How to build an T-44 ???    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Tanks >> How to build an T-44 ???
Page: [1]
Login
How to build an T-44 ??? - 1/26/2013 2:33 PM
Silk789
Score: 100
Last Login: 5/17/2013
Status: online
Hi guys, I need your advice, how could i build up the lower Hull for an T-44?
The upper will be easy i Think, Turret from T-34 an just straight Plates, but how could I build up the damn lower?
Does anyone of you has already build one? Or has an idea how to do?
Best regards
Frank
Hide Signatures
       Post #: 1
RE: How to build an T-44 ??? - 1/26/2013 2:44 PM
mustclime
Score: 106
Last Login: 5/20/2013
Status: offline
get a t55 hull and a proline kv85 turret........done.
_____________________________
That which does not destroy me just makes me more irritable
Hide Signatures
(in reply to Silk789)
       Post #: 2
RE: How to build an T-44 ??? - 1/26/2013 2:55 PM
mustclime
Score: 106
Status: offline
I was thinking about making one when the t55 came out....here is some info I collected....
hope they help
Hide Signatures
(in reply to mustclime)
       Post #: 3
RE: How to build an T-44 ??? - 1/26/2013 4:47 PM
HAL_HUSKER
Score: 155
Status: offline
actually not... T55 is a different one...
T55 is a development of T54 and T54 (that was built in January 1945) was a futher improvement of T44 (1943 creation)...
As an option we have here soviet toys that can be converted to T44...
here is an example
and after some "improvements"
this lower hull + upper one could be used for T44, but you will need rebuild the turret...
and after
www.ircto.org
Hide Signatures
       Post #: 4
RE: How to build an T-44 ??? - 1/26/2013 4:50 PM
Silk789
Score: 100
Status: online
Ok thx you two
@ Hal i just see the first pic this little cheesy Tank ,)
Hide Signatures
(in reply to HAL_HUSKER)
       Post #: 5
RE: How to build an T-44 ??? - 1/26/2013 4:53 PM
HAL_HUSKER
Score: 155
Status: offline
Please get me right... the pictures that I have put are for my T54B, but the lower hul and upper cover is 100% applicable to T44 too...
Actually I am thinkuing also to build T44 in future... it was excellent new tank, with fantastic low profile to hit...
www.ircto.org
Hide Signatures
       Post #: 6
RE: How to build an T-44 ??? - 1/26/2013 4:59 PM
Silk789
Score: 100
Status: online
Hehe, ok i understand Hal
bit opne question, in your first post you just added one picture ore two?
because i just see the first toytank
do you have maybe a picture after convertign this toy?
Hide Signatures
       Post #: 7
RE: How to build an T-44 ??? - 1/26/2013 5:20 PM
mustclime
Score: 106
Status: offline
t-54
t-55
http://en.wikipedia.org/wiki/T-54/55
the lower hulls are very close.....here is a nicerunning one.
http://www.youtube.com/watch?v=y9d4E8DBZec
http://www.youtube.com/watch?v=LjmcOjo7cNo
Hide Signatures
       Post #: 8
RE: How to build an T-44 ??? - 1/26/2013 5:39 PM
HAL_HUSKER
Score: 155
Status: offline
quote:
ORIGINAL: Silk789
not finished yet
www.ircto.org
Hide Signatures
       Post #: 9
RE: How to build an T-44 ??? - 1/26/2013 8:57 PM
sassgrunt
Score: 100
Status: offline
A recent issue of Finescale Modeler had an article about making one in 1/35 scale. The more I looked at it; the more I wanted to try it with a WSN T-34. And then, I saw this build on another forum and decided that it really COULD be done pretty easily. http://www.rctankwarfare.co.uk/forums/viewtopic.php?f=23&t=3708
The only real question I have is with the gap between the roadwheels. The T-34 has it between the second and third, and nearly all of the references I've found say that for the T-44 it is between the first and second. The WSN hull is pretty flimsy already, so cutting it into three pieces and then gluing it back together seem like it would be even flimsier.
Hide Signatures
       Post #: 10
RE: How to build an T-44 ??? - 1/26/2013 9:04 PM
Airbrushler
Score: 112
Status: online
quote:
ORIGINAL: HAL_HUSKER
here is an example
and after some ''improvements''
and after
Where are thse toy tanks made Hal Husker do they still sell them?
http://s1009.photobucket.com/user/airbrushler/media/Soviet_Tank_Battle_zps9b2ee783.gif.html
Hide Signatures
       Post #: 11
RE: How to build an T-44 ??? - 1/26/2013 9:16 PM
Martellus
Score: 100
Last Login: 5/19/2013
Status: offline
Just use a WSN t-34 for roadwheels and accessories, a hooben t-55 for the hull, and either the t-34's turret or a kv-85 turret. I found in testing though that the wsn tracks require ludicrous tension to prevent slippage on the drive sprocket, which I detest, so I prefer a mix of the older roadwheels and the t-55's tracks like on this semi modernized t-44:
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 12
RE: How to build an T-44 ??? - 1/29/2013 1:05 AM
pattoncommander
Score: 132
Status: offline
Hal I remember well when the T-44 came out. It had more of a fear factor than the ill fated JS-III bacause it was so much smaller and faster than the T-34s that we were facing and had such sleek lines. I always liked it but it was replaced quickly by the newer T-54-55s.
It would be a cool model to have.
HL M-26, M-46, M-41B, T-34/85, IDF M-51 (2)
Hide Signatures
       Post #: 13
RE: How to build an T-44 ??? - 1/29/2013 4:53 AM
HAL_HUSKER
Score: 155
Status: offline
quote:
ORIGINAL: pattoncommander
Exactly, they were replaced because T54 made in 1945 had some advantages... That is why they decided to concentrate on T54 prototype.
Thanks for sharing this is awesome... I also attach the couple of pictures of T54 for you to compare. I am just thinking of switching from my T54B to T54 (1945)...
Click for fullsize
Click for fullsize
Click for fullsize
www.ircto.org
Hide Signatures
(in reply to pattoncommander)
       Post #: 14
RE: How to build an T-44 ??? - 1/29/2013 3:56 PM
pattoncommander
Score: 132
Status: offline
Thanks Hal, I think the early T-54 had better features over the later cramped dome turret. I think the turret crew would be so much more effective in the earlier T-34 design turret where they were not bent over with no where to move. I've driven a T-55, been in T-62 and T-72, and they are just too cramped in the turrets. Plus on an incline, the dome turrets are poorly designed for balance and manual traverse uphill , especially with the 125mm gun, is really tough. The driver in a 55 or 62/64 has plenty of room and they drive nicely, but that "user unfriendly" dome turret kills the effectiveness of the crew. I like that earlier model.
Hide Signatures
       Post #: 15
RE: How to build an T-44 ??? - 1/31/2013 8:52 PM
Silk789
Score: 100
Status: online
Ok guys, a little Update from me
I just have got an T-44 lower Hull for approximately 40€
and from a friend in another forum i have ordered the WSN T-34 Road Wheels and an T-34/85 Turret
But i think i have to do the upper hull by scratching because i think its simple and ther Orginal T-55 is not really the same as the T-44
does Anyone of you has Blue prints with dimensions etc. for the upper?
Best regards
Frank
Hide Signatures
       Post #: 16
RE: How to build an T-44 ??? - 1/31/2013 11:35 PM
sassgrunt
Score: 100
Status: offline
In the build link I posted above, the builder used the 1/35th scale plans on page 80 in George Bradford's book: Russian Armored Fighting Vehicles. If you scale the plans up 218%, you'll have 1/16th drawings to copy in plastic.
Hide Signatures
       Post #: 17
RE: How to build an T-44 ??? - 1/31/2013 11:43 PM
MAUS45
Score: 100
Status: offline
Hi Frank, here is a site with photos of the T55 engine deck and details.
http://www.armorama.com/modules.php?op=modload&name=SquawkBox&file=index&req=viewtopic&topic_id=167910&page=1
I have attached drawings of it as well. If you look at the drawings I think you will see that maybe the Hooben T55 could be converted.
I have looked at them booth and it seems they are similar.
Click for fullsize
3 Tamiya''s Tiger I, Tiger II, Panther G, 3 HL Stug III G, 1 HL Panzer III M, 1 Jagdpanzer IV L/70, 1 1/8 Tiger II
Hide Signatures
       Post #: 18
RE: How to build an T-44 ??? - 2/1/2013 12:08 AM
MAUS45
Score: 100
Status: offline
Here is more T44 information. Try this site for some good color detail drawings and I have attached some better T44 line drawings as well.
http://www.o5m6.de/t-44.html
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to MAUS45)
       Post #: 19
RE: How to build an T-44 ??? - 2/3/2013 6:41 AM
HAL_HUSKER
Score: 155
Status: offline
the only one in CIS restored T-44 "beauty"...
www.ircto.org
Hide Signatures
       Post #: 20
RE: How to build an T-44 ??? - 2/3/2013 5:55 PM
MAUS45
Score: 100
Status: offline
Она была очень красива. Спасибо за участие! She was beautiful. Thanks for Sharing!
Hide Signatures
       Post #: 21
RE: How to build an T-44 ??? - 2/3/2013 6:12 PM
Panther F
Score: 135
Status: offline
Oh, hot damn Hal... that T-44 is awesome! Much better looking than a T-34/85.
But not better than a T-54/55.
It'll be interesting to see a build thread here.
~ Jeff
Hide Signatures
       Post #: 22
RE: How to build an T-44 ??? - 2/5/2013 1:23 PM
pattoncommander
Score: 132
Status: offline
Hal, that's a great looking tank and seems to drive well too. Like that much better than the T-55s. Thanks for sharing.
Hide Signatures
       Post #: 23
RE: How to build an T-44 ??? - 2/5/2013 2:45 PM
YHR
Score: 204
Status: online
THanks Hal. I really like the look of this tank
Dan
Battle Armor R C
Hide Signatures
       Post #: 24
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.781RCU1
