RE: DLE 55 weirdness...    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Garage Sequestration Liquidation
Seller:  Mr DJ
Details:   $999,999.00   |  4/29/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: DLE 55 weirdness...
Page: <<   < prev  1 [2] 3 4 5 6   next >   >>
Login
RE: DLE 55 weirdness... - 1/29/2013 3:06 AM
juliangarcia
Score: 100
Last Login: 4/22/2013
Status: offline
I had a similar problem with one of my new airplanes. turned out after going through all the steps you mentioned, i ended taking the fuel tank out.
found the stopper was for glow fuel and was literally dissolving in the tank and all the debris was plugging the clunk. possible solution
Hide Signatures
(in reply to All Day Dan)
       Post #: 26
RE: DLE 55 weirdness... - 1/29/2013 3:13 AM
warbird addict
Score: 159
Last Login: 5/18/2013
Status: offline
Valid points for sure but from a troubleshooting standpoint you have to start with the basics of making sure the minimum requirements are met and eliminated as the problem and troubleshoot from there, the 93 octane we already know is a problem some would argue that point but it's already been clearly stated by the people who make the engines that it's not a good idea and has no benefit to use anything other than 87 octane.
The OP has already stated that he's been all over the map with the needle settings I'm just curious as to exactly what the specified mix rate is listed on the oil he's using, that coupled with the 93 octane could have a significant impact on the problems he's having, but before you can troubleshoot the problem you first have to address the basics specificly and eliminate those as the problem, troubleshooting starts with step 1 the basics and works forward to the solution
quote:
ORIGINAL: Muttdog
I would replace the ignition module with another one. DLE 30 was my first gasser. When I set up the plane and test run the engine it shut off on me and would not restart until I turned the ignition off and then back on. Didn't think anything of it as this was my first one and thought I screwed something up. I ran a tank on the ground after that and had a wonderful maiden day of flying. Then a week later after a successful flight in the morning, I had a dead stick 5 minutes into my flight. I recovered the plane in the field and turned off all switches. When I got it back it fired right up. We looked it over and found nothing so I decided to fly again and sure enough 5 minutes into the flight it deadsticked again. This time I tried to start it again out in the field and it would not start. I also noticed that when I looked at the digital tach I have under the canopy that there was no RPM being registered when flipping it over like I noticed before. All I did was turn off the ignition and back on again and it fired right up. got it back and drained the fuel to go home but wanted to fire it up to run it dry. This time it failed almost immediately and same thing as before, no rpm registering on the tach until I turned off the switch and turned back on. In the end DLE sent me a new ignition module under warranty and I have now put over 3 gallons of fuel with zero problems. Even though the issues are not exactly the same, they were both intermittent. Many of the ideas posted are valid but most don't cause intermittent problems like you are describing. Usually fuel system issues or air leaks are always there and do not come and go like you describe . A faulty ignition module/switch/battery/opto kill etc could most certainly cause an intermittent failure and ignition issues can very easily be mistaken for tuning/fuel issues. You could change the pickup as mentioned already but in my experience it is rare to see a hall effect sensor fail intermittently. usually they work or they don't unless there is a mounting problem. If you have the option to try another ignition I would do that first.
_____________________________
"Q" If you could have one super power what would it be?
"A" The ability to leap tall blondes without them screaming
Hide Signatures
(in reply to Muttdog)
       Post #: 27
RE: DLE 55 weirdness... - 1/29/2013 4:53 AM
thorpdrvr
Score: 100
Last Login: 5/11/2013
Status: offline
What voltage are you running on your ignition? If you don't have the high voltage ignition, the common thought is to stay below about 5 volt if I remember correctly. You might be pulling the voltage down a little with all of the tuning only to have the engine run good the rest of the flying session. Each time you go out you have the same problem because of the initial high voltage.
Hide Signatures
(in reply to warbird addict)
       Post #: 28
RE: DLE 55 weirdness... - 1/29/2013 7:41 AM
warrbirdcrasher
Score: 100
Last Login: 1/29/2013
Status: offline
Try a 40/1 mix on your fuel
Hide Signatures
       Post #: 29
RE: DLE 55 weirdness... - 1/29/2013 11:49 AM
RiverLarry
Score: 100
Last Login: 5/22/2013
Status: offline
start at squar 1          Tank     lines    carb    reeds   spark    !!!
at least start at the tank
it is not your prop !!!     any good oil     4 OZ  1 gal.  =  32 / 1        reg gas
4 OZ of any good oil is fine !!!        Amsoil  dont know    but  I wont use IT
need to go through your  fuel system        dont  hop around     that will drive you NUTS  !!
Hi Cap. John           R/L
Hide Signatures
(in reply to juliangarcia)
       Post #: 30
RE: DLE 55 weirdness... - 1/29/2013 12:03 PM
Cyberwolf
Score: 655
Last Login: 5/24/2013
Status: offline
(warbird addict)
( additionally higher octane fuel in a low compression engine as I'm told causes preignition of the fuel and a hotter running engine which also causes it's own set of tunability issues )
Sorry but that is just backwards, Octane was (is) added to gas to prevent preignition and detonation in higher compression engines, using it in a low compression engine as a rule does nothing to help power wise in a stock setup but sure will not make it have preignition or detonation.
Octanes job is to make a slower burn so you get a even flame front and the proper burn at the correct time.
Timing, carbon deposits, poor cooling and using the low octane gas in a high comp engines are a few of the issue related to both preignition and detonation.
If you can''t fix it with a hammer, you''ve got an electrical problem.
Hide Signatures
       Post #: 31
RE: DLE 55 weirdness... - 1/29/2013 12:21 PM
bmfer
Score: 100
Last Login: 4/13/2013
Status: offline
Well there are lots of thoughts. High octane fuel is not the prob. Get some 110 and run in it, it don't care but it will not make anymore power than 87 because you don't have the compression to benifit the high octane. 30 to 1 40 to 1 50 to 1. What ever it won't make it hard to start then run good after it starts. Get rid of the junk ashless oil and get something good. I like still ultra for airplane motors. This will most likely not fix the prob just help you in the long run. Most likely the needle is sticking in the carb and not allowing enough fuel in till it Loosens up from flipping the prop. Once it becomes lose it will work fine and work fine the rest of the day. Then it sets a few days and sticks again. Take carb apart and clean up good and really look good at the needle and seat. Air leak or tank filter or old gas bad oil mix will not magically fix itself and the engine start and run for the rest of the day. Anytime you have to start messing with needles to get it to start something is wrong!! As long as you have had it running in the past. If you get tired of it send it to me I will fix it. It's what I do fur a livin...
Just like some have said start with simple stuff and if all checks good you have to go deeper but you have to think what would cause it not to start good but once it does start it runs the rest of the day.
Hide Signatures
(in reply to warrbirdcrasher)
       Post #: 32
RE: DLE 55 weirdness... - 1/29/2013 1:57 PM
geebeenut
Score: 100
Last Login: 5/21/2013
Status: offline
try replacing diaphragm in carb may be dryed out and not pulseing like it should
Hide Signatures
(in reply to bmfer)
       Post #: 33
RE: DLE 55 weirdness... - 1/29/2013 1:58 PM
PropsnWings
Score: 110
Last Login: 5/23/2013
Status: offline
As Pe Rievers said, clean the carb.
Moving the needles and getting a better result, indicates you allowed a fine particle to pass that was restricting.
Change out to using a clunk filter, with no inline filter.
Hide Signatures
(in reply to bmfer)
       Post #: 34
RE: DLE 55 weirdness... - 1/29/2013 3:09 PM
redbiscuits
Score: 130
Status: offline
quote:
ORIGINAL: All Day Dan
It sounds like it's time to check the reeds, rebuild the carburetor and finally replace the sensor and ignition module. Dan.
+1.
Had a similar intermittent problem with my 30, liked to drove me crazy. Eventually swapped out ignition with my 55 and presto! Sent the ignition back to Hobbico, and they sent me a new unopened ignition no questions asked.
Gary-Waco Brother#171 If the build gets tough, always refrain from throwing things! ARCA, Austin Tx. www.austinrc.org
Hide Signatures
       Post #: 35
RE: DLE 55 weirdness... - 1/29/2013 3:42 PM
7kings
Score: 100
Status: offline
quote:
ORIGINAL: warbird addict
I'm sorry, but I have to disagree (which I hate to do when I've asked for help).
1: The DLE manual (which are actually the people who manufacture the engine, not Valley View), clearly states that their recommended fuel is between 87-93 octane, so this is not an issue per the manufacturer.
2: 2-cycle oil is not generally engineered to be mixed at a specific ratio to be effective. As I've stated, on many (if not most) 2-cycle oil containers, mix quantities are listed for various mix ratios. The proper ratio is determined by the engine manufacturer, who decides exactly how much oil is needed for their mechanical application to operate as intended. The oil does not care how it is mixed. On the oil I've been using (Husqvarna), it lists mix quantities for 32:1, 50:1, and 100:1.
3: Regarding the earlier statement that higher octane fuel is more likely to cause preignition on low-compression engines, it's just completely backwards. The higher the combustion chamber compression ratio, the more likely it is to cause preignition (caused by the heat generated by the compression of gasses), which is then countered by the cooler-burning of high-octane fuel. Low-compression engines are able to run low-octane fuel because they do not generate as much heat during the compression stroke, which is a leading factor when talking about preignition (there are other factors, but we're sticking to compression ratios here). Honestly, the only thing I would be concerned about by running high-octane fuel in a low compression (non-boosted) engine is the possibility of engine deposits down the road.
I'm not trying to be an a$$, and I appreciate the help, but I just wanted to clear that up so we're not traveling down a false troubleshooting path.
Thanks.
Hide Signatures
       Post #: 36
RE: DLE 55 weirdness... - 1/29/2013 3:47 PM
7kings
Score: 100
Status: offline
quote:
ORIGINAL: bmfer
Good solid advice. Thanks.
Hide Signatures
(in reply to bmfer)
       Post #: 37
RE: DLE 55 weirdness... - 1/29/2013 4:05 PM
pe reivers
Score: 646
Status: offline
Almost 100% true, since you mention engine deposits down the road.
Some oils have enough additives when used at lean mixes to keep the engine relatively happy. More oil in those cases lets the engine run at a higher power level, yet the engine will ingest more additives which in turn may pollute the engine in due time.
If the manufacturer states to use 2% to 3% of oil, the end user should not select an oil concocted for 1% mixes.
having said that, More or less oil, or higher octane fuel will never show up as the engine disturbances you have. NO WAY!
The problem you perceive is in intermittent fuel supply into the engine.
If the reeds were to blame, it would be a constant failure mode, which is not the case.
Fuel delivery problems could be:
1) carb failure to pump properly (bad external line connections?), carb foot gasket etc. (intermittent engine cut-out)
2) leaks in fuel suction line (failure to run well at all)
3) internal carb filter clogged, external clunk and inline filter collected dirt. Felt filters have best amount collecting features.
4) Regulating diaphragm has hardened (failure to adjust carb at all), or not engaging properly (binding in case of forked lever)
5) Debris inside carb passages (haphazard disturbances)
On several occasions I experienced changes in mixture in a haphazard way. In all cases a thorough carb cleaning solved the issue. It is astonishing what amount of debris I flushed out of those rogue carbs.
Pe, (www.mvvs.nl), MVVS, MOKImotor, RCexl, MTW, Xoar, Mejzlik.
Blessing in ignorance? There is sanctuary in analysis.
Hide Signatures
(in reply to 7kings)
       Post #: 38
RE: DLE 55 weirdness... - 1/29/2013 4:11 PM
MTK
Score: 203
Status: offline
quote:
ORIGINAL: 7kings
7Kings....tough poker hand to beat...
Just a thought, have you checked all the bolts for tightness and most importantly, seal, all around? Particularly the ones that mount the carb and reed cage to the rear cover. Also, have you carefully inspected the rear cover for cracks?
To me it sounds like an intermittent air leak.
Regards,
MattK
Hide Signatures
       Post #: 39
RE: DLE 55 weirdness... - 1/29/2013 4:53 PM
7kings
Score: 100
Status: offline
quote:
ORIGINAL: MTK
quote:
ORIGINAL: 7kings
I have spent quite a bit of time on and around that carb, checking to make sure everything is tight. I haven't looked for cracks, so that's something I can check.
Hide Signatures
(in reply to MTK)
       Post #: 40
RE: DLE 55 weirdness... - 1/29/2013 5:03 PM
kmeyers
Score: 125
Status: offline
One thing that has not been mentioned, THERE IS NO SUCH THING AS "FACTORY NEEDLE SETTINGS".
I have two 55's. I recomend a propeller that loads the engine enough to keep the RPM's down in the low 7000 range. I've been using a Bolly 23 x 8 which does this very well. It is not the only prop, but I keep the RPM's down to increase the longevity of the motor while making good power.
The tunning should always be done by the user on every occasion of different prop, fuel, oil ratio and large temp and humidity change.
If the factory setings are perfectly correct for one specfic time, it is just an accident.
After the normal steps are taken: fuel lines, battery charge, switch, clean the carb, spark plug,etc. You have to look else where.
I start as if at the beginning, redo everything.
< Message edited by kmeyers -- 1/29/2013 7:50 PM >
Oops!
Hide Signatures
(in reply to MTK)
       Post #: 41
RE: DLE 55 weirdness... - 1/29/2013 5:56 PM
7kings
Score: 100
Status: offline
quote:
ORIGINAL: kmeyers
After the normal steps are taken: fuel lines, battery charge, switch, clean the carb, spark plug,etc. You have look else where.
I start as if at the beginning, redo everyting.
I don't think I understand. Factory needle settings are specified in the DLE manual. Are you saying that they shouldn't be used as a hard-and-fast setting for all occasions? If so, I agree, but if the engine runs fine with them one day and not the next with no real change to the any factors except the relatively minor climate changes between the two days, I'm not sure they are to blame. That being the case, we've messed with the needles and always end up coming back to the factory settings by the end of the day, and the engine ticks like a clock at that point.
I definitely have some good information that you guys have offered so far, so I have several things to check.
Hide Signatures
(in reply to kmeyers)
       Post #: 42
RE: DLE 55 weirdness... - 1/29/2013 6:32 PM
kmeyers
Score: 125
Status: offline
quote:
ORIGINAL: 7kings
quote:
ORIGINAL: kmeyers
One thing that has not been mentioned, THERE IS NO SUCH THING AS ''FACTORY NEEDLE SETTINGS''.
Yes I am saying the factory settings are just where you start. If you don't tune from there it is unlikely that you have the best tune possible.
I don't touch my needles for months on end once tunned. I find that if the neeedles need to be touched it is something else wrong, like a dirty filter or loose fuel line.
This has been my experience with gas engines for more than 10 years and many different brands.
Oops!
Hide Signatures
       Post #: 43
RE: DLE 55 weirdness... - 1/29/2013 6:53 PM
freeonthree
Score: 100
Last Login: 4/4/2013
Status: offline
BarracudaHockey, I run Quicksilver 100% Full Synthetic with regular gas, and I run 100:1 in the winter, and 80:1 in the summer when the temps are between 90 and 110. The manual for my buds Bryson 50cc tells you to run Full Synthetic at 100:1. It sounds scarey, but once ya run it for a while, you will never go back. I run the same fuel in my weedeater and chainsaw also. Dennis
Have you hugged your RC Plane today ?
Hide Signatures
(in reply to BarracudaHockey)
       Post #: 44
RE: DLE 55 weirdness... - 1/29/2013 9:00 PM
pe reivers
Score: 646
Status: offline
quote:
ORIGINAL: 7kings
quote:
ORIGINAL: MTK
quote:
ORIGINAL: 7kings
Try a carb pressure pop-off tester. It also will reveal if the carb holds pressure, and if there are leaks around the carb nipples and carb innards.
I am sorry, I know not many pilots carry that kind of equipment, but it is needed to pinpoint the problem. ALL clients with engine problems that came to me left with a smile on their face. Small causes, BIG effects. "there's sanctuary in analisys." is my motto not for nothing.
Hide Signatures
       Post #: 45
RE: DLE 55 weirdness... - 1/29/2013 9:04 PM
pe reivers
Score: 646
Status: offline
quote:
ORIGINAL: 7kings
quote:
ORIGINAL: kmeyers
I am with Ken here.
Factory settings are right to get the engine started, wherever you are. Prop choice, humidity and elevation play large roles in setting up the right needle settings. No factory bla-bla can have it right for all applications, so you must use it as a start to get to your own specific target. "nuff said!
Hide Signatures
       Post #: 46
RE: DLE 55 weirdness... - 1/29/2013 9:07 PM
pe reivers
Score: 646
Status: offline
If it works for you, be happy. To post it here as general advice in solving a specific problem, i do not deem that very wise.
quote:
ORIGINAL: freeonthree
Hide Signatures
(in reply to freeonthree)
       Post #: 47
RE: DLE 55 weirdness... - 1/29/2013 9:11 PM
3136
Score: 135
Status: offline
Did you take the carb screen out and use compressed air on it, sometimes it can look ok but develop buildup which is hard to see till you actually take it out.
regards Mark
Hide Signatures
(in reply to pe reivers)
       Post #: 48
RE: DLE 55 weirdness... - 1/29/2013 9:20 PM
pe reivers
Score: 646
Status: offline
carb screen gum up, you are right! This however does not explain the OP problems.
PS
Carb screen cleaning I use paint brush softener, brushes and (an)  air blast(s). There seems to be no other way to get the damn stuff out of the fine mesh!
Hide Signatures
(in reply to 3136)
       Post #: 49
RE: DLE 55 weirdness... - 1/29/2013 9:54 PM
7kings
Score: 100
Status: offline
Actually, I used throttle body cleaner to clean the fuel screen. Worked like a charm.
Hide Signatures
       Post #: 50
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> RE: DLE 55 weirdness...
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.250RCU1
