RE: HobbyKing 50cc Warbirds    Gallery
Logged in as Guest
    Search This Thread
Printable Version
1/5 Scale Don Smith's Henschel HS-129B - RTF
Seller:  Dumb Thumb
Details:   $2,750.00   |  5/16/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: HobbyKing 50cc Warbirds
Page: <<   < prev  1 2 3 4 [5] 6 7 8 9   next >   >>
Login
RE: HobbyKing 50cc Warbirds - 2/16/2013 5:53 PM
kahloq
Score: 125
Last Login: 5/19/2013
Status: offline
No one has flown this HK spitfire yet that we are aware of. Its pretty new and only a handful of build threads(one here and one on rcgroups). The retracts are in the scale position for the real plane. I had a similar concern myself and asked my long time flying friend about this. He's had numerous large scale spitfires over the years and the position of the gear actually made him happy...and is part of why he himself bought the plane. He said it should be just fine.....just manage the elevator and throttle for takeoffs and landings.
Hide Signatures
(in reply to kmtranmd)
       Post #: 101
RE: HobbyKing 50cc Warbirds - 2/16/2013 8:44 PM
radfordc
Score: 100
Last Login: 5/6/2013
Status: offline
Well, I went ahead and ordered the last set of gear in stock at HK. I don't know when or if I will get the plane but I would hate to get it and not be able to have the gear.
Hide Signatures
       Post #: 102
RE: HobbyKing 50cc Warbirds - 2/16/2013 9:03 PM
kahloq
Score: 125
Status: offline
That's exactly what I had been thinking several weeks ago when I ordered the first set of gear. But....since my elderly friend wantsd to buy the plane and get started on it, I sold that set to him. Ironically, the next day my wife told me to go buy the plane. So.....I bought a 2nd set of the retracts and ordered the plane right then. Tracking says it will be here on Wednesday.
Hide Signatures
(in reply to radfordc)
       Post #: 103
RE: HobbyKing 50cc Warbirds - 2/16/2013 9:08 PM
jeffk464
Score: 100
Last Login: 5/16/2013
Status: offline
quote:
ORIGINAL: kahloq
Yeah, no problem just have better skills.
Hide Signatures
(in reply to kahloq)
       Post #: 104
RE: HobbyKing 50cc Warbirds - 2/17/2013 1:50 AM
SWORDSN
Score: 100
Status: offline
Is anyone in the process of assembly with a gas engine?
Hide Signatures
(in reply to jeffk464)
       Post #: 105
RE: HobbyKing 50cc Warbirds - 2/17/2013 2:04 AM
BJ64
Score: 100
Last Login: 5/18/2013
Status: offline
quote:
ORIGINAL: kahloq
What type of 190???? Do you want an fw-190d9 or an A variant? ...
It would be anything but the D variant, which runs an inline whereas I'm keen on a radial.
I think the 60cc HK radial would be just a bit too big for the ESM 71" FW 190 - or do you reckon that would be a half-decent match up?
BJ
_____________________________
Ahhhh...I love the smell Kero in the mornings....
Hide Signatures
       Post #: 106
RE: HobbyKing 50cc Warbirds - 2/17/2013 2:36 AM
91zulu
Score: 130
Status: offline
quote:
ORIGINAL: kochj
How did this post go so far off???
I might as well add to the caos.....
I have 2 magnums .91 4-strokes....The carbs are very touchy when inverted. BOTH of the carb/intake were machined incorrectly...So much so that
I had to place a spacer behind the carb to engine attachment point, so it would fit properly w/o leaking....
My OS engines have always ran like a clock.... I have had MANY kinds of rc engines. Planes, RC cars, Trucks, Buggies, Boats...ect.... and
OS has been BY FAR the MOST reliable engines I have ever owned... LEGENDARY CARBS??? YEP....
Those have always been made in Japan, and because our Dollar is tanked, and work outsourced, we have to pay to play.....
I have owned a Epson Artisan 800 until I found out that the Crooks at the Epson Foundry, had set up the PADS... (the fuzzy things that the ink goes onto for cleaning)
so it would only let you print so many times, until it SHUT DOWN and blinked ''Print Pads Full, Bring into AUTh. dealer to fix''
I even downloaded a fix, so it would work again, it did 1-more print..and stopped working again..
After numerous calls to Epson, (which was really a transferred call to INDIA, and I got to hear a woman and MAN try to make sense of our ENGLISH Language)
Other customers had the same thing happen, only a few of them (w/in 2 years of purchase) had a remanufactured one sent to them free...
I owned mine for over 2 years so I was on my own.... I can't understand that part.... It would have been in there best interest, that they give me a new printer...
The cartridges run 90$ for all the colors, and if you are out a PINK, you can't ever prink BLK/WHITE documents!!!!! SO you are FORCED to purchase MORE cartridges in order to use your printer...
After talking with the Indians, I was transferred back to AMERICA, so I could lodge a complaint with Epson....
''I can't be the only one that complained about this''? Epson Techi ''no , that is why we don't do that on our CURRENT printers''
It isn't about buying American, it is about Making AMERICA Strong again....
B. A degrees are a DIME A DOZZEN...... AND MASTER degree's are Common...... Fairly soon, you will need a Doctorate to work at BURGER KING!....
Yea , ASP has some good carbs too, That is if you new the Super Tiger and old 2 needle Fox carbs. At one point the heli guys swap out the OS carb for the ASP in I believe it was an OS 90, not too sure. The OS middle use to load up and cause them problems. Used a few Asp carbs in other engines I had, Skyward the Chinese version, change a few carbs on Royals....yep those were the days.
Oh yea, I think Enya had better carbs than OS.
91-Zulu
Hide Signatures
(in reply to kochj)
       Post #: 107
RE: HobbyKing 50cc Warbirds - 2/17/2013 3:11 AM
BJ64
Score: 100
Status: offline
OoOoooo.... too many carbs can make you overweight
BJ
Hide Signatures
(in reply to 91zulu)
       Post #: 108
RE: HobbyKing 50cc Warbirds - 2/17/2013 4:46 AM
kahloq
Score: 125
Status: offline
quote:
ORIGINAL: BJ64
quote:
ORIGINAL: kahloq
I think the 60cc HK radial would be just a bit too big for the ESM 71'' FW 190 - or do you reckon that would be a half-decent match up?
BJ
That 60cc radial would work very well in the Top Flite 85" wingspan fw-190 A. I assume your referring to the ASP400 5 cyl radial? Its actually 65cc. Yes...way too big for the 71" esm 190A, but perfect for the topflite 85" 190A.
A bit larger displacement and with 7 cylinders, horizonhobby sells a 77cc 7 cylinder radial:
http://www.horizonhobby.com/products/7-cylinder-77cc-4-stroke-glow-radial-engine-EVOE777#t2
Or you could use the saito 325 5 cyl or saito 3cyl 450 radial:
But....there is a 190A giant scale available
Is this what you have in mind?
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXCBLL&P=ML
Hide Signatures
(in reply to BJ64)
       Post #: 109
RE: HobbyKing 50cc Warbirds - 2/17/2013 4:49 AM
kahloq
Score: 125
Status: offline
quote:
ORIGINAL: SWORDSN
Yes.........I have a friend building the HK spitifre using a rear exhaust 55cc gasser. Once I receive mine next week.....I have a 50cc turnigy gas motor I will be using
Hide Signatures
(in reply to SWORDSN)
       Post #: 110
RE: HobbyKing 50cc Warbirds - 2/17/2013 7:41 AM
BJ64
Score: 100
Status: offline
Great info - thanks Kahloq.
The 85" looks just a tad too big, while the 71" is just that little bit too small.
That's why I was wondering if anyone makes an FW 190 in 80"....?
BJ
Hide Signatures
       Post #: 111
RE: HobbyKing 50cc Warbirds - 2/17/2013 2:09 PM
SWORDSN
Score: 100
Status: offline
quote:
ORIGINAL: kahloq
quote:
ORIGINAL: SWORDSN
It would be great to see some assembly pics.
Nelson
Hide Signatures
       Post #: 112
RE: HobbyKing 50cc Warbirds - 2/17/2013 3:10 PM
glazier808
Score: 291
Status: offline
quote:
ORIGINAL: BJ64
BJ
here is my 80" Holman FW190A8
http://www.rcuniverse.com/forum/m_11400684/anchors_11403498/mpage_4/key_/anchor/tm.htm#11403498
Casey
Fliteskin, Sierra, Nelson Hobby, MICKO aircraft, Getstencils, Holman Plans, VicRC, Castle Creations, Addicted to Luft
Hide Signatures
(in reply to BJ64)
       Post #: 113
RE: HobbyKing 50cc Warbirds - 2/17/2013 3:11 PM
BJ64
Score: 100
Status: offline
Um.... I'm lookin, but I kaint see nothin, Glazier...
Or are the pics not up yet?
BJ
PS - oh... looks like the link didn't post first time or something. It's there now.
O/T - That you, Invermast? How's the big TomCat coming along?
Hide Signatures
(in reply to glazier808)
       Post #: 114
RE: HobbyKing 50cc Warbirds - 2/17/2013 3:14 PM
glazier808
Score: 291
Status: offline
Has to add link sorry
Hide Signatures
(in reply to BJ64)
       Post #: 115
RE: HobbyKing 50cc Warbirds - 2/17/2013 3:20 PM
BJ64
Score: 100
Status: offline
No probs - thought it might have been my puter - things have been playing up a bit here tonight.
I came across Bob Holman's models only an hour or so - and saw the one you have there. Darn, if only the wings were already done - just not in the mood for sheeting etc atm.
What AUW did yours come in at, ready to spin the prop over?
BJ
Hide Signatures
       Post #: 116
RE: HobbyKing 50cc Warbirds - 2/17/2013 3:25 PM
glazier808
Score: 291
Status: offline
I didn't get a chance to put it on the CG machine yet.  I'm in Hawaii for business until Tuesday, so I'll get back on it then and will post in the thread I linked.
I expect it to be around 27 lbs after I put on CG.  I'm at just under 25 now.
Casey
Hide Signatures
(in reply to BJ64)
       Post #: 117
RE: HobbyKing 50cc Warbirds - 2/18/2013 12:54 AM
kahloq
Score: 125
Status: offline
quote:
ORIGINAL: SWORDSN
quote:
ORIGINAL: kahloq
quote:
ORIGINAL: SWORDSN
Nelson
It would be great if people have a bit a patience. I stated mine isnt arriving until wednesday. As far as my friend's....its hard for ME to take pictures of HIS plane when it's located at HIS house. He does not visit the forums, but....rest assured.....when I get mine this week....I will take pictures and answering anything I can.
Hide Signatures
       Post #: 118
RE: HobbyKing 50cc Warbirds - 2/18/2013 2:22 PM
SWORDSN
Score: 100
Status: offline
quote:
ORIGINAL: kahloq
quote:
ORIGINAL: SWORDSN
quote:
ORIGINAL: kahloq
quote:
ORIGINAL: SWORDSN
Nelson
Thank you,
It's only Monday, I guess I can wait... I know...,I know... I will have to
Hide Signatures
       Post #: 119
RE: HobbyKing 50cc Warbirds - 2/19/2013 12:07 PM
BJ64
Score: 100
Status: offline
Man...that TF 190 sure looks mouth watering.
Finally justified it to myself...and the retracts... until the shipping came out to $450.
Crap - pipe-dream has just gone up in smoke...
BJ
Hide Signatures
       Post #: 120
RE: HobbyKing 50cc Warbirds - 2/19/2013 12:14 PM
kahloq
Score: 125
Status: offline
There's no hobbyshop in Aussie land that carries TopFlite planes or one that can order it for you?
$450 just for shipping....holy crap.
I know its not an A version, but I know there are places in Australia that carry the ESM line of planes. They have the 82.5" Fw-190 D9.
There is also another D9 available here that's made by Vantex(same company that makes the Hobbyking Spitfire)
http://www.cozmiktoys.com/55cc-p-11357.html?osCsid=86009e30294eb209c70447f79e5ddf02
Hide Signatures
(in reply to BJ64)
       Post #: 121
RE: HobbyKing 50cc Warbirds - 2/19/2013 12:26 PM
BJ64
Score: 100
Status: offline
Thx Kahl...
Really after an A model now - the D would mean a mind-shift in engines etc.
Ya know how it is - finally get your heart set on something, and it gets hard to budge...
BJ
Hide Signatures
       Post #: 122
RE: HobbyKing 50cc Warbirds - 2/19/2013 12:43 PM
BJ64
Score: 100
Status: offline
PS - funny you should mention Ozzie Dealers for Top Flite.
The only one listed on the TF site is "Dawn Trading" in NSW.
I go to their site, but they make no link reference to Top Flite - closest would be Blackhorse, and that's back to a 70" FW 190A.
I rang them once before for something I was after that someone suggested that they carried, and the bloke I spoke to was really vague and ended up saying "um...no... don't think we stock that kind of thing" (yet their website suggested they did).
*sigh*
Wonder if Top Flite are interested in setting up an genunine Ozzie Rep? (that would be me )
No...seriously... I'd bring 10 units into the country if we could strike a decent price and take it from there.
We're really starved of decent kit down here sometimes. And considering the postage, it's not really that surprising.
Surely a spot in some container somewhere would bring things back to a realistic price? Not really into making anything out of it apart from covering my cost and a little bit of time - more of a service to others here Down Unda.
Dream on...
BJ
Hide Signatures
(in reply to BJ64)
       Post #: 123
RE: HobbyKing 50cc Warbirds - 2/19/2013 12:47 PM
kahloq
Score: 125
Status: offline
Maybe you should try calling that one hobbyshop again and if you get the same dumb a.s.s on the phone, ask to speak to someone else or call back at different times seeing of there is a different employee working.
Some people just care about their jobs nor have the knowledge to answer properly and instead of saying ..."ill get back to you after i look into it"...they just say no or I dont know cuz its easier and they are lazy. Its ppl like you talked to on that phone call that causes customers to go look elsewhere for their needs and then those hobbyshops go out of business.
Hide Signatures
(in reply to BJ64)
       Post #: 124
RE: HobbyKing 50cc Warbirds - 2/19/2013 12:54 PM
BJ64
Score: 100
Status: offline
Yah...there's that too.
I have mixed feelings for LHS's - some really try to help you. Others can't be fagged to give you the time of day (and they wonder why people don't buy from them).
Goes back to that 'buy local' discussion (or was that a different thread?).
At the end of the day - be it a local store, or the Internet - I guess what us customers all want is a little bit of TLC and some 'service'.
And that is getting rarer than 'made locally'... :
I hate that "got your money, now piss off" attitude.
Then again, if I was actually in the RC business, I'd probably end up the same if I had to deal with dickerheads like me all the time...
BJ
Hide Signatures
       Post #: 125
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.078RCU1
