OS GT33 shaft dia 8mm vs 10mm prop hole    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Moki 2.10
Seller:  thunderbolt-RCU
Details:   $250.00   |  5/18/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> O.S. Engines Support >> OS GT33 shaft dia 8mm vs 10mm prop hole
Page: [1]
Login
OS GT33 shaft dia 8mm vs 10mm prop hole - 2/6/2013 11:13 PM
Ken Cz
Score: 105
Last Login: 5/11/2013
Status: offline
Need some help.
Bought a new OS GT33 engine and discovered that the prop shaft is 8mm dia.
All the common gas props these days like Xoar. Mejzlik, PT CF, and the rest all have a 10mm shaft hole - leaving a difference of 2mm.
Does anyone know where I can find a bushing to fit inside the prop to make up the difference?
Not sure if the APC plastic bushings that come with props will work but I would prefer a metal one.
Any ideas or help? Seems like quite an oversight by OS.
Thanks!
Ken
Hide Signatures
       Post #: 1
RE: OS GT33 shaft dia 8mm vs 10mm prop hole - 2/7/2013 3:19 PM
Bax
Score: 169
Last Login: 5/21/2013
Status: offline
If you can machine parts, you can machine a piece of brass tubing to the desired inside and outside diameters. You can buy a propeller with a smaller hole and drill it to fit...most wood props are like that. Finally, you can wrap the shaft with tape to build it up.
_____________________________
Bill Baxter, Manager Hobby Services/Futaba Service/North America
3002 N. Apollo Dr. Ste. 1 Champaign, IL 61822 USA
Service Phone: 217 398-0007
Email: hobbyservices@hobbico.com
Hide Signatures
(in reply to Ken Cz)
       Post #: 2
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> O.S. Engines Support >> OS GT33 shaft dia 8mm vs 10mm prop hole
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.172RCU1
