Help Identifying older Sachs 3.2 engine.    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> Help Identifying older Sachs 3.2 engine.
Page: [1]
Login
Help Identifying older Sachs 3.2 engine. - 2/8/2013 10:10 PM
singingflea
Score: 100
Last Login: 2/9/2013
Status: offline
Hi, I am new to this forum so bear with me. I recently bought an old Pitts special biplane. It has a 66 inch wing span. I was piloted by Charles Hillard and ran in world class championships in the late 60's and on through the 70's. I am trying to identify the original manufacturer and modifier of the engine. I want to sell it but I don't know how to describe it. Perhaps you can help me with this. I think the head is a Sachs 3.2 because it has the lettering 44 Zn 18 on the casing. Other numbers on the casing are OB, ++, V, and W2. The rest of the engine and prop mount I have not seen while searching the internet. The crank case is machined aluminum two piece with a flat plat on one end to mount the base and six bolt prop mount on the prop side. It does not look like the same material as the head. There is also a base mount  shaped something like a wire spool to bolt the engine to the firewall. This is an older engine with a fiber block type ignition advance, a Bennett exhaust and a Welbro carburetor that is only marked with a DO next to the fuel inlet. The ignition block is a CD ignition made by CH Electronics Inc. in Riverton, WY. There is no prop. Could you please let me know if you can identify the original maker? It seems to have excellent compression and was recently run for a few minutes. Would it be hard to find parts for and is it worth restoring to flight or would I be better off looking for a newer engine?
Thank You. Peter
Hide Signatures
       Post #: 1
RE: Help Identifying older Sachs 3.2 engine. - 2/8/2013 10:12 PM
w8ye
Score: 318
Last Login: 6/20/2013
Status: offline
Some good pictures would be worth another thousand words
_____________________________
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Recipient, Mangledhand award August 2008
Club Saito Member #7
Original AMA #31261
Hide Signatures
(in reply to singingflea)
       Post #: 2
RE: Help Identifying older Sachs 3.2 engine. - 2/8/2013 10:59 PM
singingflea
Score: 100
Status: offline
I tried but get an internal error 500. Resources cannot be displayed. Any suggestions?
Hide Signatures
(in reply to w8ye)
       Post #: 3
RE: Help Identifying older Sachs 3.2 engine. - 2/8/2013 11:09 PM
tkg
Score: 657
Last Login: 6/19/2013
Status: offline
Maybeyour picture file is to big.
A fiber timing block usually means an older A&M. Remoce carb and look at tbe rod. Alumiun rod is junk engine, copper/bronze rod means good engine.
TKG
Too much power is just about right.
Hide Signatures
       Post #: 4
RE: Help Identifying older Sachs 3.2 engine. - 2/8/2013 11:17 PM
CK1
Score: 150
Status: offline
From your description of the back plate , the material the advance cam is made of and the six bolt prop hub it sounds like an A&M which later was taken over by Brison Aircraft .
http://www.bj-model-engines.com/ Bill Jensen services most any Sachs based engine .
"Aint this great !!" - Chris
"Nosen Cessna 310 Club" #8
Hide Signatures
       Post #: 5
RE: Help Identifying older Sachs 3.2 engine. - 2/8/2013 11:40 PM
singingflea
Score: 100
Status: offline
It's an aluminum rod. As for picture size I'll try some smaller ones if 600x 500 is too big. Hmmm...480x 400 no good either. I'll try just one. Hmmm...nope, no luck.
Apparently I will need better instructions on how to upload pictures to this server. What is the size limit?
Anyway, I'll follow the link from CK1 and see what I find. Any ideas what the junk ones go for on auction?
Hide Signatures
(in reply to tkg)
       Post #: 6
RE: Help Identifying older Sachs 3.2 engine. - 2/8/2013 11:44 PM
w8ye
Score: 318
Status: offline
I upload the pictures to Photobucket and then link to them from the RCUniverse post.
They come out sized just right.
Original AMA #31261
Hide Signatures
       Post #: 7
RE: Help Identifying older Sachs 3.2 engine. - 2/8/2013 11:55 PM
All Day Dan
Score: 156
Status: offline
44ZN18 is a Mahle 3.2 cubic inch cylinder with mating piston assembly. Brison used the same pair in their 3.2 engine. You can get it serviced by Bill Jensen whether it's a Brison or not. Dan.
Dan
Hide Signatures
       Post #: 8
RE: Help Identifying older Sachs 3.2 engine. - 2/9/2013 1:47 AM
karolh
Score: 315
Status: offline
Aluminium rod, hmmmmm
Karol
When inverted always remember that down is up and visa versa
Hide Signatures
(in reply to All Day Dan)
       Post #: 9
RE: Help Identifying older Sachs 3.2 engine. - 2/9/2013 2:18 AM
w8ye
Score: 318
Status: offline
There was something wrong with the attachment loader but right now it seems to be working.
Brison 3.2
Click to see fullsize image.
Click for fullsize
Original AMA #31261
Hide Signatures
(in reply to karolh)
       Post #: 10
RE: Help Identifying older Sachs 3.2 engine. - 2/9/2013 2:29 AM
singingflea
Score: 100
Status: offline
OK, this time it loaded successfully. Here is the pix.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to w8ye)
       Post #: 11
RE: Help Identifying older Sachs 3.2 engine. - 2/9/2013 2:39 AM
singingflea
Score: 100
Status: offline
Here is a picture of the plane. Apparently Charle Hillard was a championship pilot in a full size  plane and this is a replica of his plane. I an guessing the decals all came as part of a kit.
Click for fullsize
Hide Signatures
(in reply to w8ye)
       Post #: 12
RE: Help Identifying older Sachs 3.2 engine. - 2/9/2013 2:52 AM
CK1
Score: 150
Status: offline
The plane is a Byron Pitts . The black plastic mounts on the back of the engine came with the Byron Kit .
The plane can be a great flyer if it is not to heavy from fiberglass and repairs to the foam . Beware gass will eat the foam quickly . If the A&M 3.2 has the alluminum rod most knowing buyers will pass on it as a useable engine . Changing the crank over to a Sachs crank and rod will make it a great engine again but may be too costly to be worth it.
Hide Signatures
       Post #: 13
RE: Help Identifying older Sachs 3.2 engine. - 2/9/2013 4:26 AM
singingflea
Score: 100
Status: offline
OK, well I bought the whole plane for $100 so I am thinking I did alright anyway. We have a local club down at the Kona airport so I will take it down there and see what they think. I don't have a controller but maybe someone there will want to get it flying. It doesn't look too heavy yet.
Thanks for all your help.
Peter
Hide Signatures
(in reply to CK1)
       Post #: 14
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> Help Identifying older Sachs 3.2 engine.
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.063RCU1
