How to find CG on unknown plane    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Aerodynamics >> How to find CG on unknown plane
Page: [1]
Login
How to find CG on unknown plane - 2/8/2013 12:00 AM
mikes68charger
Score: 106
Last Login: 5/19/2013
Status: offline
 I got a Spacewalker 2 from a friend who passed away. I can't figure out who makes it. I think it may be a Sig Kit but not sure
Been reading about CG calculator. But I'm scared of getting it wrong.
its got a very simple rectangle wing.
Its 13.5 in wide and 82in long.
I know. CG is 25-30% of the with
so I'm I right in thinking my CG is 3.5-4in?
thanks
Hide Signatures
       Post #: 1
RE: How to find CG on unknown plane - 2/8/2013 12:54 AM
flyinwalenda
Score: 156
Status: online
Looking at the manual for a Seagull Spacewalker2 120 (wing is 82.7 X 13.15) the recommended CG is 4.3 inches back from the LE.
Yes , for a constant cord wing you take the cord measurement time 25 -30 percent.   I normally balance at 27% and go from there.
_____________________________
Brian Ray
Hide Signatures
(in reply to mikes68charger)
       Post #: 2
RE: How to find CG on unknown plane - 2/8/2013 4:50 AM
Lnewqban
Score: 163
Last Login: 5/6/2013
Status: offline
Yes, 3.5" will be a safe start.
For more precise calculation, the on-line calculator listed in the sticky thread above includes the tail.
Maiden a little nose heavy and remove nose weight at taste a test flight at a time.
Lnewqban - "The recipe for perpetual ignorance is: be satisfied with your opinions and content with your knowledge." - E. H.
Hide Signatures
       Post #: 3
RE: How to find CG on unknown plane - 2/8/2013 2:38 PM
charlie111
Score: 100
Status: offline
I am Old School But, you can always get close on a staight wing by balancing the plane from about 1/3 back from leading edge.A bit more complex with a swept wing.Try balancing it from a point that bysects the wing in the middle when a line is drawn connecting wingtips.See what happens when you hold the plane at the front of wingtips on swept wing?AS you would never add water to a Habitat Soup.Never make your plane (Tail Heavy) It will try to stall in lavel flight !
Charlie111 Looking for two h.p. motors with single channel speed control.High Performance maybe equal to o.20 or 0.49
Hide Signatures
(in reply to flyinwalenda)
       Post #: 4
RE: How to find CG on unknown plane - 2/9/2013 12:38 AM
GaryHarris
Score: 168
Last Login: 5/16/2013
Status: offline
Main spar?
Sig Kadet Brotherhood #1
Ultra Sport Brotherhood #105
Hide Signatures
(in reply to charlie111)
       Post #: 5
RE: How to find CG on unknown plane - 2/9/2013 2:29 AM
da Rock
Score: 265
Status: offline
quote:
ORIGINAL: GaryHarris
Main spar?
Really should mention the main spar isn't a good location if it's not straight. (Wing isn't swept)
Good flying wit ya today
Hide Signatures
(in reply to GaryHarris)
       Post #: 6
RE: How to find CG on unknown plane - 2/9/2013 2:35 AM  2 votes
da Rock
Score: 265
Status: offline
The really simple suggestions usually leave out a whole bunch of details.
It's really simple to make the measurements online applications ask for. It's dead simple and takes almost no time to do it.
Measure the wing's tip chord, root chord, half span, and sweep.
Measure the same things for the horizontal stab.
Measure from the LE of the wing to the LE of the stab.
How hard is that?
The applications deal with wing sweep, taper, etc and consider all the things that matter for pitch stability. The real simple techniques don't.
Hide Signatures
(in reply to da Rock)
       Post #: 7
RE: How to find CG on unknown plane - 2/10/2013 2:42 AM
karolh
Score: 310
Status: offline
It can be quite confusing for a first timer knowing just what to use as the CG as there is calculated CG and there is also the suggested %f MAC to arrive at a balance point which is significantly different from the CG dimension, all of which can really muddle the water.
When inverted always remember that down is up and visa versa
Hide Signatures
       Post #: 8
RE: How to find CG on unknown plane - 2/10/2013 11:59 AM
JohnBuckner
Score: 342
Status: online
quote:
ORIGINAL: mikes68charger
Your Spacewalker will fly best at 25% mac. Divide the 13.5 inch chord by four and measure back from the leading edge by that amount and that is where you balance the airplane at.
John
"Keep your controllines tight"
Hide Signatures
       Post #: 9
RE: How to find CG on unknown plane - 2/10/2013 8:24 PM
da Rock
Score: 265
Status: offline
quote:
ORIGINAL: karolh
With the online calculators, if they can work a yardstick, that's all they need be able to do.
They don't do anything except measure some things, type in the measurements, then hit a key.
Hide Signatures
(in reply to karolh)
       Post #: 10
RE: How to find CG on unknown plane - 2/11/2013 12:01 PM
AA5BY
Score: 153
Status: online
I can understand the trepidation of trusting a calculator but maybe can help lay it to rest. Last winter I designed & built a 35cc model and used the calculator for the CG. It nailed the position. I've played both fore and aft and came back to the position, which provided a neutral elevator, no pitch coupling in knife edge and common power on/off trim.
btw... 4.3" is a good number for the Seagull Spacewalker II 1.20. Upgraded recently to LiFe batteries and rebalanced and flew mine last week and it flew great with that number.
Hide Signatures
       Post #: 11
RE: How to find CG on unknown plane - 2/12/2013 7:23 PM
buzzard bait
Score: 115
Status: offline
I've been using the formula the calculators use for about 30 years with great success. The neutral point depends on the wing area, stab area, length of tail arm, and the average chord of the wing. Once you know where it is you can decide how stable you want your plane to be and calculate a CG based on that.
People always recommend rules of thumb when this question comes up. They work a lot of the time because designers do things in similar ways. But you can do much better than just balancing on the spar or 25% back from the LE or 30%. Yes, those rules will usually allow the plane to fly, but you can do much better with a formula or calculator.
Jim
Hide Signatures
(in reply to AA5BY)
       Post #: 12
RE: How to find CG on unknown plane - 2/12/2013 7:28 PM
mikes68charger
Score: 106
Status: offline
Thanks guys,
I flew it 8 times yesterday. I put the CG a little ahead of 4 in, and it flew great, but it was hard to get a smooth landing, it seemed to fall out the sky the last foot or so.
So I guess I need to more the cg more to the rear.
Hide Signatures
(in reply to AA5BY)
       Post #: 13
RE: How to find CG on unknown plane - 2/12/2013 9:21 PM
karolh
Score: 310
Status: offline
Yup.
Hide Signatures
       Post #: 14
RE: How to find CG on unknown plane - 2/12/2013 11:21 PM
AA5BY
Score: 153
Status: online
I second the Yup... losing elevator authority to hold positive angle of attack.
Hide Signatures
       Post #: 15
RE: How to find CG on unknown plane - 2/16/2013 4:11 PM
da Rock
Score: 265
Status: offline
Thanks guys,
Or come in with a click or two more throttle. Either that or don't pull off the throttle at the last foot or so. No matter what the CG, they fall out of the sky because they don't have enough airspeed or we have too much elevator input.
Sometimes we don't need another trim change, we need a slightly different flying technique.
Hide Signatures
       Post #: 16
RE: How to find CG on unknown plane - 2/16/2013 4:44 PM
AA5BY
Score: 153
Status: online
To some extent, the Spacewalker is finicky regarding landing. It enjoys the balance point being close. Too far forward and the mains hit too hard and bounce.
Too far aft and when the plane touches down it drives the tail down and if enough speed exist, it lifts back off and awaits a second landing. When the balance is good, it lands sweet.
Hide Signatures
       Post #: 17
RE: How to find CG on unknown plane - 2/18/2013 6:06 PM
Lnewqban
Score: 163
Status: offline
Thanks guys,
You are welcome
Nose heavy models must land hot.
You can safely move the CG aft 1/8" at a time until the elevator inputs start feeling twitchy.
Hide Signatures
       Post #: 18
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.469RCU1
