Gyros 'N jets    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> Gyros 'N jets
Page: [1]
Login
Gyros 'N jets - 1/27/2013 6:09 AM
husafreak
Score: 100
Last Login: 5/25/2013
Status: offline
I am interested in trying a gyro on the steering of my Electra or future jet... I see Dreamworks has a JR370 which is expensive and an Eflight which is reasonable. But now that the heli guys have embraced Flybarless units you can pick up a great heli rudder gyro for peanuts. Seams like a no brainier to me, just a single axis gyro right? And if I go gyro do you recommend Rate mode or Heading Hold mode, again I imagine rate mode would be fine for short landing or takeoff runs. Any advice on how to set the gain? Thanks
Hide Signatures
       Post #: 1
RE: Gyros 'N jets - 1/27/2013 7:17 AM
JackD
Score: 100
Status: offline
quote:
ORIGINAL: husafreak
Eric,
You need rate gyro, not hhold.
If you are installing one on the nose gear, you might as well couple it with the rudder. Rudder gyros always help.
In my electra I have a jr 270 and works perfectly.
Another option is the 370A, which is only rate
Regarding setting, put it initially on a knob and increase the rate until you start getting tail wagging. Then dial it down a bit
You also might want to have a higher gyro rates with flaps down than flaps up, so it will be more effective at low speeds and more effective on the ground
Good idea trying to find a used one given the fbl migration, just make sure it has a rate mode
Had fun flying today, Doing a great job with the electra
_____________________________
Jack Gerardo Diaz
BVM Rep, Team Horizon, Team Jet Central
Hide Signatures
(in reply to husafreak)
       Post #: 2
RE: Gyros 'N jets - 1/27/2013 7:35 AM
DelGatoGrande
Score: 105
Status: offline
what i use in touchy steerings
http://dreamworksrc.com/catalog/micro-piezo-gyro-p-1043.html
Best Regards George SKYMASTER-A/D JETS-JETCAT-POWERBOX www.rcjet.gr "props are for boats"
Hide Signatures
(in reply to JackD)
       Post #: 3
RE: Gyros 'N jets - 1/27/2013 2:30 PM
sailing1
Score: 100
Status: offline
DelGatoGrande,
Are you mounting these at the center of rotation or can they be mounted a little closer to the front of the cockpit where there is a little more room? Also, do you have a recommmended starting point for the gain when used in steering mode only?
Hide Signatures
(in reply to DelGatoGrande)
       Post #: 4
RE: Gyros 'N jets - 1/27/2013 2:54 PM
hooker53
Score: 100
Status: offline
With the emergence of the AS3X tech, I have to wonder if gyros will go south in the future? I know it wil be awhile but look what they are doing to calm the little park flyers and stuff down.
Scratch it till it bleeds Convert it till it chokes
Hide Signatures
(in reply to sailing1)
       Post #: 5
RE: Gyros 'N jets - 1/27/2013 3:06 PM
flyinfool1
Score: 100
Last Login: 5/24/2013
Status: offline
Gyros can be located any where. Gyros measure rotation. Hopefully the entire aircraft will always be rotating at the same angular velocity.
The only critical mounting considerations are that it be mounted with its sensing axis exactly aligned with the axis of the aircraft. that it is sensing. Meaning that if you are using it for rudder or steering, the vertical axis of the gyro must me vertical in the aircraft.
The other consideration is vibration. Most gyros do not like vibration. If flight this is not an issue. while on the ground, a bumpy runway like a grass field may cause some vibration and result in some slight issues.
As mentioned above. Start with a low gain on a dial or slider and work up till you get instability and then back off some.
Jeff Borowski
RAMS Club President
Hide Signatures
       Post #: 6
RE: Gyros 'N jets - 1/27/2013 3:21 PM
DelGatoGrande
Score: 105
Status: offline
quote:
ORIGINAL: sailing1
DelGatoGrande,
You can mount it anywhere it doesnt matter .I place at the nose close to the steering servo so i wont use extension.
I would never recommend a starting point since geometry can change the outcome.For example trailing link nose legs need more gain than direct.
Mount it and move the nose left and right.Gently corections is what you should see even in hard changes.
Hide Signatures
       Post #: 7
RE: Gyros 'N jets - 1/27/2013 4:01 PM
sysiek
Score: 100
Status: offline
Hi after flying the jets for full day we go for gyro or two with friends ,I only witness problems with gyros including two totall loss crashes, and for that reason I using mine pilot talent ,at least for now.
Hide Signatures
       Post #: 8
RE: Gyros 'N jets - 1/27/2013 7:03 PM
landeck
Score: 137
Status: offline
Here is use what I use on the rudder of tail dragers for take off and landing:
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXCNFR&P=SM
Bruce
Bruce L. AMA# 54227
Ultra Sport Brotherhood #15
Hide Signatures
       Post #: 9
RE: Gyros 'N jets - 1/27/2013 7:18 PM
husafreak
Score: 100
Status: offline
Thank guys, good to hear the simple and cheap GWS gyro can get the job done. Come to think of it I have one of those in my DLG. The JR370A is 165 bucks so I will look for a less expensive solution, maybe the 270 is less. The Futaba looks good too, cant argue the quality there. I will probably stick with nose gear only initially at least until I figure how it would affect the rudder during flight? It would be possible to have the flap switch turn off the gyro (zero gain) on retraction, Or put it on a knob like you Jack said and play with it to see. All heading Hold gyros are capable of Rate Mode too as far as I know, it is just a function of how you set the TX gain. And while I agree with sysiek that the edible gyros are the best ones, I am very skeptical of how a gyro could cause a total loss crash, they are simple and reliable and pretty transparent.
Jack, after replacing the main gear tires and adjusting the toe in the Electra was definitely handling better on the runway but still it is more sensitive to corrections at high speed than any model I have ever owned, it almost always wants to veer one way or the other on touchdown roll out.
FWIW I picked up a Spectrum RX with the ASX3 system at my LHS last week, couldn't resist! Should be fun to play with, starting small.
Hide Signatures
(in reply to sysiek)
       Post #: 10
RE: Gyros 'N jets - 1/28/2013 8:04 PM
flyinfool1
Score: 100
Status: offline
quote:
ORIGINAL: husafreak
The Futaba GY240 Gyro is Heading Hold only. It does not have a "Rate" or "Normal mode. There may be others that I am not familiar with.
Depending on the failure mode of the gyro and what control it was connected to. It is possible for a gyro to fail in a way that locks the servo hard over to one side. This is not a common thing. In 15 years in helies and who knows how many thousands of successful flights, and failures of various sorts that I have seen, I have only seen this once. The most common gyro failure that I have seen (short of setup error) is the mounting tape letting go and the gyro flopping around giving all kinds of bad instructions to the servo. Many heli fliers now put a velcro safety strap over the gyro to prevent this.
Jeff Borowski
RAMS Club President
Hide Signatures
       Post #: 11
RE: Gyros 'N jets - 1/28/2013 10:32 PM
DAN AVILLA
Score: 100
Status: offline
I have used the 240 for years in jets. The avs switch turns the heading hold off.  Dan
Hide Signatures
(in reply to flyinfool1)
       Post #: 12
RE: Gyros 'N jets - 1/29/2013 12:29 AM
dbsonic
Score: 100
Status: offline
I just put a JR G270 on the Bandit for steering only. Seems to help but still playing/finding the gain setting. Has both rate and heading options, but I'm using it in rate mode.
Hide Signatures
(in reply to DAN AVILLA)
       Post #: 13
RE: Gyros 'N jets - 1/29/2013 2:20 PM
BarracudaHockey
Score: 280
Status: offline
quote:
ORIGINAL: flyinfool1
The Futaba GY240 Gyro is Heading Hold only. It does not have a ''Rate'' or ''Normal mode. There may be others that I am not familiar with.
It has a dip switch, it just doesn't have the second lead so it can be changed in flight.
Andy - Helicopter Forum Moderator
AMA 77227 Leader Member- Contest Director
www.JaxRC.com
Hide Signatures
       Post #: 14
RE: Gyros 'N jets - 1/29/2013 3:01 PM
kevinthoele
Score: 100
Status: offline
I love the 240. There is a switch to put in normal mode. Makes braking and takeoff wonderful. Also heli guys are giving them away. The last one I got lightly used for $30
Performs awesome.
Kevin Thoele
Texas Jets Group
Hide Signatures
(in reply to BarracudaHockey)
       Post #: 15
RE: Gyros 'N jets - 1/29/2013 3:37 PM
sailing1
Score: 100
Status: offline
Is there any problem with running two Gyros in one plane? I want to set up a small 1/8 scale Tamjets F16 with a Futaba 352 gyro running in Elevon mode and GWS Pc-03 for the steering. Both will need to be in the front of the plane, probably with the GWS right in front of the Futaba 352 due to space limitations. If this setup will work out, I would then like to duplicate it in a larger F35. I don't really think the little F16 needs the help but it should make a good air frame for me to get used to the gyros.
Hide Signatures
(in reply to kevinthoele)
       Post #: 16
RE: Gyros 'N jets - 1/29/2013 4:42 PM
BarracudaHockey
Score: 280
Status: offline
quote:
ORIGINAL: kevinthoele
Performs awesome.
Supply and demand, now that we know the jet guys want them the price will go up!
www.JaxRC.com
Hide Signatures
       Post #: 17
RE: Gyros 'N jets - 1/29/2013 4:48 PM
flyinfool1
Score: 100
Status: offline
quote:
ORIGINAL: BarracudaHockey
Thats kind of what I ment, Once airborn you can not turn off the Heading Hold or make changes to the gain. So if something is a bad setting you are stuck with it till you land.
Jeff Borowski
RAMS Club President
Hide Signatures
       Post #: 18
RE: Gyros 'N jets - 1/29/2013 8:58 PM
kevinthoele
Score: 100
Status: offline
It is only controlling the nose stering. I have never had any issues with this. Is does not matter airborne. Just make sure it is working in the correct direction and take off. No worries!!!!
Kevin Thoele
Texas Jets Group
Hide Signatures
       Post #: 19
RE: Gyros 'N jets - 1/29/2013 9:33 PM
John Redman
Score: 117
Status: offline
Sailing1, you can run more than one gyro in the model. No worries there. Both of my latest jets have 3 gyro's in place, one for elevator, rudder, and ailerons. Makes teh jet just grove like no other!!
John Redman
Team Horizon, JetCat USA Rep
Hide Signatures
       Post #: 20
RE: Gyros 'N jets - 1/30/2013 9:50 AM
Rush!
Score: 100
Status: offline
Anyone tried the new Futabe 431 gyros?  at 80 bucks each they're pretty reasonable...
< Message edited by Rush! -- 1/30/2013 12:04 PM >
Hide Signatures
(in reply to John Redman)
       Post #: 21
RE: Gyros 'N jets - 1/30/2013 12:11 PM
extra 300
Score: 100
Status: offline
quote:
ORIGINAL: John Redman
Hi John,
Could you please elaborate on the systems you are using on your jets as i was thinking of getting into this setup on my large F-15E mainly for more scale flying.
Thanks in advance
Regards,
Hide Signatures
       Post #: 22
RE: Gyros 'N jets - 1/30/2013 4:15 PM
husafreak
Score: 100
Status: offline
Good call Rush! Tower Hobbies has both the 430 and 431 listed and available for the same price. Don't know what the diff is...
Hide Signatures
(in reply to extra 300)
       Post #: 23
RE: Gyros 'N jets - 1/30/2013 6:16 PM
Rush!
Score: 100
Status: offline
I think the 430,431 gyros are just upgrades of their old 350,351,352 series.  I think the 431 is the 351 upgrade which allows for two aileron servos or rudder/steering combinations.  Can also be used for delta configurations.
havnt seen any reports on their use...  though but i wouldnt expect any problems with Futaba.
I have used the 351 on two jet (rate mode only) and i like them.  The 431 shouldn't disappoint....
Hide Signatures
       Post #: 24
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.015RCU1
