E-Flite Power 15 high RPM vibration    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Electric Aircraft Universe >> E-Flight Power Sources >> E-Flite Power 15 high RPM vibration
Page: [1]
Login
E-Flite Power 15 high RPM vibration - 1/30/2013 5:32 PM
Striker
Score: 100
Last Login: 3/25/2013
Status: offline
Hi Guys,
I know this is a shot in the dark question but dont know if anyone here has the same problem.
I have put together an Acro Master and got a new E-Flite Power 15 brushless motor for it. I have not flown this thing as yet all because I am getting a violent vibration at high RPMS just around 6500 RPM.
I have a perfectly balanced APC 13X6.5 prop and an E-Flite prop hub. If the battery's peak power drops, it runs OK. I can reduce my throttle by about 10% but that's a band aid patch approach which I hate, it does this 2 clicks below full throttle.
I have read that some people said these motors are not balanced well etc. All I did to it was to use my vice and a socket to push the shaft to the other end since it has to be front mounted. I am an electronic tech and a huge mechanical background so I cant see it being screwed up by that.
Anyone had these issues with this motor? This is annoying me to the core.
Thanks.
_____________________________
Pilots are Kings when they smashed their wings and say ah s**t, just a couple of dings.
The greatest high is... Hitec
Hide Signatures
       Post #: 1
RE: E-Flite Power 15 high RPM vibration - 1/31/2013 10:27 AM
whitecrest
Score: 106
Last Login: 5/23/2013
Status: offline
Is there any vibration with the prop off? That ought to rule out any fundamental motor imbalance. I would think a mechanical imbalance in the prop or hub would be evident well before 6500RPM. It might be worth trying a slightly smaller prop or programming higher ESC timing. Timing issues usually crop up when a motor is being pushed.
Another thought is to check the motor mount for any looseness or play.
Tim
Hide Signatures
(in reply to Striker)
       Post #: 2
RE: E-Flite Power 15 high RPM vibration - 1/31/2013 1:31 PM
Striker
Score: 100
Status: offline
Everything is tight and balanced, I am beginning to think after doing some more testing that its a resonance issue.
Hide Signatures
(in reply to whitecrest)
       Post #: 3
RE: E-Flite Power 15 high RPM vibration - 2/7/2013 11:22 AM
chuckk2
Score: 106
Last Login: 5/22/2013
Status: offline
The ESC may be faltering at higher settings, or the battery cannot supply the current required.
Hide Signatures
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.220RCU1
