Please help, was told electric was a good way to go for a beginner    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> Please help, was told electric was a good way to go for a beginner
Page: [1]
Login
Please help, was told electric was a good way to go for... - 2/13/2013 3:12 AM
kinslayer1973
Score: 100
Last Login: 2/18/2013
Status: offline
 I just purchased a Redcat Volcano Exp Pro and straight out of the box I have had problems. I charged the battery pack for 3 hours as recommended by the dealer and on the first run the truck just surged repeatedly in forward but runs perfectly in reverse. I tried tweaking the adjustment on the controller but to no avail, it actually made it worse. I gave up for an hour being frustrated then went back out to try again and it took off like it was supposed to then started surging again. Now its surging in fwd and reverse. Anybody have any ideas why this is happening. This is my second Redcat truck, my first is a Groundpounder which on the advice of my hobby dealer I upgraded the battery pack to a lipo 5800 which turned out to be a death sentence to the stock motor or esc not sure which. I want to upgrade the motor and esc in this as well since they are shot. Any suggestions for that?
Hide Signatures
       Post #: 1
RE: Please help, was told electric was a good way to go... - 2/13/2013 6:23 AM
VTEC_Inside
Score: 100
Last Login: 5/13/2013
Status: offline
See if its possible to re-calibrate the controller. I checked the manual on the Redcat site, but couldn't find anything helpful at a quick glance.
Hide Signatures
(in reply to kinslayer1973)
       Post #: 2
RE: Please help, was told electric was a good way to go... - 2/13/2013 8:14 AM
Foxy
Score: 2012
Last Login: 5/22/2013
Status: offline
It sounds like the ESC has some problems. It may be worth trying to do the calibration procedure again (ESC calibration, not radio), but it maybe a bad ESC from the start, it does happen.
Unfortunately, and this is not exclusive to Redcat by any means, it applies to almost all RTRs, RTRs are supplied with pretty rubbish electronics, and that includes the servo too. Expect to replace the ESC and servo.
We have a dedicated Redcat forum which I'm going to move your thread to now...I'm sure someone in there will square you away.
_____________________________
So, you got a smartphone. You now have virtually unlimited access to the collective acquired knowledge of the entire human race in the palm of your hand, and you use it to... play Angry Birds while sitting on the toilet. Way to go!
Hide Signatures
(in reply to VTEC_Inside)
       Post #: 3
RE: Please help, was told electric was a good way to go... - 2/13/2013 1:20 PM
nitrosportsandrunner
Score: 296
Last Login: 5/23/2013
Status: offline
quote:
ORIGINAL: kinslayer1973
It sounds like the low voltage detection (a function of the esc needed for use of lipo batteries) may be faulty. either that, or it is not calibrated to the radio right. I would try recalibrating it.
see my video below.
After that, I would check the function of the radio. You could pull the reciever out of your groundpounder to see if your volcano radio is the issue.
If neither of those sets solve the problem, then it is the ESC. Redcat will replace it if you fill out the warrenty form on their website.
As for replacement gear...plenty of options.
Traxxas vxl system
Team associated SC450 ESC/reedy motor
Ezrun/hobbywing 60amp system.
Most any 1/10 scale system with a motor that has a 3300-3900kv motor will work.
Redcat Mirage Pro, Tornado EPX Pro, SC10, TTR Phoenix XB. Redcat Racing Dealer.
Hide Signatures
       Post #: 4
RE: Please help, was told electric was a good way to go... - 2/13/2013 3:31 PM
Dads like rc too
Score: 540
Status: offline
Are you charging the battery with the factory supplied wall charger? If you are, three hours sounds a little short to fully charge your battery. Your low voltage cutoff may just be activating because the battery is low to begin with.
Caldera 10e : Volcano EPX : Monsoon XTR : Sumo x2 :
Hide Signatures
(in reply to nitrosportsandrunner)
       Post #: 5
RE: Please help, was told electric was a good way to go... - 2/13/2013 4:37 PM
EXT2Rob
Score: 177
Last Login: 5/21/2013
Status: offline
Just a thought.....make sure each of the connectors to the motor are nice and tight.  If one fits loosely, it'll cause the motor to surge or stutter. Might run fine for a bit, then start acting up.  I found one of the bullet connectors on the motor wasn't very solid. After giving it a slight crimp, it solved the problem.
Hide Signatures
(in reply to Dads like rc too)
       Post #: 6
RE: Please help, was told electric was a good way to go... - 2/14/2013 2:47 AM
kinslayer1973
Score: 100
Status: offline
Thank you for all the help. I'm going to try the calibration again. Hopefully it works, but if not I will just upgrade all the electronics on both my trucks. Somebody mentioned the possibility that I'm not charging my battery correctly. I have the stock charger so there really isnt any indicator that I can find to show when its fully charged. The three hours I went by was suggested by the hobby dealer, but then again he is also the one that said I could put the 5800 lipo battery in my groundpounder with no problem. If the battery is under charged on the first time is that battery going to be short lived from now on. I heard that the nimhd battery has a memory for that.
Hide Signatures
       Post #: 7
RE: Please help, was told electric was a good way to go... - 2/14/2013 3:29 AM
kinslayer1973
Score: 100
Status: offline
I tried re-calibrating and no difference, except now the reverse doesnt work right either. I'm going to try charging the battery again to see if it could be the low voltage issue.
Hide Signatures
       Post #: 8
RE: Please help, was told electric was a good way to go... - 2/14/2013 12:05 PM
Dads like rc too
Score: 540
Status: offline
You can probably get a better answer from Nitrosports since he's all about the electric stuff, but I thought it took 6-8 hours to charge the stock battery with the stock wall charger. It's just one of those things that almost has to replaced right away. You can pick up a decent charger for less than around $40 that will charge your battery in an hour.
Hide Signatures
       Post #: 9
RE: Please help, was told electric was a good way to go... - 2/14/2013 3:14 PM
Score: 296
Status: offline
quote:
ORIGINAL: Dads like rc too
another thing that goes along with this is that people have gotten defective stock chargers before. I recently got a tamiya tamtech who's stock charger (has a LED) stays red even if its plugged in over night. And the battery never gets charged.
Slapped it on my Thunder AC6 and problem solved.
These stock "brick" chargers are soo low tech, even IF they are working you cant trust them to put 100% charge into your battery.
Kinslayer, before you change out your electronics, please try either a totally different battery (maybe a friend has one you can try?) or a better charger. Even if you do end up chaging the electronics a better charger will be better anyway. My Thunder AC6 was $50 and can charge that stock NIMH in under an hour.
Hide Signatures
       Post #: 10
Foxy
Score: 2012
Status: offline
Also, since you recallibrated and made it worse, there is obviously still a callibration issue (the reverse callibration didn't take by the sound of it). You need to keep doing this until you get it right again unfortunately.
Hide Signatures
       Post #: 11
RE: Please help, was told electric was a good way to go... - 2/15/2013 3:03 AM
kinslayer1973
Score: 100
Status: offline
 Thanks again ya'll. I re-calibrated again and charged the battery for 7 hours and that seemed to work. It still glitches every now and then while its running but  at least its running lol. If it starts acting up I let off the throttle a little and ease back into it and it takes off again.
Hide Signatures
(in reply to Foxy)
       Post #: 12
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.063RCU1
