touch up spray guns???    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> touch up spray guns???
Page: [1]
Login
touch up spray guns??? - 1/30/2013 5:22 AM
Peter_OZ
Last Login: 5/17/2013
Status: offline
I'm after a gravity feed touch up spray gun???
Thoughts?
_____________________________
fun police have struck again
Hide Signatures
       Post #: 1
RE: touch up spray guns??? - 1/30/2013 5:28 AM
InboundLZ
Last Login: 5/12/2013
Status: offline
I have an Iwata jam gun, HVLP....sweet!
Dave Bottita
evoJet Factory Pilot
Smart-Fly
Hide Signatures
(in reply to Peter_OZ)
       Post #: 2
RE: touch up spray guns??? - 1/30/2013 5:30 AM
BobH
Last Login: 5/18/2013
Status: offline
Agree, Iwata Jamb gun.. superior
BobH.
Hide Signatures
(in reply to InboundLZ)
       Post #: 3
RE: touch up spray guns??? - 1/30/2013 8:01 AM
Peter_OZ
Status: offline
thanks guys
Hide Signatures
(in reply to BobH)
       Post #: 4
RE: touch up spray guns??? - 1/30/2013 12:06 PM
peter w h
Last Login: 5/13/2013
Status: offline
Been using this one for some time now, fits like a glove and sprays even better.
http://www.tcpglobal.com/spraygundepot/itemdetail.aspx?itemno=DEV+802405
Peter
Hide Signatures
       Post #: 5
RE: touch up spray guns??? - 1/30/2013 11:55 PM
Peter_OZ
Status: offline
quote:
ORIGINAL: peter w h
Peter
thanks. a mate of mine suggested the DeVilbiss touch up guns as well. How do you find the smaller 1mm tip? Can you fit a larger tip?
I'd be mainly spraying the entire surfaces of my warbirds. Say all the underneath in grey or uppers surfaces in dark grey prior to apply camo pattern. You get the idea.
cheers
Peter
Hide Signatures
(in reply to peter w h)
       Post #: 6
RE: touch up spray guns??? - 1/31/2013 12:04 AM
Peter_OZ
Status: offline
far out so many options with these things. anyone give advice as to type, tip size etc??
Hide Signatures
       Post #: 7
RE: touch up spray guns??? - 1/31/2013 11:36 AM
peter w h
Status: offline
 Everything in these pictures was sprayed with the DeVillbiss gun, no tip changes. 1MM is perfict and you can cut back on fluid/air to spray small parts like the gun turret pictured below.
Peter.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 8
RE: touch up spray guns??? - 1/31/2013 11:39 AM
carlbecker
Last Login: 4/29/2013
Status: offline
I use two Iwata's, airbrush and detail. Love them.
Hide Signatures
       Post #: 9
RE: touch up spray guns??? - 1/31/2013 12:10 PM
OVSS Boss
Status: offline
Anyone use any of the HVLP guns from Harbor Freight? I have had guys tell me that they are good buys. I am going to shoot my first wrabird this spring and am using latex and am going that way. I have a Grex airbrush for detail stuff.
Marc
Hide Signatures
(in reply to carlbecker)
       Post #: 10
RE: touch up spray guns??? - 1/31/2013 2:04 PM
glazier808
Status: online
quote:
ORIGINAL: OVSS Boss
Marc
I've got he detail gun and I love it.  It's still working like new after quite abit of paint.  A great deal I think.
casey
Fliteskin, Sierra, Nelson Hobby, MICKO aircraft, Getstencils, Holman Plans, VicRC, Castle Creations, Addicted to Luft
Hide Signatures
(in reply to OVSS Boss)
       Post #: 11
RE: touch up spray guns??? - 1/31/2013 2:09 PM
OldScaleGuy
Status: offline
quote:
ORIGINAL: OVSS Boss
Marc
I had one of their HVLP's and did not like it the way it worked and it was heavy. I am not sure if it the same gun as their detail gun. I use a Badger 100 detail gun and really like it.
Steve - Spitfire Brotherhood #144
Full size airplanes are real, our models are too.
Hide Signatures
       Post #: 12
RE: touch up spray guns??? - 2/2/2013 12:49 PM
Brad330l
Status: offline
Hi Pete, I sprayed my Spitty with a cheap gravity fed touch-up gun from home hardware and it was very easy to adjust and use. I think any of these things will be OK for what you want to do in the way of coverage for your model painting.
I was able to adjust it to a very fine spray and I'm sure if you muck around with paint mixture you could achieve many different results.
Save some money and get a cheapy, spend the rest on good gear.
Cheers cobba,
Brad
Visit pilbaraaeromodellers.com
Spitfire Brotherhood # 5
Hide Signatures
(in reply to OldScaleGuy)
       Post #: 13
RE: touch up spray guns??? - 2/3/2013 10:21 PM
Peter_OZ
Status: offline
G'day Brad,
how is life over in the West? Long time no chat. Hope Bazza is in good health. Say G'day for me.
Yeah thought about a cheapy but last cheapy I bought was junk wo will most likely lash out and buy a good one, DeVilbriss most likely. Wont be till about June as I will be moving in April and will take some time to get my workshop setup again
cheers
Peter
Hide Signatures
(in reply to Brad330l)
       Post #: 14
RE: touch up spray guns??? - 2/4/2013 4:28 AM
BobH
Status: offline
A few bits of information about the Iwata vs the other guns mentioned. The Iwata sprays a fine enought mist that Luthiers (guitar and voilin) makers use them to spry the clears over their work. That's really good atomizing!
The second thing: you only have to buy one good gun vs the cheap ones. The cheap guns don't last.. sorry but its just the way it is.. ask the pro car painters what they use.
thirdly you can tell the difference in paint quailty on a model using a cheap vs quality gun.
just my thoughts.
BobH.
Hide Signatures
       Post #: 15
RE: touch up spray guns??? - 2/4/2013 4:45 AM
Peter_OZ
Status: offline
Bob, concur mate which is why I want a good one but which one and what spec?? Seems to be a bunch of tip sizes availabile but for spraying a model which is best?
I'm not talking about small airbrush type work here such as you would use on camoflage etc.
cheers
Peter
Hide Signatures
(in reply to BobH)
       Post #: 16
RE: touch up spray guns??? - 2/4/2013 7:09 AM
G T
Status: offline
HI Pete
this is a good all around spray gun,, you will be able to do touch up etc
as Brad said you just need to mix ( thin ) the paint down to do your camo blend in areas
Iwata LPH80 Mini Gravity Fed Spray Guns
LPH80 Miniature HVLP Spray Gun Set-Ups Chart
Model Nozzle Size (mm) PSI CFM Pattern Width (inch) Air Cap Model Gun Only PCG2B-1 (150ml) #6036 Usage Applications
LPH80-042G 0.4 13.0 1.8 1.6 E2 4900 4901 Spot Repair
Graphics
Woodwork
Hobby
(Touch-ups,
Shading)
LPH80-062G 0.6 2.4 4905 4906
LPH80-082G 0.8 3.2 4910 4911
LPH80-102G 1.0 3.9 4915 4916
LPH80-122G 1.2 4.7 4920 4921 - " THIS ONE MATE "
LPH80-124G 1.2 2.1 5.5 4930 4931
Hide Signatures
       Post #: 17
RE: touch up spray guns??? - 2/4/2013 7:12 AM
Peter_OZ
Status: offline
cool thanks bloke
Hide Signatures
(in reply to G T)
       Post #: 18
RE: touch up spray guns??? - 2/4/2013 8:18 AM
dadragon
Last Login: 3/14/2013
Status: offline
I have the Harbor FRT gravity hvlp and I used it for latex and it sprays just fine,do your latex in lite coats it will dry quicker between coats.
Hide Signatures
       Post #: 19
RE: touch up spray guns??? - 2/4/2013 11:06 AM
Brad330l
Status: offline
quote:
ORIGINAL: Peter_OZ
cool thanks bloke
Hi mate and "hi to ya"
All good here,,,, hot but good.
Baz is back from Perth soon after more treatment (6 weeks worth). Good on that front as well.
Cheers,
Brad
Hide Signatures
       Post #: 20
RE: touch up spray guns??? - 2/4/2013 3:22 PM
John Redman
Status: offline
My preference is the SATA Mini Jet with a 0.8 mm nozzle.
Have been using this for the past 12 years with great results.
http://www.sata.com/index.php?id=1109&L=1
John Redman
Team Horizon, JetCat USA Rep
Hide Signatures
       Post #: 21
RE: touch up spray guns??? - 2/4/2013 4:38 PM
BobH
Status: offline
Sata is another Profession brand spray gun, made in Germany I think. Again not cheap but gives excellent results.
Latex paint is pretty easy to spray once thinned properly with just about any gun. But if you want to go to other type paints.. then cheap guns suffer.
Pete, my Iwata has the standard needle/tip size. Don't remember what it is at the moment? But I think GT put you in the right direction.
FYI I have a few Iwata air brushes as well.. good products.
BobH.
Hide Signatures
(in reply to John Redman)
       Post #: 22
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.688RCU1
