Velcro to hold wings on?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Scratch Building, Aircraft Design, 3D/CAD >> Velcro to hold wings on?
Page: [1]
Login
Velcro to hold wings on? - 1/23/2013 10:08 PM
jp1961
Score: 100
Last Login: 6/17/2013
Status: offline
I'm thinking of using Velcro to hold the wings on my profile. The wings have a (very) snug fit on the aluminum joiner tube (1.250") and there is a 3/8" dowel to keep them from rotating. Being a gas plane there would be no problems with oil residue. The Velcro would be on the bottom of the wing, strips about 5 or so inches long (positioned from root to tip). The one side would be attached to the fuselage with wood screws. The other side of the Velcro would be epoxied to the wing (I don't trust the peel and apply type). Velcro doesn't vibrate loose and assembly at the field would be a snap. Again, thinking outside the box. Any thoughts, ideas?
Jeff
Hide Signatures
       Post #: 1
RE: Velcro to hold wings on? - 1/23/2013 10:25 PM
countilaw
Score: 229
Last Login: 6/18/2013
Status: offline
Go for it ! !     And send us the pictures of the results .
Frank
_____________________________
It''s a hobby, not a job.
Hide Signatures
(in reply to jp1961)
       Post #: 2
RE: Velcro to hold wings on? - 1/23/2013 10:34 PM
Live Wire
Score: 6334
Last Login: 6/20/2013
Status: offline
Get back in the box
Larry K AMA 36417
Sig Kadet Brotherhood # 4 WACO Brotherhood #34 Cub Brotherhood 14
Hide Signatures
(in reply to countilaw)
       Post #: 3
RE: Velcro to hold wings on? - 1/24/2013 12:32 AM
N1EDM
Score: 125
Status: offline
Take pictures of the debris field before you pick up the pieces.... Somehow, I don't think this is a good idea....
Bob
Club Saito #61 Cub Brotherhood #107
Spitfire Brotherhood #143
Hide Signatures
(in reply to Live Wire)
       Post #: 4
RE: Velcro to hold wings on? - 1/24/2013 5:49 AM
Campgems
Score: 143
Last Login: 6/19/2013
Status: offline
Jeff, the velcro has good holding ability in the shear direction.  The issue with it is that it gathers all kinds of crud over time and becomes less and less effective.
My concern is that over time, the air flow would tend to peal it off given the lint and crud that it picks up in use.
Otherwise, it isn't much different than some of the "use once" tape I've seen used to hold glider wings together.  Should work.  Although a bit heaver than the tape.
Don
Hide Signatures
       Post #: 5
RE: Velcro to hold wings on? - 1/24/2013 6:57 AM
combatpigg
Score: 381
Status: offline
The Olympic 650 glider was a 3 piece wing that used pins to plug the outer panels into the center section, then they [IIRC] recommended using electrical tape to seal the slight gap [seam] where the panels meet.
Actually, I'm not really sure if the instructions called out for taping the seams or not..it's been over 20 years. This was a 2 or 3 pound plane that flew at 25 mph.
For a big, powerful aerobatic model with a fast roll rate I would be a little bit nervous about the velcro.
Blatantly corrupt umpiring at Yankee Stadium is an American tradition
It''s just part of the game.
Hide Signatures
(in reply to Campgems)
       Post #: 6
RE: Velcro to hold wings on? - 1/24/2013 3:56 PM
LesUyeda
Score: 151
Status: offline
" The issue with it is that it gathers all kinds of crud over time and becomes less and less effective. "
Valcro, otherwise known as "hook and loop" material. The "hooks" wear out, tear off, and loose their effectiveness.
Les
Hide Signatures
(in reply to combatpigg)
       Post #: 7
RE: Velcro to hold wings on? - 1/24/2013 4:11 PM
aspeed
Score: 105
Status: offline
Someone needs to come up with a better method than rubber bands and nylon screws.  Every time I use the screws and have a bad day, the pins in front of the wing wreck the fuselage former, and rubber bands are just unprofessional. I would check real close before using the velcro.  I always hold the wing firmly and shake it up and down real hard to see if the wing/fuselage pulls up or moves.  (Then add more rubber bands if it does. or in your case abort the idea)
Hide Signatures
(in reply to LesUyeda)
       Post #: 8
RE: Velcro to hold wings on? - 1/24/2013 7:23 PM
ARUP
Score: 144
Status: offline
Check out offerings from 'Iflytailies.com' or similar. They carry Graupner and other wing connectors that work well for BIG sailplanes that fly can faster than most powered airplanes. Otherwise a tab and thru bolt are the best options. My 1/4 DH-5 has scale connectors which consists of two connectors per wing that are bolted to top sides of wings at spar locations.
Hide Signatures
(in reply to aspeed)
       Post #: 9
RE: Velcro to hold wings on? - 1/24/2013 7:50 PM
aspeed
Score: 105
Status: offline
Back in the last millenium I kind of remember a spring loaded pin that was pushed in from the back I think, and used the locating spring in front like the conventional way.  The spring was kind of like a ball point pen spring.  I can't remember much about it, it was the 70's man. Another more recent one had a slot in the wing so the wing would twist in a light crash.  Couldn't see the picture close enough to figure it out.
Hide Signatures
(in reply to ARUP)
       Post #: 10
RE: Velcro to hold wings on? - 1/24/2013 8:44 PM
iron eagel
Score: 118
Status: offline
Sorry using Velcro to hold the wings on is a bad idea, stick with something a lot less outside of the box.
Hide Signatures
       Post #: 11
RE: Velcro to hold wings on? - 1/24/2013 9:22 PM
Rodney
Score: 174
Status: offline
For those using the peg or pin in the front former to hold the front of the wing on and then screws in the back: most use much to large a screw, usually 1/4-20's. These are much to large. On most planes, a 6-32 is more than ample. for 1/4 scale go to 8-32 nylons. Also make sure there is no gap between the wing and the point where the screw enters the fuselage. You want it a tight fit so that, if you hit on a wing tip the bolt(s) will shear easily. Having no gap aids in this shearing action. Without it, the bolt tends to bend and it takes much more force to break it if it is in tension which can cause the front pins to tear out the bulkhead they are inserted in.
Hide Signatures
(in reply to iron eagel)
       Post #: 12
RE: Velcro to hold wings on? - 1/24/2013 9:26 PM
Boomerang1
Score: 120
Status: offline
Why not?
Like Don said velcro has lots of strength in shear, I use it all the time to hold batteries in
with a loop around the battery with plenty of overlap.
Maybe the answer is a seperate, loose velcro strap which loops through the (re enforced) wing
ribs, through the fuselage, back through the opposite wing with a large overlap on the bottom.
If the velcro gets a bit manky with age just replace it. - John.
Distributor for: Nothing! So my posts can be unbiased.
Hide Signatures
       Post #: 13
RE: Velcro to hold wings on? - 1/25/2013 2:27 AM
iron eagel
Score: 118
Status: offline
A big Gas aerobatic plane with the wings held on with Velcro really sounds a bit iffy to me.
I use Velcro doubled up to secure my batteries into planes but I personally would never use it for something structural.
Having dealt with full scale aircraft, I am a bit more conservative than most when it comes to how planes are held together.
Hide Signatures
(in reply to Boomerang1)
       Post #: 14
RE: Velcro to hold wings on? - 1/25/2013 4:40 AM
ARUP
Score: 144
Status: offline
Here are some examples.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 15
RE: Velcro to hold wings on? - 1/25/2013 5:10 PM
aspeed
Score: 105
Status: offline
I saw the I fly tailies thing before too.  I guess here is the dumb question.  Doesn't that just hold the wing together, not on,   a regular top or bottom fuselage mount?  The Tailies snap thing too?
Hide Signatures
(in reply to ARUP)
       Post #: 16
RE: Velcro to hold wings on? - 1/26/2013 12:29 AM
N1EDM
Score: 125
Status: offline
Hmmmmm, I don't see jp1961 anywhere but in the 1st post. You don't suppose that this was a phishing expedition, do you???
Hide Signatures
       Post #: 17
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.750RCU1
