will lengthening the sticks slow down the control    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Electric Aircraft Universe >> 3D Electric Flying! >> will lengthening the sticks slow down the control
Page: [1]
Login
will lengthening the sticks slow down the control - 2/2/2013 10:41 AM
suzonka
Score: 100
Last Login: 5/14/2013
Status: offline
will lengthening the sticks slow down the control of the ailerons ,elevator and rudder,
I have a new girl in the anger I never experienced a 540 electric edge by 3D Hobbies, with out exponential I have lowered the aileron rates as much as possible for this model to eliminate the snaps, or twitchy control because of its barn door ailerons, so if I lengthen the control sticks on my transmitter to the max, make them longer will this really help me gain a little more smoothness or control?
Hide Signatures
       Post #: 1
RE: will lengthening the sticks slow down the control - 2/2/2013 11:58 AM
CHassan
Score: 105
Last Login: 5/17/2013
Status: offline
It could. Making the sticks longer will require you to move the sticks FARTHER to get the same controls throws. That is if you fly on or near the tips of the stick.
_____________________________
The knack of flying is learning how to throw yourself at the ground and miss.
--Hitchhikers Guide to the Galaxy--
Hide Signatures
(in reply to suzonka)
       Post #: 2
RE: will lengthening the sticks slow down the control - 2/2/2013 12:16 PM
flyinwalenda
Score: 156
Last Login: 5/19/2013
Status: offline
If you have been using the radio for some time it may throw you off a bit flying your other planes. What I do with a new , aerobatic plane is the take the recommended low rate settings and cut them almost in half and the same with the high rate settings. Take off on high rates then switch to low when it's in the air. Usually for me the elevator is touchy as well as the ailerons until I get a feel for it. After initial trimming and a few flights the H/L rates can be adjusted a bit . I try to not use exponential as I feel it's better to learn to fly the plane rather than the radio doing it BUT I have used it initially , in small amounts ,on some  planes for the first couple of flights and slowly removed it afterwards.
Brian Ray
Hide Signatures
(in reply to CHassan)
       Post #: 3
RE: will lengthening the sticks slow down the control - 2/11/2013 3:53 PM
Beachcomber
Score: 100
Last Login: 4/21/2013
Status: offline
If you don't want to lower your "rates" any further, your radio might also have "travel adjust" you can reduce the full stroke of each servo. What you are looking for is "expo" to soften the controls near center, but reducing "rates" and/or "travel adjust" is second best solution.
Hide Signatures
(in reply to flyinwalenda)
       Post #: 4
RE: will lengthening the sticks slow down the control - 2/11/2013 5:18 PM
countilaw
Score: 219
Last Login: 5/18/2013
Status: offline
You can also use   shorter   control arms on the servos,    and move the   push rod   to the  outer most hole on the   control  horn.
Frank
It''s a hobby, not a job.
Hide Signatures
(in reply to Beachcomber)
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.719RCU1
