Eneloop batteries for 12X    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> Eneloop batteries for 12X
Page: [1] 2   next >   >>
Login
Eneloop batteries for 12X - 1/30/2013 2:01 AM
Mike Haddox
Score: 100
Last Login: 5/25/2013
Status: offline
Ordered a set for my 12X. How do you charge them?
Hide Signatures
       Post #: 1
RE: Eneloop batteries for 12X - 1/30/2013 2:28 AM
jetspud
Score: 100
Status: offline
Mike
ni-mh at .2 milliamps
david
Hide Signatures
(in reply to Mike Haddox)
       Post #: 2
RE: Eneloop batteries for 12X - 1/30/2013 2:33 AM
hooker53
Score: 100
Status: offline
quote:
ORIGINAL: jetspud
Mike
david
+ 1 also. Don't be tempted to charge with a wall wart. It will do it but will take a lot of life and cycles out of your pack.
_____________________________
Scratch it till it bleeds Convert it till it chokes
Hide Signatures
(in reply to jetspud)
       Post #: 3
RE: Eneloop batteries for 12X - 1/30/2013 4:34 AM
C185Pilot
Score: 105
Last Login: 5/24/2013
Status: online
Exactly right about wall wart...they don't like to stay on trickle.
Hide Signatures
(in reply to hooker53)
       Post #: 4
RE: Eneloop batteries for 12X - 1/30/2013 5:02 AM
samdimaio
Score: 100
Status: offline
i have the eneloop batteries for 12x also and have no clue how to charge them either. Attempted charging with JR wall charger and now the charger dont work. What charger do I need and what are the proper settings?
Hide Signatures
       Post #: 5
RE: Eneloop batteries for 12X - 1/30/2013 5:36 AM
cyphur01
Score: 100
Status: offline
I use a thunderpower 610 set to .2a with 3mv/c. I have it set on auto voltage on nimh mode with the 610 but any good programmable charger will let you set 8cell nimh mode and adjust the peak mv. 200-300mah charge is max. If your pack false peaks, turn the mv up to 5 and try again. I have about 50-60 cycles on my pack and it still gets full capacity. Best upgrade I have ever done for that radio. The charger that came with the 12x cooked my stock battery from the beginning. It never recovered.
Hide Signatures
(in reply to samdimaio)
       Post #: 6
RE: Eneloop batteries for 12X - 1/30/2013 12:39 PM
megafly
Score: 100
Status: offline
Where I can get one pack of enelop for my 12x?
Thanks!
Hide Signatures
(in reply to cyphur01)
       Post #: 7
RE: Eneloop batteries for 12X - 1/30/2013 12:43 PM
luv2flyrc
Score: 102
Status: offline
I charge mine at 500ma with a PowerLab 8 on NiMh setting, I think I read that you can charge them at up to 1C, which would be 2amps. I'm not sure if the JR battery board that connects to the pack can take that much though, you might end up frying the little diode on it.
Mike
Hide Signatures
(in reply to megafly)
       Post #: 8
RE: Eneloop batteries for 12X - 1/30/2013 1:15 PM
Vincent
Score: 105
Status: online
I use a Peak Electronics (sirus) charger which is factory set for 1amp.I would say i have been running the eneloops for about the last 4-5 years with no issues.
Vin...
Hide Signatures
(in reply to luv2flyrc)
       Post #: 9
RE: Eneloop batteries for 12X - 1/30/2013 2:00 PM
Art ARRO
Score: 100
Last Login: 5/23/2013
Status: offline
Mike,
Go to www.electrodynam.com  for instructions on charging Eneloops.  Andy also has some chargers  that will do the trick. He provides info on the delta-V numbers to detect the peak for these cells.  I've converted all my tranny batteries to Eneloops with success and also trying them for low drain airborne applications-not jets.
Art ARRO
Hide Signatures
(in reply to Vincent)
       Post #: 10
RE: Eneloop batteries for 12X - 1/30/2013 2:31 PM
Greg Wright
Score: 102
Status: offline
I've always used the wall charger from my JR radio with out any issues. It just takes a little longer.
Greg Wright
Not a Horizon team member/ But would love to be one!!!!!!!!!!!! BVM Jets/Jetcat
Hide Signatures
(in reply to Art ARRO)
       Post #: 11
RE: Eneloop batteries for 12X - 1/30/2013 2:32 PM
Greg Wright
Score: 102
Status: offline
quote:
ORIGINAL: megafly
Thanks!
BVM sells the enloop battery packs.
Greg Wright
Hide Signatures
       Post #: 12
RE: Eneloop batteries for 12X - 1/30/2013 2:47 PM
CraigG
Score: 105
Status: online
quote:
ORIGINAL: Greg Wright
quote:
ORIGINAL: megafly
Thanks!
Sin City Jets also
http://www.sincityjets.com/store-batteries.htm
Hide Signatures
(in reply to Greg Wright)
       Post #: 13
RE: Eneloop batteries for 12X - 1/30/2013 2:59 PM
megafly
Score: 100
Status: offline
Thanks!
Hide Signatures
(in reply to CraigG)
       Post #: 14
RE: Eneloop batteries for 12X - 1/30/2013 3:36 PM
cyphur01
Score: 100
Status: offline
Duralite also sells eneloops
Hide Signatures
       Post #: 15
RE: Eneloop batteries for 12X - 1/30/2013 4:23 PM
rcjetsaok
Score: 135
Status: offline
Send your old 12X battery to Chad at Sin City Jets. He will remove the old batteries and install the Eneloop batteries and send it back ready to go !!! $ 49.99.. Can't beat a deal and service like that.. It's the way to do it.
Danno
The Hobby Express - Jet Central Tejas
Hide Signatures
       Post #: 16
RE: Eneloop batteries for 12X - 1/30/2013 4:25 PM
yeahbaby
Score: 135
Status: online
+1
"Audentes fortuna iuvat"
Hide Signatures
(in reply to rcjetsaok)
       Post #: 17
RE: Eneloop batteries for 12X - 1/30/2013 4:27 PM
Four Stroker
Score: 104
Last Login: 3/28/2013
Status: offline
As Vincent said, the Sirius Smart Charge "peak predict" chargers work really well with Eneloops. But mine is the old 500 mA.
Hide Signatures
       Post #: 18
RE: Eneloop batteries for 12X - 1/30/2013 5:09 PM
flycatch
Score: 118
Status: offline
If your transmitter is under warranty you will void it by using a nicad pack not honored by the manufacture.
Hide Signatures
       Post #: 19
RE: Eneloop batteries for 12X - 1/30/2013 5:16 PM
cyphur01
Score: 100
Status: offline
Ok.... The 12x was almost unusable with the stock nimh pack. I had to charge mine while I was out at the field to have a full day of flying. Also, eneloop packs are nimh not nicad. Same as stock. I would much rather have a radio that works without a warranty, even though i see no reason that replacing old batteries with newer technology of the same chemistry would void the warranty, than having a paperweight that I cannot use because of the 2 hour battery life.
Hide Signatures
(in reply to flycatch)
       Post #: 20
RE: Eneloop batteries for 12X - 1/30/2013 5:29 PM
flycatch
Score: 118
Status: offline
quote:
ORIGINAL: cyphur01
Call Horizon and see what they have to say. Most if not all r/c modelers never fly for two hours of flight time and that makes you an exception to the rule.
Hide Signatures
       Post #: 21
RE: Eneloop batteries for 12X - 1/30/2013 5:50 PM
cyphur01
Score: 100
Status: offline
If it voids the warranty it does. I like the eneloops. I really like my lipos in my 3 DX18s but that really is not an option
Hide Signatures
       Post #: 22
RE: Eneloop batteries for 12X - 1/30/2013 6:11 PM
rcjetsaok
Score: 135
Status: offline
quote:
ORIGINAL: flycatch
Who said anything about using NiCad Packs ???
D
Hide Signatures
       Post #: 23
RE: Eneloop batteries for 12X - 1/30/2013 6:23 PM
Mike Haddox
Score: 100
Status: offline
Thanks everybody for the info.
Two things. Chad does not have the batteries. He is out of stock.
Like Cyphur says " If it voids the warranty it does.
The radio is unusable with the stock set up. Thanks, Mike
Hide Signatures
       Post #: 24
RE: Eneloop batteries for 12X - 1/30/2013 7:55 PM
Four Stroker
Score: 104
Status: offline
I just bought two reload packs from Hangtimes Hobbies. They fit the 12X pack.
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.828RCU1
