Looking for Wraith shock upgrade recommendations    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Rock Crawlers >> Looking for Wraith shock upgrade recommendations Page: [1]
Login
Looking for Wraith shock upgrade recommendations - 2/12/2013 7:37 PM
gforce2448
Score: 105
Last Login: 6/18/2013
Status: offline
I've been running my Wraith that I built as a kit for almost a year now. The stock shocks are okay but have leaked several times and I have not been impressed at all with them. So instead of rebuilding them again and replacing a bottom retaining ring I just lost on my last outting, I want to upgrade.
I've heard the Pro-line Powerstroke scaler shocks are good. I've also recently seen Gmade has a line of shocks out that fit the Wraith as well. A piggyback model and two others. I mainly do trail driving with some crawling along the way. So looking for the best shocks for that. Thanks!!
_____________________________
Axial Wraith x2, SCX10 Rubicon
Hide Signatures
       Post #: 1
RE: Looking for Wraith shock upgrade recommendations - 2/12/2013 8:31 PM
t9dragon
Score: 328
Last Login: 6/16/2013
Status: offline
sent you a pm....
Hide Signatures
(in reply to gforce2448)
       Post #: 2
RE: Looking for Wraith shock upgrade recommendations - 4/21/2013 2:05 AM
jrowles91
Score: 100
Last Login: 5/22/2013
Status: offline
PM!? lol I was looking for an answer too! Hopefully someone chimes in. I'm looking for slightly more articulation too.
Emaxx 3905: RX8/2250kv, Slash 4x4 BL
Losi 8ight BL Conversion, TA TC3 BL
Hide Signatures
(in reply to t9dragon)
       Post #: 3
RE: Looking for Wraith shock upgrade recommendations - 4/21/2013 4:19 AM
nitro stan
Score: 100
Last Login: 6/14/2013
Status: offline
king offroad shocks seem to be getting popular these days, i dont have a wraith, so i dont know how long they need to be
http://184.172.61.235/King-Off-Road-Scale-Piggyback-Shocks-wFaux-Reservoir-100mm_p_2500.html
Hide Signatures
(in reply to jrowles91)
       Post #: 4
RE: Looking for Wraith shock upgrade recommendations - 4/21/2013 6:08 AM
gforce2448
Score: 105
Status: offline
I actually installed Integy MSR10 shocks on my Wraith not long after my original post. They are way longer than the stock shocks but I wanted alot of articulation as I mainly use my Wraith for crawling and trail runs. I believe they are like 124mm. I'm using the medium length ends which gives the suspension maximum travel without any binding of driveshafts. The shocks have about an inch of travel both up and down where the shocks sit with just the weight of the truck on them.
Hide Signatures
(in reply to nitro stan)
       Post #: 5
RE: Looking for Wraith shock upgrade recommendations - 4/22/2013 3:52 AM
jrowles91
Score: 100
Status: offline
How much taller does the truck sit?
Hide Signatures
       Post #: 6
RE: Looking for Wraith shock upgrade recommendations - 4/22/2013 12:20 PM
Jeepy2013
Score: 100
Last Login: 5/30/2013
Status: offline
The Pro-Line shocks are really good, some of the best out there. I haven't used them on my Wraith, but I have used them on my Traxxas 2wd Slash that I race.
RC10 Gold Pan / RC8.2e FT / SC10.2 FT / Thunder Tiger EB4 G3 / Axial SCX-10 Trail Honcho
Hide Signatures
       Post #: 7
RE: Looking for Wraith shock upgrade recommendations - 4/22/2013 5:14 PM
gforce2448
Score: 105
Status: offline
Here are some pics taken yesterday of my Wraith aka "Bushwhacker" along the Clackamas River past Estacada, OR. It sits pretty high, these shocks came with 3 sets of springs. The stiffest ones makes it sit up really high. It easily tips over taking a corner fast but like I said I mainly crawl and do trail runs. I've got weights in the wheels and the COG is pretty low. I originally had the Integy shocks mounted normally, but I read somewhere that if you invert them they don't leak as bad. They leaked a little at first but haven't had much of a problem lately. Used some green slime and inverted them. I looked at the Pro-line shocks and liked them alot. But got the Integy's as they were $60 for 4, which that would only get 2 of the PLs.
My son's Wraith has stock shocks and I lowered it, it sits a few inches shorter than mine but still slithers over rocks and stuff. But it works great for his driving style. When we get into some serious rock crawling my Wraith is usually the only one getting through because of the ground clearance.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by gforce2448 -- 4/22/2013 7:50 PM >
Hide Signatures
       Post #: 8
RE: Looking for Wraith shock upgrade recommendations - 4/24/2013 4:44 AM
Muskokarc
Score: 105
Last Login: 4/25/2013
Status: offline
They look great.  Love the paint jobs.
How you find putting together the kit?  When I get enough chash together I hope to get a kit to.
Youtube ID Muskokamike100
Hide Signatures
       Post #: 9
RE: Looking for Wraith shock upgrade recommendations - 4/24/2013 3:55 PM
phmaximus
Score: 632
Last Login: 6/19/2013
Status: offline
hummm tough one....
it all depends what u want from ur shocks.
there is a rule with shock. seaking shocks is not allways a bad thing
the tighter the seal the less chance of leaking, and increases resistance in shaft movement.
the looser the seal the higher the chance it will leak, but it will have less resistance in the shaft.
and another thing to consider is the seal will expand over time from the silicon. u can delay this using some o ring grease, highly reccomended by me.
been a crawler i would go for a looser seal as i will get slightly more articulation. just means u might have to top up the shocks more than normal.
The new losi 22 shocks offer 2 different o ring just for this reason.
they have a black toght
and a grey loose
for a basher its reccomended to use 2 black ones, so it does not leak
for a clubman basher its reccomended to use a grey one and a black one, for improved smootheness and slight leakage
for a track car its reccomended to use 2 grey one, for ultra silky smoothe suspension articulation, but will need toping up regularly
Losi Micro SCT,5IVE,8IGHTe
Tamiya BajaKing,TA01R,TL01B
Hide Signatures
(in reply to Muskokarc)
       Post #: 10
RE: Looking for Wraith shock upgrade recommendations - 4/24/2013 5:16 PM
gforce2448
Score: 105
Status: offline
Thanks! Mine actually has a skin from Freqeskinz and not painted. They have many different ones. My sons is just digital camo duct tape. lol. I had to wrap the broken panels in it to create new screw holes. The hood was fabbed out of plastic as it was missing. That is how bad his truck was in, but I got it used RTR for $200.
I enjoyed putting the kit together. Took my time over about 3 days last spring. It was nice knowing that all the screws are tight and enough grease on gears, that sort of thing when you build it. Unlike a ready to run. I want to build a SCX10 kit next. But I also need to save money for it.
Hide Signatures
       Post #: 11
RE: Looking for Wraith shock upgrade recommendations - 4/28/2013 1:42 AM
phmaximus
Score: 632
Status: offline
hey has anyone noticed the only SCX10 kit is now the Dingo.... and its only $100 cheaper than the RTR!!!!! kind of a rip... considering that the Honcho/jeep RTR is only $100 more and comes with a Axial 2.4ghz radio gear, Axial AE-2 ESC, Axial 27t motor, Axial servo and Axial LED kit...
Looking online the AE-2 is $70 alone... so that mean u are getting the radio gear, servo and motor for around $30
Hide Signatures
       Post #: 12
RE: Looking for Wraith shock upgrade recommendations - 4/28/2013 1:32 PM
KID_EVIL!
Score: 117
Last Login: 6/8/2013
Status: offline
Might I ask why you would want to let your shocks leak instead of using a thinner oil?????? OR using a 3 hole piston? or softer springs??
I''m not really a kid.... I just act like one
VROOM VROOM!!!!!
Hide Signatures
(in reply to phmaximus)
       Post #: 13
RE: Looking for Wraith shock upgrade recommendations - 4/28/2013 6:13 PM
gforce2448
Score: 105
Status: offline
But with all of Axials kits you get upgrade options. The Dingo and Wraith kits comes with aluminum links and R35 soft compound Ripsaw tires. The Rubicon kit comes with the new aluminum Icon shocks and aluminum links. The RTR models all comes with plastic links, shocks and basic tires.
If you plan on upgrading electronics I prefer the kits. If not, the RTR is great to get you on the trail.
Hide Signatures
       Post #: 14
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.422RCU1
