. After replacing the stripped gear, and resetting the 3GX rudder gyro, I test flew and found that the heli just rotated without rudder and not lifting off.
    I then reset the 3GX rudder gyro again, but nothing changed.
    Can anyone help ? If it is the static discharge resetting the 3GX, it should be alright after the 2nd time I reset the 3GX. But it is not the case.
    I think the rudder gyro function during spooling up is built -in, whether you reset the rudder gyro part or not does not affect this function. Setting the rudder gyro only determines the rudder servo direction, gyro normal/reverse setting, rudder servo end point setting etc.
    Is the 3GX rudder gyro part malfunction ?
    Hide Signatures
           Post #: 1
    Page:   [1]
    Page: [1]
  • See User Ratings
  • Jump to:
    Google
    SITE MAP!   : :   FORUM RULES
    0.359RCU1
