Sideways mounted srevos    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Scratch Building, Aircraft Design, 3D/CAD >> Sideways mounted srevos
Page: [1]
Login
Sideways mounted srevos - 1/23/2013 4:17 AM
a70eliminator
Score: 100
Last Login: 6/4/2013
Status: offline
I feel kinda newby asking this but here goes anyhow.
If I follow the plan and mount my aileron servos sideways in the wing how do I acess the mounting screws? The servo resides between two wing ribs boxed in with an acess cover, it pretty tight and I'm trying to come up with a way to mount it, theres absolutely no way to get at the screws once the servo is in position, ideas? I guess I could screw the servo to the hardwood rails then glue the rails and servo in together.
Hide Signatures
       Post #: 1
RE: Sideways mounted srevos - 1/23/2013 4:27 AM
FlyerInOKC
Score: 116
Last Login: 6/19/2013
Status: offline
Better to ask then screw something up!
Epoxy to maple or basswood blocks to the access panel and mount the servo to them. Make sure the panel screws to hardwood not balsa. When you remove the panel the servo goes with it and the screws can be easily reached. Top Flite and SIG both use this method in their kits.
_____________________________
My workbench where you always find the weird and unusual! Sig Kadet Brotherhood #89 Ryan STA/STM/SC Brotherhood # 27
Hide Signatures
(in reply to a70eliminator)
       Post #: 2
RE: Sideways mounted srevos - 1/23/2013 11:09 AM
a70eliminator
Score: 100
Status: offline
Thanks! sounds like a plan,  servos I've done were always verticle with horns exposed.
 Attaching the controls to the horn,  cables landed within the pocket between the ribs, may be a challenge though.
I may have to completely re-do the rod routing, I'll try and get pics tonight so you can better visualize thanks again,
Scratch building is sooo much fun lolo.
Ok I think just figured out a solution! Must I also install an access hatch on the bottom of the wing to connect the rods?
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by a70eliminator -- 1/23/2013 1:23 PM >
Hide Signatures
(in reply to FlyerInOKC)
       Post #: 3
RE: Sideways mounted srevos - 1/23/2013 1:47 PM
Live Wire
Score: 6334
Last Login: 6/20/2013
Status: online
If you are useing 2 servos, I would move them out and eliminate the bell cranks. What plane and kit is this
Larry K AMA 36417
Sig Kadet Brotherhood # 4 WACO Brotherhood #34 Cub Brotherhood 14
Hide Signatures
       Post #: 4
RE: Sideways mounted srevos - 1/23/2013 2:49 PM
FlyerInOKC
Score: 116
Status: offline
Larry is right dump the bell cranks and connect directly with the servos. You will get better control and eleminate a big headache!
Hide Signatures
(in reply to Live Wire)
       Post #: 5
RE: Sideways mounted srevos - 1/23/2013 3:03 PM
flyinwalenda
Score: 167
Status: online
Another vote to ditch the bell-cranks. Those in the pic also look to have nyrod too.
As stated already, move the servos out into the wing and either make a cover plate and attach the servo to the cover :
Or make a plate and mount the servo and plate into the wing and make a cover for the opening:
Brian Ray
Hide Signatures
       Post #: 6
RE: Sideways mounted srevos - 1/23/2013 3:11 PM
john josey
Score: 110
Status: online
quote:
ORIGINAL: FlyerInOKC
As the guy's say, a direct connection is the best way to do it.
But a solution to your original question are these -
Click for fullsize
Hide Signatures
       Post #: 7
RE: Sideways mounted srevos - 1/23/2013 4:50 PM
FlyerInOKC
Score: 116
Status: offline
Looking at your picture the plans are really yellowed so this is an old kit. Back in the bad old days a servo was $50 to $60 so they used bell cranks because two servos was too expensive. Now days you can buy two higher quality servos for less than the cost of the older not as good servos.
Hide Signatures
(in reply to john josey)
       Post #: 8
RE: Sideways mounted srevos - 1/23/2013 4:52 PM
a70eliminator
Score: 100
Status: offline
Thanks for all the photos! The plans are showing the belcrank for the flaps, but yes the ailerons also have belcranks as there is only 1 servo for ailerons and 1 for flaps, the plane is a Gull Wing design by Fallandy 80's vintage.
Hide Signatures
       Post #: 9
RE: Sideways mounted srevos - 1/23/2013 6:10 PM
FlyerInOKC
Score: 116
Status: offline
quote:
ORIGINAL: a70eliminator
Now days as cheap as cheap as servos are I have one for each aileron and flap, one for the rudder, elevator, rudder, and throttle. If applicable I will also have servos for retracts, landing lights, and Navigation lights upto 7 channels.
Hide Signatures
       Post #: 10
RE: Sideways mounted srevos - 1/23/2013 8:13 PM
a70eliminator
Score: 100
Status: offline
I do have plenty of servos for this project, I like to build it light as possible but I am thinking about two servos, it's not too late to pull those flex rods although I think for this plane one servo would be fine as it's far from the aerobatic stuntmaster and I'm a novice too.
Hide Signatures
       Post #: 11
RE: Sideways mounted srevos - 1/30/2013 2:08 AM
a70eliminator
Score: 100
Status: offline
I have the srevos set up in the wing like all your photos depict, I did use 4 servos 2 aileron and 2 flaps so all the clumsy belcranks are eliminated. i have run into another snag with the flaps, my gold fg series futaba does not have end point adjustments on ch's 6-7, I'm having trouble because for the servo arm to portrude out of the wing slot it has to be quite long which results in double the travel I need, a small servo wheel puts the control way low below the slot? Any work around ideas would be appreciated thanks.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 12
RE: Sideways mounted srevos - 1/30/2013 11:33 AM
CHassan
Score: 105
Last Login: 5/31/2013
Status: offline
Longer control horn on the flap.
The knack of flying is learning how to throw yourself at the ground and miss.
--Hitchhikers Guide to the Galaxy--
Hide Signatures
       Post #: 13
RE: Sideways mounted srevos - 1/30/2013 4:30 PM
john josey
Score: 110
Status: online
Make an extention that bolts to your servo disc. I'll post this pic to give you an idea.
Click for fullsize
Hide Signatures
(in reply to CHassan)
       Post #: 14
RE: Sideways mounted srevos - 1/31/2013 12:50 AM
a70eliminator
Score: 100
Status: offline
Thats a nice trick, although my isssue is just the opposite. I have a old FG gold series 7ch non computer radio,  it does has mixing and dual rates, but not on channel 6 or 7 where all you have is a slider that looks exactly like the trims, the travel from full up to full down is way too much as I get full swing of my flaps at about half the travel of the slider even with my longest control horn on the flap.
Hide Signatures
       Post #: 15
RE: Sideways mounted srevos - 1/31/2013 4:39 AM
HighPlains
Score: 152
Last Login: 6/18/2013
Status: online
You can buy an entire 6 channel computer radio for the cost of a single servo from 1970.
- Supplementary insipid innocuous inane vacuous proclamation
Hide Signatures
       Post #: 16
RE: Sideways mounted srevos - 1/31/2013 5:36 AM
a70eliminator
Score: 100
Status: offline
quote:
ORIGINAL: HighPlains
Lol aint that the truth.
I got it sorted out, just used the smallest drive wheel nd the largest control horn and all it's comfortable now.
Ps I love my fp-t7fg/k transmitter and just can't seem to let go of it,  yea there's  quite a few thibngs it can't do without human input  and i'll probably never get that far adavanced to where i need anything else cheap or not, i'm kinda stuck in 1970.
< Message edited by a70eliminator -- 1/31/2013 11:06 AM >
Hide Signatures
(in reply to HighPlains)
       Post #: 17
RE: Sideways mounted srevos - 2/1/2013 5:38 AM
dreadnaut
Score: 110
Last Login: 6/16/2013
Status: offline
Aileron belcranks came from the days when radio control, and servos were expensive.. I use two aileron servos and mount them to openings I cut int he ribs, then double with 1/8" lite ply. I put holes in adjacent ribs that line up with the mounting screws that I can insert a jewelers screwdriver into. The down side is that you need to cut the covering away to insert the screwdriver if you need to replace a servo, but not that big a deal.
Cali is a city in Colombia
I''m from California.
Hide Signatures
       Post #: 18
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.719RCU1
