OS max 52 surpass 4 stroke is this true    Gallery
Logged in as Guest
    Search This Thread
Printable Version
TurboHeader Muffler
Seller:  RC Specialties
Details:   $69.95   |  4/28/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> OS max 52 surpass 4 stroke is this true
Page: [1]
Login
OS max 52 surpass 4 stroke is this true - 1/23/2013 3:59 AM
raron455
Score: 100
Last Login: 5/21/2013
Status: offline
I bought an OS max 52 surpass 4-stroke for my .40 size spitfire I am building, I got a good price, 50.00 It has a prop on it,, I turned it over by hand and noticed there was not much compression at all, on the compression stroke,I hear the valvetrain moving, so I believe it is all working,, The seller told me that the engine will not really have compression until it has fuel in it?? is this true,, I am new to these engines, I bought it he seemed like an honest enough old timer,
Thanks fellas
I also have to mount it inverted, I was told I have to use an onboard glow driver to help prevent flooding and dying at low throttle?
Hide Signatures
       Post #: 1
RE: OS max 52 surpass 4 stroke is this true - 1/23/2013 5:36 AM
noveldoc
Score: 115
Last Login: 2/26/2013
Status: offline
Fuel and warming up will help compression.  Also check the valve settings.
Tom
Hide Signatures
(in reply to raron455)
       Post #: 2
RE: OS max 52 surpass 4 stroke is this true - 1/23/2013 11:06 AM  1 votes
pe reivers
Score: 646
Last Login: 5/20/2013
Status: offline
Sometimes, if they sat in storage for a while, they will only get good compression after running for a minute or so.
_____________________________
Pe, (www.mvvs.nl), MVVS, MOKImotor, RCexl, MTW, Xoar, Mejzlik.
Blessing in ignorance? There is sanctuary in analysis.
Hide Signatures
(in reply to noveldoc)
       Post #: 3
RE: OS max 52 surpass 4 stroke is this true - 1/23/2013 2:53 PM
proptop
Score: 130
Last Login: 5/9/2013
Status: offline
Also, if the throttle is all the way closed when you're turning it over...that can make the compression feel soft...
It is bad luck to be superstitious...
Steuben Red Barons, Paradise R/C Flyers, RAAM
Hide Signatures
(in reply to pe reivers)
       Post #: 4
RE: OS max 52 surpass 4 stroke is this true - 1/23/2013 6:09 PM
john josey
Score: 110
Last Login: 5/19/2013
Status: offline
I have the same engine from new that had the same issue when i turned it over from been laid up for a couple of years, a stuck valve was the cause.
Hide Signatures
(in reply to proptop)
       Post #: 5
RE: OS max 52 surpass 4 stroke is this true - 1/24/2013 2:01 PM
tkline
Score: 100
Status: offline
You need to make sure the valves aren't gummed up but more than likely it just needs to be run some and as to the onboard glow driver if an engine is adjusted correctly and the fuel tank is in the correct position with the carb there is no need for an onboard glow driver all it will do is add weight to your spit and you will want to eliminate all the weight you can if you are putting a .52 on a .40 sized model I normally try to put at least a .70 four stroke on a .40 size plane but it just depends on the total weight of the model. Just my .02
Club Saito member # 689/topflite AT6/KMP B25 /H9 B25 /sterling PT-17/Andrews aeromaster/H9 p-51/BUSA eindecker/SE5A/J3 Cubs
Hide Signatures
(in reply to john josey)
       Post #: 6
RE: OS max 52 surpass 4 stroke is this true - 1/24/2013 7:49 PM  1 votes
pe reivers
Score: 646
Status: offline
I had a 5.5 kilo Spit using an OS90 4-stroke (not surpass)
The engine was mounted inverted, and I had a Micro switch operated on board single NiCd cell for glow, active below 1/3rd throttle, dead on throttle cut.
I could idle the engine at about 1400 rpm. When I cut glow support, it would die. Very convenient to set up, and weight certainly was no problem at all. The (Sterling kit) Spit would fly just like the real thing. Nothing Jackrabbit, but steady.
Hide Signatures
(in reply to tkline)
       Post #: 7
RE: OS max 52 surpass 4 stroke is this true - 1/24/2013 8:16 PM
john josey
Score: 110
Status: offline
quote:
ORIGINAL: pe reivers
I had the same set-up on my pilot pitts, a 3amp sub c battery and micro switch. Although it would idle fine, it was quite 'lumpy' and the onboard glow smoothed it out to super sweet !
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 8
RE: OS max 52 surpass 4 stroke is this true - 1/25/2013 4:55 PM
Four Stroker
Score: 104
Last Login: 3/28/2013
Status: offline
That was then and this is now. Get a Switch Glo which plugs directly to your receiver. No extra battery. Works great in a big plane where you have a big battery anyway. Not good if you use a AA pack in a small plane.
Hide Signatures
       Post #: 9
RE: OS max 52 surpass 4 stroke is this true - 1/28/2013 12:31 PM
acdii
Score: 155
Status: offline
They lose compression when sitting for a while, especially if they have been flipped dry a lot. A small amount of glow fuel, or after run oil shot into it will boost compression before you can run it if you want to feel compression in it.
http://www.facebook.com/pages/B-17e-Desert-Rat-Restoration-Project/218159428244374
Hide Signatures
(in reply to Four Stroker)
       Post #: 10
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Glow Engines >> OS max 52 surpass 4 stroke is this true
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.360RCU1
