DX18 Binding Problem    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> DX18 Binding Problem
Page: [1] 2   next >   >>
Login
DX18 Binding Problem - 2/10/2013 11:03 PM
never-enuff
Score: 100
Last Login: 6/19/2013
Status: offline
Hey guys, well with all the good advise I received I could hardly wait to go pick the 18 up. I had a R1221 already in the F16 I am working on so I just bound the new 18 to that receiver and worked perfectly. Then I decided to add some extra goodies to the jet such as canopy and lock, probably just because that new receiver that came with the radio and the expansion receiver that I picked up also was just setting there. So when I tried to bind the new receiver I got only a glitch of light on the receiver when I plugged the battery into it. I can not get a flashing light and I do have the bind plug in. Yet when I try the receiver I took our it binds fine. Bad receiver? I don't know. I will take it back to the hobby shop tomorrow and check it with another one just to see. Any insight is greatly appreciated. Thanks
Hide Signatures
       Post #: 1
RE: DX18 Binding Problem - 2/10/2013 11:14 PM
Thommo
Score: 100
Status: offline
I had a similar experience with my 18 turned out to be low battery voltage.
Hide Signatures
(in reply to never-enuff)
       Post #: 2
RE: DX18 Binding Problem - 2/10/2013 11:37 PM
never-enuff
Score: 100
Status: offline
I checked battery voltage 6.77 volts.
Hide Signatures
(in reply to Thommo)
       Post #: 3
RE: DX18 Binding Problem - 2/11/2013 12:06 AM
madmodelman
Score: 110
Status: offline
Your rx is shot, send it to Horizon and they should replace it.
_____________________________
Stuka, P51, Super Chipmunk, Super Stearman R170, BE2e, Javelin, Hawk, F16, L39, F86, Viperjet. Need an F4!!
Hide Signatures
       Post #: 4
RE: DX18 Binding Problem - 2/11/2013 1:11 AM
George
Score: 100
Last Login: 6/18/2013
Status: offline
I'm not sure how the 18 works (haven't played with it yet), but are you trying to bind a DSMX Rx with the Tx set to DSM2? I saw this the other day with a DX8 and it turned out the wrong "modulation" was set in the Tx and wouldn't bind with the Rx until it was changed.
Isn't the R1221 DSM2 and the Rx that comes with the 18 DSMX?
Just a thought.
George DelMoral
Dreamworks "Mobile" Products LLC
Hide Signatures
(in reply to madmodelman)
       Post #: 5
RE: DX18 Binding Problem - 2/11/2013 1:12 AM
Dr Honda
Score: 100
Status: offline
Do you have all the Satellite Rx units plugged in? Some of the Rx's will run with one Sat... but I think the 12xxx needs all 4 plugged in.
Tony
Owner of A&L Motorsports (formerly ARO Products) Manufacture of custom alloy parts.
Hide Signatures
       Post #: 6
RE: DX18 Binding Problem - 2/11/2013 1:30 AM
yeahbaby
Score: 135
Status: offline
Could be a bad rx but I had something similar happen with only one satellite blinking.....I moved the transmitter a little farther away and it worked fine.
Try this, Turn everything off, insert bind plug, turn rx on, turn transmitter on with bind button.
I think the manual says something about transmitter being too close may effect binding
"Audentes fortuna iuvat"
Hide Signatures
(in reply to Dr Honda)
       Post #: 7
RE: DX18 Binding Problem - 2/11/2013 1:43 AM
never-enuff
Score: 100
Status: offline
I've tried each of your suggestions but still no go.
Hide Signatures
(in reply to yeahbaby)
       Post #: 8
RE: DX18 Binding Problem - 2/11/2013 1:46 AM
Dustin Buescher
Score: 105
Status: offline
 Post a photo of your connections with bind plug.
Dustin Buescher
BVM/Skymaster USA, Horizon, Jet Central, Jetcat
Hide Signatures
       Post #: 9
RE: DX18 Binding Problem - 2/11/2013 1:55 AM
never-enuff
Score: 100
Status: offline
Dustin I will do it tomorrow if we don't get it figured out. I've left my shop for the night. But I have the bind plug in the bind data port and batt in the batt port with negative facing to the outside. I've tried the battery in any open slot as the manual said but doesn't change anything.
Hide Signatures
(in reply to Dustin Buescher)
       Post #: 10
RE: DX18 Binding Problem - 2/11/2013 2:32 AM
never-enuff
Score: 100
Status: offline
George its supposed to be compatible with both? Thanks
Hide Signatures
       Post #: 11
RE: DX18 Binding Problem - 2/11/2013 2:39 AM
never-enuff
Score: 100
Status: offline
And to add to that, it switches on its own from what I can tell.
Hide Signatures
       Post #: 12
RE: DX18 Binding Problem - 2/11/2013 2:43 AM
George
Score: 100
Status: offline
quote:
ORIGINAL: never-enuff
Yeah,
I'm not sure on the 18, but I just saw the non-binding issue due to DSMX vs. DSM2 with the 8 last week; that's why I brought it up. It might be something to look into.
George DelMoral
Hide Signatures
       Post #: 13
RE: DX18 Binding Problem - 2/11/2013 8:00 AM
JimJones1
Score: 100
Last Login: 2/18/2013
Status: offline
I have had this with a few receivers. Assuming nothing is switched on and then you plug in the receiver to a battery with the bind plug connected if it does not flash rapidly it is a bad RX. Check or try the battery the other way round first which I assume you have done as the markings on the new RX's can be confusing.
This problem has nothing to do with binding. If the RX does not flash continiously when powered up with the Bind plug in and the battery the right way round it is faulty. The TX should be off at this point
Hide Signatures
(in reply to George)
       Post #: 14
RE: DX18 Binding Problem - 2/11/2013 9:02 AM
madmodelman
Score: 110
Status: offline
As I said earlier I'm sure your rx is shot.
It's happened to me a few times, even on an AR7000 which had hundreds of flights, when I finally went to rebind it showed no flashing lights no matter what. Don't waste your time.
Gary.
Hide Signatures
       Post #: 15
RE: DX18 Binding Problem - 2/11/2013 2:01 PM
exfed
Score: 100
Status: offline
I recently received a new JR 9 channel rx that would not bind with my 9503 tx. After trying everything I could, I finally attempted the binding process with a different rx battery. I had been using a well charged 5 cell pack. When I replaced it with a 4 cell pack, it binded with no problems. I called Horizon and discussed the issue with their tech reps. They say they haven't heard of this before, but trust me, it happened. The new radio works flawlessly and on the 5 cell pack. Just won't bind....
Hide Signatures
       Post #: 16
RE: DX18 Binding Problem - 2/11/2013 6:33 PM
JimJones1
Score: 100
Status: offline
quote:
ORIGINAL: exfed
Interesting that one as I use an old 5 cell pack (6v) to bind all my receivers
Hide Signatures
(in reply to exfed)
       Post #: 17
RE: DX18 Binding Problem - 2/11/2013 8:28 PM
luv2flyrc
Score: 102
Status: offline
Assuming this is a power safe receiver, remove the soft switch. Install bind plug, attach batteries, that should put receiver in bind mode.
Mike
Hide Signatures
(in reply to JimJones1)
       Post #: 18
RE: DX18 Binding Problem - 2/11/2013 9:16 PM
uncljoe
Score: 160
Status: offline
 Try another bind plug making sure that is seated.. (had your identical problem, swapped the bind plug ..Presto now works ...
Semper Fi ,Mac
Joe
Look towards the Horizon......your death awaits you there
Hide Signatures
(in reply to luv2flyrc)
       Post #: 19
RE: DX18 Binding Problem - 2/11/2013 10:27 PM
Rob2160
Score: 184
Status: offline
Some things to try...
1. is the Bind plug in the correct port?   I had two identical JR receivers, and one binds perfectly with bind plug in the marked bind port.. the 2nd RX did exactly what you described if I put the bind plug in the marked port.. It turned out that the actual bind port was on the oppostive end of the ports and using this position (incorrectly marked on RX) worked perfectly..
2. correct polarity of the Battery on the RX?
3. DSMX or DSM2 modulation set in your radio?  It won't actually make a difference because the RX will / should bind either way.. but select DSMX because it is a better protocol ..   ( whatever your TX is set to will not affect the RX flashing in bind mode)
HOpe that helps.. Please post if you fix the problem.. just out of curiosity..
..... frakkin cylons...
Hide Signatures
(in reply to uncljoe)
       Post #: 20
RE: DX18 Binding Problem - 2/11/2013 10:34 PM
never-enuff
Score: 100
Status: offline
Ok guys, embarrassing to say but the problem was I had the bind plug in the wrong port. I looked at it again and thought I would try it in another port and presto! The 9020 receiver is very unclear the way it's marked. Thanks for all the info. This is a great thread I've learned a lot more than what my original post was about.
Hide Signatures
(in reply to Rob2160)
       Post #: 21
RE: DX18 Binding Problem - 2/11/2013 11:12 PM
madmodelman
Score: 110
Status: offline
I just don't believe I'm reading this.
Hide Signatures
       Post #: 22
RE: DX18 Binding Problem - 2/11/2013 11:46 PM
BaldEagel
Score: 118
Status: offline
That's nothing have a look at this thread: http://www.rcuniverse.com/forum/m_11403527/tm.htm
Mike
No matter what anyone says 100% is the maximum you can get.
Hide Signatures
       Post #: 23
RE: DX18 Binding Problem - 2/12/2013 12:17 AM
George
Score: 100
Status: offline
quote:
ORIGINAL: George
I'm not sure how the 18 works (haven't played with it yet), but are you trying to bind a DSMX Rx with the Tx set to DSM2? I saw this the other day with a DX8 and it turned out the wrong ''modulation'' was set in the Tx and wouldn't bind with the Rx until it was changed.
Just a thought.
I have to correct my post above^^^
It was NOT that the rx wouldn't bind, it was the fact that it wouldn't work the controls when set to DSMX.
I just wanted to make that clear, Sorry!
George DelMoral
Hide Signatures
       Post #: 24
RE: DX18 Binding Problem - 2/12/2013 12:49 AM
Rob2160
Score: 184
Status: offline
Great to hear it worked..  I guess the bind position on some JR RX is incorrectly labelled.. one of mine definately is.. .
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.594RCU1
