canard .049 pusher queries.    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> "1/2 A" & "1/8 A" airplanes >> canard .049 pusher queries.
Page: [1]
Login
canard .049 pusher queries. - 1/30/2013 3:08 AM
mick1404
Score: 100
Last Login: 5/15/2013
Status: offline
hello all,
I'm contemplating designing a canard wing plane powered by a Cox .049 with remote choke and I was wondering if there was any mods or aftermarket add ons if needed to convert these awesome engines to a pusher configuration, and if there are any hints and tips that could help me out in any way. Also if there is anybody that has had success using an .049 as a pusher.
Any feedback would be greatly appreciated.
thanks again
_____________________________
suck, squeeze, bang, blow. Thermodynamics, love it.
Hide Signatures
       Post #: 1
RE: canard .049 pusher queries. - 1/30/2013 3:13 AM
Jaspur_x
Score: 100
Last Login: 3/5/2013
Status: offline
49 pusher is easy, I recomend adding or having a thrust washer on the crank,not all 049`s have them and the cases wear pretty rapidly under the stress.
A pusher prop works well.
Yes,I have done this many times with my airboats to get the best steering thrust from a COX reedie.
Keep us posted if you don`t do an entire build thread,I`m interested in your plane design
Hide Signatures
(in reply to mick1404)
       Post #: 2
RE: canard .049 pusher queries. - 1/30/2013 3:30 AM
GallopingGhostler
Score: 133
Last Login: 5/19/2013
Status: offline
Actually, what is recommended on a pusher is a brass prop drive plate. On a tractor engine (up front), the prop drive plate does not contact the aluminum crankcase, so there are no issues of rubbing contact and wear. On a pusher, it is desirable to have the drive plate of a harder material.
For the reed valve engines, you can buy a complete crankcase with brass drive plate, cost $6.95 US:
http://coxengines.ca/cox-.049-crankcase-crank-pusher.html
or just the brass drive plate if you are bold enough to replace it yourself, cost $1.95 US:
http://coxengines.ca/cox-.049-drive-plate-hex-brass.html
Shipping costs are extra. I couldn't find anything for the Tee Dees or Medallions.
George Hostler
Clovis MADS AMA Club, Vintage R/C Society (VRCS)
Hide Signatures
(in reply to Jaspur_x)
       Post #: 3
RE: canard .049 pusher queries. - 1/30/2013 8:41 AM
mick1404
Score: 100
Status: offline
quote:
ORIGINAL: GallopingGhostler
thanks mate, I will order the whole crankcase with brass drive plate as I don't like the idea of using a hammer on a Cox engine, I will post my progress once I finalize my design.
thanks again.
Hide Signatures
(in reply to GallopingGhostler)
       Post #: 4
RE: canard .049 pusher queries. - 1/30/2013 10:30 AM
SBS_Pilot
Score: 105
Status: offline
You might get some inspiration from this thread: http://www.rcuniverse.com/forum/m_4813640/anchors_4813640/mpage_1/key_/anchor/tm.htm#4813640
I actually have this plan, but I have already promised it to an other pilot/builder. If you are interested I can try to scan it before I post it to the recipient. If you are: send me a PM.
Best of luck with your build (and keep us posted)
/Stefan
Hide Signatures
       Post #: 5
RE: canard .049 pusher queries. - 1/30/2013 12:58 PM
mick1404
Score: 100
Status: offline
yes, i love it, I love unusual aircraft, especially ones that can fly ,lol
Hide Signatures
(in reply to SBS_Pilot)
       Post #: 6
RE: canard .049 pusher queries. - 2/10/2013 9:19 AM
mick1404
Score: 100
Status: offline
I was going to design a forward swept wing canard but decided not to, as I have plans for a canard wing model from D. Boddington (Dracon) and to my surprise, one of my Cox .049's has a brass drive plate fitted, so I have everything needed to make this model. I will keep you all posted.
Thanks to you all !!!
Hide Signatures
       Post #: 7
RE: canard .049 pusher queries. - 2/10/2013 8:59 PM
SGC
Score: 100
Status: offline
If your building the Dracon, I have a few suggestions, move the main(rear) wing forwards 1/2" and keep the CG in the same place relative to the fuselarge then reduce the amount of incedense on the forward plane (probably by about 1/2) this will result in a better flying model.
I built it as per plan for my son and with the wings and CG as shown it needed slight up elevator (canard flaps drooped) to fly level and would drop the nose savaglely when inverted makeing rolls a task. As designed the canard has a fairly high loading. An addition of 1" to the canard span would also be of benefit.
Stewart
Hide Signatures
       Post #: 8
RE: canard .049 pusher queries. - 2/11/2013 6:23 AM
mick1404
Score: 100
Status: offline
awesome, thanks, luckily I haven't started cutting out the wings as yet. Did you use a throttled Cox .049 with a remote tank on the model you built? As that's what I had in mind using and placing the tank and throttle servo as close as possible to CG. Also did you have to add any additional strength to the main wings as they don't look all that strong, I might be wrong but they look a tad flimsy.
Hide Signatures
(in reply to SGC)
       Post #: 9
RE: canard .049 pusher queries. - 2/11/2013 7:12 AM
SGC
Score: 100
Status: offline
I added a 1/8 x 1/4" spruce brace across the wing join, tcut to fit the taper required to match with the wing sweep, the model was powered with an unthrottled cox Black Widow 049 tanked motor. The model only reqiured a firm level launch, hold it level for 25-30yds then you can pull it up into a 40deg climb.
Hide Signatures
       Post #: 10
RE: canard .049 pusher queries. - 2/11/2013 9:36 AM
mick1404
Score: 100
Status: offline
sweet mate, I think it would be a good idea to incorporate a mainspar just to give the wing some strength, if you can think of any other pointers, please let me know.
Thanks again.
Hide Signatures
(in reply to SGC)
       Post #: 11
RE: canard .049 pusher queries. - 2/11/2013 8:41 PM
SGC
Score: 100
Status: offline
I built the wing as per plan, just added the spruce wing joiner that was 5-6" long and sheeted the underside of the wing centre section were it sat on the fuselarge only. The wing then was strong enough , my son used to wring it out pretty well.
Hide Signatures
       Post #: 12
RE: canard .049 pusher queries. - 2/11/2013 8:45 PM
BMatthews
Score: 247
Last Login: 5/14/2013
Status: offline
Mick, what I've always done to remove the drive washer is to stick an old prop screw into the crankshaft then with some 1/8 plywood pads use my bench vise to push the crank back into the case and out of the washer. Works slick as a whistle and avoids the hammer shock.
Putting them on is as easy as starting it on the spline then use a prop and screw to push it back into place.
Witty saying to be plagarized shortly.....
Hide Signatures
(in reply to SGC)
       Post #: 13
RE: canard .049 pusher queries. - 2/14/2013 1:28 AM
Jaspur_x
Score: 100
Status: offline
quote:
ORIGINAL: BMatthews
I second the motion of using this method
Hide Signatures
(in reply to BMatthews)
       Post #: 14
RE: canard .049 pusher queries. - 2/14/2013 11:28 AM
mick1404
Score: 100
Status: offline
sweet, beats using a hammer on such a sweet piece of engineering.
Hide Signatures
       Post #: 15
RE: canard .049 pusher queries. - 2/14/2013 11:30 AM
mick1404
Score: 100
Status: offline
oh I forgot to ask you, what washer would you recommend? Phenolic or Stainless Steel?
Hide Signatures
       Post #: 16
RE: canard .049 pusher queries. - 2/14/2013 1:32 PM
MajorTomski
Score: 113
Status: offline
Here was a great little canard from the late great Model Builder magazine
Click to see the file in new window.Attachment.pdf
Spitfire Brotherhood #6
Kadet LT 40 Brotherhood #98
Hide Signatures
       Post #: 17
RE: canard .049 pusher queries. - 2/15/2013 2:57 PM
mick1404
Score: 100
Status: offline
I love it MajorTomski, that will be my canard model #2 in my 'hangar'. Thanks again.
Hide Signatures
(in reply to MajorTomski)
       Post #: 18
RE: canard .049 pusher queries. - 2/24/2013 12:30 PM
mick1404
Score: 100
Status: offline
hi all,
I havent started building my Dracon canard yet, (nearly finished my Jim Vigani 'Scratch' and very busy with work commitments) and I was wondering if anyone had any ideas regarding the aileron linkages as I would like the model to have removable wings and not have the same system as the Dracon calls for where you would have to disconnect the clevises from control horns to remove wings.
Hide Signatures
       Post #: 19
RE: canard .049 pusher queries. - 3/2/2013 4:27 AM
mick1404
Score: 100
Status: offline
no problem, bit of engineering nouse got it sorted
Hide Signatures
       Post #: 20
RE: canard .049 pusher queries. - 3/10/2013 3:35 AM
OzMo
Score: 113
Last Login: 5/18/2013
Status: offline
here ya go
http://www.rcgroups.com/forums/showthread.php?t=1826664
Yes dear, I did glue my hand to the airplane to keep from dropping it.
Hide Signatures
       Post #: 21
RE: canard .049 pusher queries. - 3/10/2013 4:04 PM
mick1404
Score: 100
Status: offline
 that is also me on RCG, thanks anyway mate.
Hide Signatures
(in reply to OzMo)
       Post #: 22
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.078RCU1
