Receiver batteries    Gallery
Logged in as Guest
    Search This Thread
Printable Version
F-16 1/8 Advanced - ARF
Seller:  AndyAndrews
Details:   $2,800.00   |  6/17/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> Receiver batteries
Page: [1] 2   next >   >>
Login
Receiver batteries - 1/26/2013 5:06 PM
StephenUK
Score: 100
Last Login: 6/17/2013
Status: offline
Hi Guys
I’ve recently bought my first jet - a Boomerang Nano fitted with Wren 44 Gold. The model was second hand from a very reputable local model shop. The only component missing is the receiver. The model appears to be in very good condition, the turbine has a total running time of 110 minutes.
One question I have is regarding radio. I currently use a JR XG11 DMSS radio. I plan to use the 11 channel JR RG1131B receiver. I have noticed that the model is fitted with 2x 2000mah 6v NIMH receiver batteries (plus a 2s lipo for the ECU). The receiver previously installed in the model was a Spektrum with two battery terminals. Is this common practice to use two receiver batteries, presumably one as a backup if the other fails? I have been looking through the JR DMSS range of receivers but they do not offer a similar receiver with the two battery terminals. In my F3A models, my preferred method is to use a 2s lipo and a Power Box Digi Switch, is this suitable in a jet?
Another option is to continue with the two NIMH receiver batteries (obviously replace with new ones) and use a Power Box 12 switch which allows the use of 2 receiver batteries.
Any help would be much appreciated.
Regards
Stephen
Hide Signatures
       Post #: 1
RE: Receiver batteries - 1/26/2013 5:45 PM
JohnMac
Score: 100
Last Login: 6/18/2013
Status: offline
Hi Stephen,
Yes it is common practice to use dual batteries in a jet. The main aim is redundancy, as at jet speeds even a momentary loss of control through a brown out event, can be catastrophic. This has the added benefit that twin batteries working in parallel offer twice the current capability of a single battery. Again, jets tend to use high power digital servos, and these are current hungry.
If you intend to replace the NiMh batteries, then my advice would be to go for A123 batteries if you can. I think these are now accepted as the best battery technology currently available. Personally, I use no NiMh batteries in my models.
John
Hide Signatures
(in reply to StephenUK)
       Post #: 2
RE: Receiver batteries - 1/26/2013 6:06 PM
Xairflyer
Score: 105
Status: offline
I agree the Life may be better but see no reason why not to stick with the sub C Nimh batteries which I use in all my models, properly charged they are very robust.
_____________________________
www.letterkennymodelflyingclub.com
www.jmaireland.com
Hide Signatures
(in reply to JohnMac)
       Post #: 3
RE: Receiver batteries - 1/26/2013 6:11 PM
CraigG
Score: 105
Status: online
quote:
ORIGINAL: StephenUK
I have been looking through the JR DMSS range of receivers but they do not offer a similar receiver with the two battery terminals.Regards
Stephen
Welcome to jets!
You can plug a second battery into any unused servo terminal. It will operate in parallel with the one plugged into the "battery" terminal.
Concur with JohnMac on the A-123 battery suggestion. I use them in all my jets.
Craig
Hide Signatures
       Post #: 4
RE: Receiver batteries - 1/26/2013 6:18 PM
mick15
Score: 105
Status: offline
I'm not disagreeing with what has been written just giving another view.
I have been flying a Boomerang XL for the last four years with one LiFe 2300 two cell. KISS
m
Hide Signatures
(in reply to CraigG)
       Post #: 5
RE: Receiver batteries - 1/26/2013 6:26 PM
ash 26
Score: 100
Last Login: 6/8/2013
Status: offline
I am with you John been using back -up system in all my models from Gliders to Jets and have been using A123 for the last 4 years now
cheers
Andy
Hide Signatures
       Post #: 6
RE: Receiver batteries - 1/26/2013 6:33 PM
StephenUK
Score: 100
Status: offline
Hi guys,
Thank you very much for the information. If I use 2s A123 batteries, Will i be ok to plug these straight into the receiver through a normal switch, without the use of a regulator? the receiver instructions specify an input voltage range of 4.8v - 8.5v and a 'normal rated voltage' of 4.8v? I guess it would depend on the voltage rating of the servos?
Once again many thanks
Stephen
Hide Signatures
       Post #: 7
RE: Receiver batteries - 1/26/2013 6:45 PM
ash 26
Score: 100
Status: offline
I would always go through a regulator like Power Box sensor switch or emcotech
cheers
Andy
Hide Signatures
       Post #: 8
RE: Receiver batteries - 1/26/2013 7:24 PM
bcovish
Score: 1018
Status: offline
quote:
ORIGINAL: CraigG
quote:
ORIGINAL: StephenUK
Stephen
Welcome to jets!
You can plug a second battery into any unused servo terminal. It will operate in parallel with the one plugged into the ''battery'' terminal.
Craig
If all the channels are being used in the receiver, you can "Y" the second battery into any of the channels on the RX
Bob-O
Austin TX
Hide Signatures
       Post #: 9
RE: Receiver batteries - 1/26/2013 8:03 PM
CraigG
Score: 105
Status: online
quote:
ORIGINAL: ash 26
cheers
Andy
Not everybody agrees but many of us have been running A123 batteries without regulators and without problems of any sort. Goes along with the aforementioned KISS principle. It's an individual choice.
Hide Signatures
(in reply to ash 26)
       Post #: 10
RE: Receiver batteries - 1/26/2013 9:15 PM
Boomerang1
Score: 120
Status: offline
If the model has been flying fine I'd just replace the batteries with new of the same specification NIMH.
No CG problems, no packaging or access problems, just fit your reciever, set up & fly.
NIMH batteries are fine as long as you realise their good & bad points & use them appropriately.
The set up you have is exactly what I use in my jets, plug the extra battery into any spare socket on
the reciever via a switch or your choice.
Some servos get angry if you feed them too much voltage hence the need for a regulator.
I used that setup at the last jet fly I attended, I forgot my usual batteries so had to make do with what a vendor at the meet had
available, used 2 LIFE batteries & 2 x PB Digi Switches which worked fine. The only thing that concerned me was the current rating
of the Digi switches, jets use lots of servos & the current rating of the switches I bought was quite low. - John.
Distributor for: Nothing! So my posts can be unbiased.
Hide Signatures
       Post #: 11
RE: Receiver batteries - 1/26/2013 10:29 PM
BarracudaHockey
Score: 280
Status: offline
The reciever you refer to is called a Power Safe reciever and yes, its got dual battery inputs for redundancy and a "soft switch" which means the switch when closed holds the reciever in an OFF state, so if the switch fails they normally fail open, and you just cant turn off your reciever, vice the other way around where if a normal switch opens you loose power.
As for the DMSS recievers, they do not, as of yet, offer Power Safe recievers in DMSS yet and your radio isn't compatable with any of the DSMX power safe receivers.
I was told, end of January for DMSS power safe, but....its the end of January and they aren't here yet so.....soon maybe?
Andy - Helicopter Forum Moderator
AMA 77227 Leader Member- Contest Director
www.JaxRC.com
Hide Signatures
(in reply to Boomerang1)
       Post #: 12
RE: Receiver batteries - 1/26/2013 10:54 PM
George
Score: 100
Status: offline
quote:
ORIGINAL: StephenUK
I have been using the dual Power Box switch with 2 2S Fromeco Li-Ions for years and is my preferred set-up. You can do the same and use 2 2S Li-Pos if you were already using the Li-Po. The A123s are a good option as well and many are switching to that set-up. It comes down to personal preference and what you're comfortable with in regards to power, safety and needs.
Welcome to jets, you'll love it!!
George DelMoral
Dreamworks "Mobile" Products LLC
Hide Signatures
       Post #: 13
RE: Receiver batteries - 1/27/2013 3:41 AM
sirrom
Score: 105
Last Login: 6/15/2013
Status: offline
Yes it is common to use two packs for back up purposes and yes you can just plug the second battery into an unused receiver channel. I for the longest time did not usually do this but started flying giant scale planes with my son so started using dual RX batteries. I set up my 37% ultimate with a smart fly power expander with 2 LiFe batteries plugged in. In my son's plane which is a 30% extra I used two LiFe batteries directly into the receiver. Today that practice saved his plane. He did a very hard snap roll today while flying, when we landed something was a little off so we took off the canopy and one of the batteries had come loose from it's mount and disconnected itself. If the second battery had not been there, we would have lost the plane. So yes use both batteries, with power expander or a just plugged into the rx.
Patrick
Perfect landing or total destruction crash, I still love this hobby!
Hide Signatures
       Post #: 14
RE: Receiver batteries - 1/27/2013 3:42 AM
sirrom
Score: 105
Status: offline
Patrick
Hide Signatures
       Post #: 15
RE: Receiver batteries - 1/27/2013 10:22 AM
3dean
Score: 101
Status: online
i wouldnt change the batterys but i would put them through a powerbox sensor switch ,if the switch fails it will do so in a closed position,the lights will also give you an indication of battery condition. a nano may be the budget end of the market but actually its still a sh1t load of £ to stick in the deck
Hide Signatures
(in reply to mick15)
       Post #: 16
RE: Receiver batteries - 1/27/2013 11:29 AM
Dave Wilshere
Score: 108
Status: offline
First...there is no such thing as 4.8v operation...I have argued with JR over this for 10 years plus and have only had a straight answer in the last year. 4.8v is a poor description of battery voltage, it means 4 cell. 6v (common Futaba talk) means 5 cell...Ni or MiMH. These are flat voltages and NOT what we fly at. Good 4 cell packs operate between 5.5 and 5.7v, Good 5 cell packs around 7.2v. JR do all their testing on servos and radios at 5.7v....
Most Rx's now are good over a range of voltages right up to 8.4v (2s Li-Po called 7.4v!!) 2s Li-po when charged. So its down the the servos and sometimes valves as to what they will take.
Powerbox realised a long time ago that an optimum voltage for servos and Rx's is between 5.5 and 5.9v
I fly my Nano with a single Digi switch rated at 3A and 5.5v, it has a 2s Li-Po charged to 8.4v and I have digital servos on everything except nose steering and I can say I fly it hard...for landing I have 90 degree flap, Ailerons raised 12mm and rudders spread 15mm to all act as air brake. I have 100+ flights and the Digi switch heat sink gets slightly warm after flight. (how many of you check the temp of your Sensor switch or even Powerbox unit alu heat sinks...this tells you everything about how hard the unit is working.
In this case if they are good NimH (Eneloop) or quality D cells running 5 cells (so 7v plus), I'd stick in a Sensor Switch (overkill) and fly all weekend.
I have Sensor switches in all my CARF Flashes including the 2006 Instruction manual aeroplane, with the same two 2s Li-Pos with hundreds and hundreds of flights...thats rated at 5A
Dave W
Motors & Rotors. JetCat, Powerbox, Intairco, Behotec, Graupner. CARF-models Rep. JR Propo for ever!, Jet 1A, MAP, Evojet, BV
Hide Signatures
(in reply to 3dean)
       Post #: 17
RE: Receiver batteries - 1/27/2013 11:43 AM
BaldEagel
Score: 118
Status: offline
quote:
ORIGINAL: StephenUK
Hi guys,
Stephen
I have been using A123's since they first appeared in the market, this was before they where available to the RC market, I just use them the same as a Nimh battery (except for charging) their off the charger voltage is less than a fresh charged 5 cell Nimh, they do not need a regulator.
Mike
No matter what anyone says 100% is the maximum you can get.
Hide Signatures
       Post #: 18
RE: Receiver batteries - 1/27/2013 1:16 PM
Wayne22
Score: 105
Status: offline
it depends on the max voltage that your servos will take. Many JR and some Futaba servos are rated at 6 volts max. I've seen one such servo get cooked running an unregulated 123 pack. NiMH have a bad tendancy to drop in voltage under load....I wont use them except in pairs of 5 cells with a regulator.
Since the Nano only weighs 12 lbs fully fuelled, there is no need to get overly complicated with it.
All I ask is for a chance to prove that money can't make me happy......
Hide Signatures
(in reply to Su26flyer)
       Post #: 19
RE: Receiver batteries - 1/27/2013 1:48 PM
3dean
Score: 101
Status: online
hmmm is a sensor switch and 2 batts over complicated ? or just common sense ??
i think its a nobrainer
yes my nano was good value 😜
Hide Signatures
       Post #: 20
RE: Receiver batteries - 1/27/2013 5:09 PM
sirrom
Score: 105
Status: offline
for your nano. Since it is a small jet you can do the following. Use two switch system with two 1100 mah a123 batteries and you will be fine. Or get a wolverine type switch.
You dont need a power box or anything for a nano just use the two batteries.
Patrick
Hide Signatures
(in reply to 3dean)
       Post #: 21
RE: Receiver batteries - 1/27/2013 7:13 PM
BaldEagel
Score: 118
Status: offline
"I've seen one such servo get cooked running an unregulated 123 pack."
In that case it would have burst into flames on a 5 cell Nimh straight off the charger.
A123's used to be obtained from 36volt DeWalt packs, but now I think they have changed, in the UK you can buy them from Puffin Models.
Mike
Hide Signatures
(in reply to Wayne22)
       Post #: 22
RE: Receiver batteries - 1/27/2013 7:19 PM
gsmarino2000
Score: 100
Last Login: 6/16/2013
Status: offline
Yes, you can plug two batteries into any receiver and they are in parallel ... but this is not the same as using a JR/Spectrum PowerSafe receiver, Powerbox or other battery sharing device. Devices intended for this purpose isolate the two batteries so that a shorted cell or similar occurance in one battery can't pull down the bus voltage.
Hide Signatures
(in reply to sirrom)
       Post #: 23
RE: Receiver batteries - 1/27/2013 8:42 PM
CraigG
Score: 105
Status: online
quote:
ORIGINAL: gsmarino2000
Whoa boy......we busted that myth years ago. Here's one of the better explanations: http://www.hangtimes.com/parallel_packs.html
Hide Signatures
(in reply to gsmarino2000)
       Post #: 24
RE: Receiver batteries - 1/27/2013 8:57 PM
VF84sluggo
Score: 345
Status: offline
quote:
ORIGINAL: CraigG
quote:
ORIGINAL: ash 26
cheers
Andy
+1
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.875RCU1
