Charging transmitter with CG 340 charger
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Hitec/MultiPlex Radios- Ask Hitec Customer Service >> Charging transmitter with CG 340 charger
Page: [1]
Login
Charging transmitter with CG 340 charger - 4/23/2002 7:52:36 PM
peso
Status: offline
Hitec has a new low cost charger the CG 340. Is it possible to charge a Hitec transmitter with this charger without shortcircuiting the protection diod in the transmitter.
       Post #: 1
Charging transmitter with CG 340 charger - 4/30/2002 9:40:05 PM
MikeMayberry
Status: offline
You will need to connect to the battery directly. If you can't find the adapter you can get it from http://www.maxxprod.com
Mike.
(in reply to peso)
       Post #: 2
Charging transmitter with CG 340 charger - 4/30/2002 10:08:52 PM
hilleyja
Status: offline
Mike,
Why would you need to remove the battery to charge it? I thought the diode only inhibited the discharge of the battery. I charge my Eclipse TX battery all the time with both my Hobbico and Hitec Field chargers -- their both peak chargers. When I want to cycle it I remove it and connect it to my Hobbico Accucycle Plus.
_____________________________
Jim Hilley
AMA #671825
RCCA# 758
Twist 150 Brotherhood #14
(in reply to peso)
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.469RCU1
