fuel soaked wood.    Gallery
Logged in as Guest
    Search This Thread
Printable Version
F-16 1/8 Advanced - ARF
Seller:  AndyAndrews
Details:   $2,800.00   |  6/17/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Crash & Rebuild >> fuel soaked wood.
Page: [1]
Login
fuel soaked wood. - 1/24/2013 3:01 PM
Fred420
Score: 100
Last Login: 3/4/2013
Status: offline
I am rebuilding an old, 25yr, aircraft. I do not know make or model, but it is a trike with a top wing. Anyway ........ the right side of the fuselage is fuel soaked. I stripped the covering off and have lightly sanded but can not remove the sticky oil feel off the wood. I know I need to get to bare wood to have the covering adhear to it
........ any suggestions as to clean it up?
Fred
_____________________________
Dave "Sparky" Davis - RCCA #870
"Earth is the insane asylum for the universe"
Hide Signatures
       Post #: 1
RE: fuel soaked wood. - 1/24/2013 5:17 PM
Rubbernecker
Score: 105
Last Login: 6/16/2013
Status: offline
K2R and a heat gun. After a couple or 3 applications and before trying to recover you should put balsa-rite or something on it to help.
John
The heat gun is to speed things up. Also helps to bring the oil to the top.
< Message edited by Rubbernecker -- 1/25/2013 3:18 AM >
Hide Signatures
(in reply to Fred420)
       Post #: 2
RE: fuel soaked wood. - 1/24/2013 5:23 PM
83scamp
Score: 100
Last Login: 6/18/2013
Status: offline
quote:
ORIGINAL: Rubbernecker
John
I'll second that.  K2R spot remover and patience.  The stuff is incredible.  It's getting harder to find, but look for a local Ace Hardware store.  There are a couple of places online that sell it, but you have to buy it in a 6-pack, and that would last most of us two lifetimes!!
You have to give it time to work.  Spray it on, and let it set overnight.  When the white, chalky K2R turns yellow and gets "doughy", brush it off and give it another coat.  Keep doing it until it stays white and chalky, then you've got it.
Hide Signatures
(in reply to Rubbernecker)
       Post #: 3
RE: fuel soaked wood. - 1/24/2013 7:03 PM
kenh3497
Score: 115
Last Login: 6/11/2013
Status: offline
Some body mentioned mixing acetone and corn starch. Brush/spray/slather it on. Works much the same as K2R. I've never done the acetone/cornstarch thing, but K2R dies work well.
Sent from my Dry-Erase-Board
Hide Signatures
(in reply to 83scamp)
       Post #: 4
RE: fuel soaked wood. - 1/24/2013 10:40 PM
Sessholvlaru
Score: 105
Status: offline
You can also try covering it in cat litter/speedy dry for a few days.
When you stare into the abyss, sometimes the abyss stares right back into you.
Hide Signatures
(in reply to kenh3497)
       Post #: 5
RE: fuel soaked wood. - 1/26/2013 11:10 PM
RC_Fanatic
Score: 100
Last Login: 6/19/2013
Status: offline
quote:
ORIGINAL: kenh3497
Tried that. Did not work nearly as well as K2R.
RC_Fanatic
Hide Signatures
       Post #: 6
RE: fuel soaked wood. - 1/27/2013 3:01 PM
KitBuilder
Score: 131
Status: offline
Brush on epoxy once done.
Mike -
I was born a pilot... 100 years to late.
Hide Signatures
(in reply to RC_Fanatic)
       Post #: 7
RE: fuel soaked wood. - 1/29/2013 9:32 PM
Ed Smith
Score: 113
Last Login: 6/17/2013
Status: offline
I tried that. The two cats thought it was their new litterbox. Need I say more?
Ed S
Hide Signatures
(in reply to KitBuilder)
       Post #: 8
RE: fuel soaked wood. - 1/29/2013 9:36 PM
KitBuilder
Score: 131
Status: offline
Next question... how do you remove cat pee from balsa
Mike -
Hide Signatures
(in reply to Ed Smith)
       Post #: 9
RE: fuel soaked wood. - 1/29/2013 9:39 PM
Ed Smith
Score: 113
Status: offline
It was the dark brown, sticky, smelly stuff that was the problem.
Anyway with a name like "Kity builder" you should know.
Ed s
Hide Signatures
       Post #: 10
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.266RCU1
