Tamjet pipe    Gallery
Logged in as Guest
    Search This Thread
Printable Version
MBA Tornado V3
Seller:  Modellbau USA
Details:   $380.00   |  5/11/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> Tamjet pipe
Page: [1] 2   next >   >>
Login
Tamjet pipe - 1/22/2013 8:31 PM
tich
Score: 100
Last Login: 5/20/2013
Status: offline
Hi Guys
I have just brought an unused Tamjet bifurcated pipe but there's a problem with it. It got slightly damaged in transit and the thin brown sealant , which I am assuming is original, has separated from the pipe and needs replacing. Can anyone tell me what this stuff is and where I can get some in the UK?
Hide Signatures
       Post #: 1
RE: Tamjet pipe - 1/23/2013 12:21 AM
Joe Westrich
Score: 105
Last Login: 5/22/2013
Status: offline
I have two of Tams bifurcated pipes and I don't see any brown sealant. Can you tell us where the sealant is?
_____________________________
Cincinnati Jet Club
Hide Signatures
(in reply to tich)
       Post #: 2
RE: Tamjet pipe - 1/23/2013 6:20 AM
jedijingle
Score: 100
Status: offline
How about some good pictures.
Duct tape is like the force, It has light side and it has a dark side, and it binds the universe together.
Hide Signatures
(in reply to Joe Westrich)
       Post #: 3
RE: Tamjet pipe - 1/23/2013 8:30 AM
tich
Score: 100
Status: offline
Pictures One shows where the bifurcation has come slightly undone- possibly a broken spot weld. You can just see where the sealant has gone under the metal. The second one is from outside with the outer pipe removed. As I said I dont know whether the sealant was original. If not then I can take the pipe top a local specialist welder and get the broken weld repaired
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to jedijingle)
       Post #: 4
RE: Tamjet pipe - 1/23/2013 11:08 AM
George
Score: 100
Status: offline
Are you sure that's a Tam pipe?
It looks like someone tried to repair that pipe. The "sealant" is not original! Do you have a shot of the pipe show both inner & outer walls?
George DelMoral
Dreamworks "Mobile" Products LLC
Hide Signatures
(in reply to tich)
       Post #: 5
RE: Tamjet pipe - 1/23/2013 11:39 AM
proline8000
Score: 105
Status: offline
It is high temp RTV: Permatex® High-Temp Red RTV Silicone Gasket
Hide Signatures
(in reply to George)
       Post #: 6
RE: Tamjet pipe - 1/23/2013 12:24 PM
tich
Score: 100
Status: offline
more pictures NB I have now scraped off all the sealant. I am not certain its a Tamjet pipe. I brought it second-hand and it was advertised as a Tamjet one. A couple of the inner spot weld have given way hence someone tried to seal it. I have a specalist welder lined up to weld it.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to proline8000)
       Post #: 7
RE: Tamjet pipe - 1/23/2013 12:57 PM
Randy M.
Score: 100
Status: offline
If you like the plane, get a new pipe.
Silence is golden,,, but duct tape is silver.
Hide Signatures
(in reply to tich)
       Post #: 8
RE: Tamjet pipe - 1/23/2013 1:06 PM
George
Score: 100
Status: offline
If that's a Tam, it must be a VERY VERY early one, because none of his "newer" pipes look like that.
I would be weary to use it!
George DelMoral
Hide Signatures
(in reply to Randy M.)
       Post #: 9
RE: Tamjet pipe - 1/23/2013 1:08 PM
tich
Score: 100
Status: offline
Okay Guys
thanks for the info. I will put the pipe away and save up for a new one! Buy cheap buy twice I guess!
Hide Signatures
       Post #: 10
RE: Tamjet pipe - 1/23/2013 1:51 PM
extra 300
Score: 100
Last Login: 5/21/2013
Status: offline
tich,
For which jet was this pipe meant to be for?
regards,
Hide Signatures
(in reply to tich)
       Post #: 11
RE: Tamjet pipe - 1/23/2013 5:00 PM
CARS II
Score: 110
Status: offline
Nope, not Tam's pipe, the spacer shape between the walls is different.
CARS II
Go fly a Jet today.
Hide Signatures
(in reply to extra 300)
       Post #: 12
RE: Tamjet pipe - 1/23/2013 5:14 PM
tich
Score: 100
Status: offline
The pipe is intended for a YA F18 single running a VT80 turbine.
Hide Signatures
(in reply to CARS II)
       Post #: 13
RE: Tamjet pipe - 1/23/2013 5:25 PM
Ron Stahl
Score: 125
Status: offline
Tich, check your PM from me on an offer to sell you a brand new TAM F-18 pipe at a good price.
I use my real name and am not sponsored by anyone but myself
Hide Signatures
(in reply to tich)
       Post #: 14
RE: Tamjet pipe - 1/23/2013 6:21 PM
tamjets
Score: 100
Status: offline
quote:
ORIGINAL: tich
That just a copy of our pipe.
Please make sure not get other comfuse with our pipe.
Tam Nguyen
Owner TamJets
Hide Signatures
(in reply to tich)
       Post #: 15
RE: Tamjet pipe - 1/23/2013 7:17 PM
YellowAircraft
Score: 181
Status: offline
Tich,
Someone sold you the pipe and represented it as a TJ?
Yellow Aircraft, JetCat Engines and Turn Key Jets
yellowaircraftplanesdotcom
Hide Signatures
(in reply to tamjets)
       Post #: 16
RE: Tamjet pipe - 1/23/2013 7:49 PM
tich
Score: 100
Status: offline
Tam
Thanks for replying. I was told by the seller that the pipe was a Tamjet one but when it arrived I wasn't happy with its condition. Sadly it will be difficult to return it to the sender as I have played with it to check for damage. I appreciate that people will make copies of your pipe and it looks like I got caught this time.
Cheers
Ian
Hide Signatures
(in reply to YellowAircraft)
       Post #: 17
RE: Tamjet pipe - 1/23/2013 8:22 PM
f16man
Score: 106
Status: offline
Did you buy it from someone here on RCU ?????
Hide Signatures
(in reply to tich)
       Post #: 18
RE: Tamjet pipe - 1/23/2013 8:49 PM
tamjets
Score: 100
Status: offline
quote:
ORIGINAL: tich
Tam
Cheers
Ian
Yup it suck someone put our brand name on they use stuffs to sell.
Anyone else come across these use pipe deal in the future. Send me a picture to comfirm.
Tam Nguyen
Owner TamJets
Hide Signatures
(in reply to tich)
       Post #: 19
RE: Tamjet pipe - 1/23/2013 10:10 PM
tich
Score: 100
Status: offline
I brought it in the UK and the I am sure the seller was genuine in believing it to be a "Tamjets" pipe. Its sometimes difficult to determine the origin of parts when they have been passed around a few times. If you buy second-hand sometimes you get caught. If it had been new then my attitude would be different.
Hide Signatures
       Post #: 20
RE: Tamjet pipe - 1/24/2013 1:04 AM
tamjets
Score: 100
Status: offline
LOL....that pipe is not even look close to my first one I built 17 years ago.
Here is what my pipe look like.
Click for fullsize
Click for fullsize
Click for fullsize
Tam Nguyen
Owner TamJets
Hide Signatures
(in reply to tich)
       Post #: 21
RE: Tamjet pipe - 1/24/2013 1:36 AM
George
Score: 100
Status: offline
Yo da' man Tam!!
George DelMoral
Hide Signatures
       Post #: 22
RE: Tamjet pipe - 1/24/2013 6:54 AM
vega406
Score: 100
Status: offline
i have a YA F-18 single with TAMS pipe made to handle P-120 here is a dusty picture of inside and you can see what Quality looks like..Funny thing i hade a guy want to buy this for ducted fan flying and i thought to myself what the heck would i do with this pipe....
Click for fullsize
Click for fullsize
Bill
Hide Signatures
       Post #: 23
RE: Tamjet pipe - 1/24/2013 8:35 AM
tich
Score: 100
Status: offline
Thanks for Tam and Vega for showing us what the pipe should look like. Its clear that Tam's pipes deserve their quality reputation. Its a good job I discovered that my pipe ius a copy. Just imagine the scene were the cheap pipe fails in flight and caused the plane to go in. Its just a shame I needed to buy the pipe but hey I have learnt a very valuable lesson here and in the scheme of things the loss of a hundred quid (160$) for the pipe is worth it for the knowledge I have gained and the fact that model and turbine weren't at risk. Can I say big thank you to all who have chipped in here there have been some very valuable bits of information contributed.
Cheers Guys
Hide Signatures
(in reply to vega406)
       Post #: 24
RE: Tamjet pipe - 1/24/2013 11:02 PM
RAMFlyer
Score: 100
Status: offline
Hey Tam; answer your email so I can get a pipe price!!!  Bill
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.875RCU1
