Georgetown TX, Club 40 March 16, 2013    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Pylon Universe - RC Pylon Racing >> Club 40 >> Georgetown TX, Club 40 March 16, 2013
Page: [1] 2 3   next >   >>
Login
Georgetown TX, Club 40 March 16, 2013 - 1/31/2013 2:32 PM
Oldbob
Score: 105
Last Login: 6/19/2013
Status: offline
OK club 40 junkies, Georgetown TX is hosting its first race of 2013 season, on March 16, 2013. See the attached flyer and pay particular attention that we will not have the A, B etc. Mains. The new NMPRA matrix program we are using does not lend itself easily to do this. Therefore, however and instead of, we will be flying 5 or 6 rounds of racing, depending on how much time we have, and all rounds will count toward the final score. That way we do not have to change wing tags between the final heats of the day. also this allows everyone to have a full day of racing.
See you at the race,
Bob
Click to see the file in new window.Attachment.pdf
< Message edited by Oldbob -- 1/31/2013 5:12 PM >
Hide Signatures
       Post #: 1
RE: Georgetown TX, Club 40 March 16, 2013 - 2/1/2013 12:45 AM
skull1971
Score: 105
Last Login: 6/16/2013
Status: offline
So is Texas going to enforce the "No bladder tank" rule?
_____________________________
ERIC DESARDI, Revver Bro. 159, NMPRA 59i
Moe''s Cycle Service, New Creations-RC
Hide Signatures
(in reply to Oldbob)
       Post #: 2
RE: Georgetown TX, Club 40 March 16, 2013 - 2/1/2013 12:56 AM
squidman
Score: 100
Last Login: 5/21/2013
Status: offline
I hope not, I have a small bladder.
throttling back during a crash means you are a "quitter"
Hide Signatures
(in reply to skull1971)
       Post #: 3
RE: Georgetown TX, Club 40 March 16, 2013 - 2/1/2013 2:05 PM
Oldbob
Score: 105
Status: offline
Skully, that depends on what the majority of the pilots want. I intended to have this discussion at our last race in November, but forgot. As you know, it is the current RCORO rule, but as we have seen each region has modify the rules to suit their needs. So if the majority of Texas Club 40 pilots wish to leave the rule as it was last year, that is what we will do, if not, we will enforce the 2013 RCPRO rule. Since the Dallas area has schedules some Club 40 races I would include them in the mix of pilots making the decision. This goes for the Houston area pilots as well.
FYI, I have used the bubble less tank in the past and found no speed advantage, and a lot of extra work, which is just my opinion. I use the stock tank and fill it full for practice and use only 4.5 oz. for a race.
The 30 second idle rule will be checked on all planes during the first round of heats. Any backup plane will be checked in the first heat it is used.
Bob
Hide Signatures
(in reply to squidman)
       Post #: 4
RE: Georgetown TX, Club 40 March 16, 2013 - 2/1/2013 7:59 PM
skull1971
Score: 105
Status: offline
Thanks Bob, my vote is to let us use them this year, and then weed them out in the future. I just bought two last year and would hate to think I wasted the $$$. Good job on making the engines idle too, mine always have.
Hide Signatures
       Post #: 5
RE: Georgetown TX, Club 40 March 16, 2013 - 2/2/2013 4:54 PM
gefisher
Score: 100
Status: offline
I like the idle rule being enforced at the start of the first heat! And I also would like to keep this Club 40 class stock box! With agreeing with Skully I think the bubbles tanks should be weeded out after this year! I like Bob do not think they are a speed advantage but they are an added expense we don’t need in the Club 40 class. I had talked about another point standing for the Texas Club 40 area in the thread (Club 40 Schedule for central TEXAS 2013 - 1/23/2013 7:57 AM) and didn’t get any replies on it so I’m not going to worry about the extra work involved in it...
Gary
Hide Signatures
       Post #: 6
RE: Georgetown TX, Club 40 March 16, 2013 - 2/5/2013 3:12 PM
ienjoyrc
Score: 100
Status: offline
Gary, I personally think that we should do it for the 3 central texas clubs. It might lend itself to everyone wanting to make every race. And people will know how they are ranking against other racers. I believe that the lack of response could be because people are not looking at RC Universe as much as they will when we get closer to the races. If you want, put your question out on the email list and see if there's a response. Just my 2 cents. Charles
Hide Signatures
(in reply to gefisher)
       Post #: 7
RE: Georgetown TX, Club 40 March 16, 2013 - 2/5/2013 4:47 PM
Tbatt
Score: 105
Last Login: 6/10/2013
Status: offline
We thought about an idle rule but could not agree on the rpm. With some guys running a 9 inch prop and others with a 10 inch you can expect different idle speeds due to the larger prop having a better flywheel effect. Have you given this any thought?
I suggest you take rpm readings of about ten engines and see what you can reliably get.
My two cents worth.......
Tim
Hide Signatures
(in reply to ienjoyrc)
       Post #: 8
RE: Georgetown TX, Club 40 March 16, 2013 - 2/5/2013 5:29 PM
dasintex
Score: 126
Last Login: 6/20/2013
Status: online
Correct me if I'm wrong; the Idle rule is in place to verify that an Engine can sit there and Idle for at least 30 Seconds, to eliminate those engines that run Wide Open Throttle much like some of those race Engines that are not allowed, or that the Mixture Screws been modified/removed; I don't believe the idle rule has a specific RPM, again, I could be wrong, but that's the way I understood the rule; Bob will clarify this for sure.
P-40 Brotherhood #3
Spitfire Brotherhood #29
Hide Signatures
(in reply to Tbatt)
       Post #: 9
RE: Georgetown TX, Club 40 March 16, 2013 - 2/5/2013 8:51 PM
gefisher
Score: 100
Status: offline
Doug you are correct! The idle rule is just for that verification of a possible modification on the carburetor! I have tested my share of props of all sizes and my plane will set and idle with any prop I put on the Thunder Tiger.
Charles, that was my thought in last year’s point standing, is to try and keep the pilots coming to the races and I’m not sure it worked! We still had the same guys going to the races from before and the other pilots just picking and choosing the race they want! Not everyone is dye hard racers like some of us....[>:]
Gary
Hide Signatures
(in reply to dasintex)
       Post #: 10
RE: Georgetown TX, Club 40 March 16, 2013 - 2/6/2013 3:32 AM
cwesh
Score: 105
Last Login: 6/18/2013
Status: online
Hi Guys,
If I remember, wasn't it also required that the plane sit idling for those 30 seconds by itself? i.e., no one holding on to it?
Chuck.....
Hide Signatures
       Post #: 11
RE: Georgetown TX, Club 40 March 16, 2013 - 2/6/2013 11:59 AM
gefisher
Score: 100
Status: offline
Yes that is the rule!
Hide Signatures
(in reply to cwesh)
       Post #: 12
RE: Georgetown TX, Club 40 March 16, 2013 - 2/6/2013 12:17 PM
Oldbob
Score: 105
Status: offline
Chuck is correct, back when the Club 40 event started one the main ideas was to make the takeoff more like a typical day at the flying field, rather than a racing event with engines running at WOT while your buddy is holding the plane. That’s when everyone started their engines at the starting line and then walked back to the flight line while their engine sat idling at the starting line. AH! Those were the days—
However because of many mid-ground crashes during takeoff it was decided to have the engine running at WOT with a buddy holding the plane until the flag dropped. This reduced the number of mid-ground crashes. Now the idle rule helps ensure that the engine is a stock sport engine rather that a purpose built racing engine or a modified sport engine..
Bob
Hide Signatures
(in reply to cwesh)
       Post #: 13
RE: Georgetown TX, Club 40 March 16, 2013 - 2/15/2013 2:56 AM
Oldbob
Score: 105
Status: offline
OK all you fast time trophy seekers, the club cook want to know how many hamburgers, hotdogs and drinks we need to have on hand for all you hungry flyers and friends. So please let me know if you are coming. I also need your AMA number so I can start putting the matrix together.
Bob
Hide Signatures
       Post #: 14
RE: Georgetown TX, Club 40 March 16, 2013 - 2/15/2013 3:58 AM
Plane Insane
Score: 100
Last Login: 6/17/2013
Status: offline
Do you want it posted in the thread or via private message?
Hide Signatures
       Post #: 15
RE: Georgetown TX, Club 40 March 16, 2013 - 2/15/2013 10:00 AM
Oldbob
Score: 105
Status: offline
Plane insane, either way will work. If you do both I will only count you once but charge double entry fees.
Bob
Hide Signatures
(in reply to Plane Insane)
       Post #: 16
RE: Georgetown TX, Club 40 March 16, 2013 - 2/15/2013 11:52 AM
gefisher
Score: 100
Status: offline
Hey Bob, I’m only posting my AMA one time cause I hat that double entry fee! # 762602
Gary
Hide Signatures
       Post #: 17
RE: Georgetown TX, Club 40 March 16, 2013 - 2/15/2013 12:49 PM
Tx_RcFlyer
Score: 105
Status: offline
Mike Buckalew and Myself are making the drive up from the Alvin Club.
Mike - 48505
Ted - 624330
Will the field be open Friday Afternoon\Evening for practice?
Hide Signatures
       Post #: 18
RE: Georgetown TX, Club 40 March 16, 2013 - 2/15/2013 2:41 PM
ienjoyrc
Score: 100
Status: offline
Charles Krempin 459571
George Bales 132224
Debra Bales
Tim Cooper 860484
I'll pay double if we have ribeyes, loaded baked potatoes, and salad
Hide Signatures
       Post #: 19
RE: Georgetown TX, Club 40 March 16, 2013 - 2/15/2013 4:31 PM
Plane Insane
Score: 100
Status: offline
I'll keep it simple then..
David Frisk   AMA# 637314
I'll see if I can get the other guy's info to add unless they do it themselves.
Here are their names:
Toby Frisk
Damon Darnall
Cory Campbell (tentatively based upon work schedule)
quote:
ORIGINAL: Oldbob
Bob
Hide Signatures
       Post #: 20
RE: Georgetown TX, Club 40 March 16, 2013 - 2/16/2013 2:28 AM
squidman
Score: 100
Status: offline
put me in the mix Bob. #476747
there should be more coming in from Waco.
Hide Signatures
       Post #: 21
RE: Georgetown TX, Club 40 March 16, 2013 - 3/9/2013 10:04 PM
Oldbob
Score: 105
Status: offline
FYI for all club 40 pylon racers, the grass at the Georgetown field has been cut and the Pylons are up. The field is in excellent shape and will be open all week for practice.
Bob
Hide Signatures
       Post #: 22
RE: Georgetown TX, Club 40 March 16, 2013 - 3/10/2013 2:17 AM
Plane Insane
Score: 100
Status: offline
Hi Bob,
What is the protocol for non-club members coming by to practice?  Are there times you guys are planning to be out there during the week?
David
Hide Signatures
       Post #: 23
RE: Georgetown TX, Club 40 March 16, 2013 - 3/10/2013 7:39 PM
Tx_RcFlyer
Score: 105
Status: offline
quote:
ORIGINAL: Oldbob
Bob
Hey Bob,
How late will the field be open on Friday evening for practice?
Hide Signatures
       Post #: 24
RE: Georgetown TX, Club 40 March 16, 2013 - 3/10/2013 9:16 PM
gefisher
Score: 100
Status: offline
Until you shut the gate on your way out!
Gary
Hide Signatures
(in reply to Tx_RcFlyer)
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.266RCU1
