Deciding between chargers, Input wanted    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> Deciding between chargers, Input wanted Page: [1]
Login
Deciding between chargers, Input wanted - 1/28/2013 6:25 AM
Kristoffer_E
Score: 100
Last Login: 3/19/2013
Status: offline
So up to this point, I've never needed a real charger. I run a Blade CX2 with the little charger it came with, and I've just used AAs in my nitro trucks.
I have an opportunity to purchase a Blade mSR, and I want to invest in some LiPo or LiFe reciever packs for the nitros. Also, I'd like to be able to charge my CX2 batteries faster. So I have a dilemma. Do I want a single, high-output charger like this 400W Turnigy, or would one of the 4-output chargers be a better choice?
With the one output charger I could parallel charge several batteries, either 1s LiPo for the mSR or 2s LiPo for the CX2 and still have the capacity to charge high-power batteries, say if I ever got a brushless truck. However, if I want to charge a LiFe reciever pack, a 2s 800 mah LiPo, and a 1s 500 mah LiPo ALL AT THE SAME TIME, I'm out of luck. Something like the HobbyKing 4B6 would allow me to do the aforementioned charging craziness.
So, are the 4-output chargers a good choice? And if so, is a particular one better than another? I have found 4 I rather like, of which 2 are within the $75 amount I'd like to spend.
HobbyKing ECO 4X6s
HobbyKing 4B6
HobbyKing Quattro
Turnigy 4X6s
What is the real difference between the 3 HobbyKing 4x6s chargers? They all seem to be 200W, 50W per port. If I only use one port at a time, can I put 200W through that port, or is the most power i could ever put to a single battery 50W? And, is the Turnigy a justifiable expense (at nearly double the "budget" I tried to put on this charger ) for the 100W per battery?
< Message edited by Kristoffer_E -- 1/28/2013 5:14 PM >
_____________________________
Eflite Blade CX-2
Redcat Volcano S30
Hide Signatures
       Post #: 1
RE: Deciding between chargers, Input wanted - 1/28/2013 8:56 AM
Goldenduff
Score: 114
Last Login: 5/22/2013
Status: offline
The thing to watch with using a charging board is that the batteries have to be the same and at the same level of discharge. You have to add all the batteries to it at the same time (so you cannot use one, put it on to charge, use another then put it on to charge etc).
I confess to not looking at your chargers but the real difference is more than likely going to be their max wattage and amps (watts= volts x amps). The thing to look out for on this one is that you must stay within the amps AND watts limits of the charger.
The chargers may also require a seperate power supply.
All the best
Hello, the IMAX b6 quattro fits the bill?
Hide Signatures
(in reply to Kristoffer_E)
       Post #: 2
RE: Deciding between chargers, Input wanted - 1/28/2013 12:31 PM
flyinwalenda
Score: 157
Status: online
I would recommend to buy from a US based company who can at least provide you with some customer service and where you don't have to spend 1/4 or more of the cost of the item to ship it back if there is a problem.
Check out this one from VH as it is similar to the 4B6 you like and will be about $20.00 less with shipping plus you would have it in a few days not weeks.
www.valuehobby.com/power-systems/chargers/gt-power-xdrive-6-4x60-watt-6a-6s-balance-charger.html
These types of chargers will output only what is rated per port or per pack. The 200w or 240w rating is if you were using all 4 ports at their max output simultaneously.
Brian Ray
Hide Signatures
(in reply to Goldenduff)
       Post #: 3
RE: Deciding between chargers, Input wanted - 1/28/2013 2:41 PM
Kristoffer_E
Score: 100
Status: offline
I agree about the inherent problems with parallel charging board, and that's another reason I like the 4 port charger. However, as far as I can tell the hobbyking 4 port chargers are all 200w, 50w per port, and range from $60 to $90 in price and I can't figure out why.
Thanks for the input,
Kristoffer
< Message edited by Kristoffer_E -- 1/29/2013 3:01 AM >
Eflite Blade CX-2
Redcat Volcano S30
Hide Signatures
(in reply to flyinwalenda)
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.266RCU1
