3 tanks in series?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Jet Central Rhino - RTF
Seller:  thunderbolt-RCU
Details:   $2,700.00   |  5/18/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> 3 tanks in series?
Page: [1]
Login
3 tanks in series? - 2/13/2013 10:57 AM
rossi63
Score: 100
Last Login: 5/21/2013
Status: offline
 In what order do I connect 3 tanks? Both my Viper and F-16 have two tanks on cg and one in front. The manuals for both models shows that its tanks on cg is drained first before the tank in front. Balance the model cg with a half full front tank is ok as long as you know when the level is reached and land with perfect cg. Would it not been better to balance the model with empty front tank and drain front tank first so remaining 2/3 of the trip flown with perfect cg? If you want to land earlier it's only the first minutes model is front heavy.
Rossi
Is using google translate :-)
Hide Signatures
       Post #: 1
RE: 3 tanks in series? - 2/13/2013 12:14 PM
Canadian Man
Score: 100
Last Login: 5/24/2013
Status: offline
Yes your idea is correct.
Both ways will work but I would drain the tank that is ahead of the CG first.
Hide Signatures
(in reply to rossi63)
       Post #: 2
RE: 3 tanks in series? - 2/13/2013 1:42 PM
Gary Jefferson
Score: 100
Last Login: 5/23/2013
Status: offline
The typical setup is to run the main tanks in parallel and then run a single line to the front tank (in front of the C.G.), then a line out of this tank to the UAT. I have run this configuration in many different types of air frames and never noticed any issues with C.G.
_____________________________
Gary Jefferson
Jetcat USA Rep
Hide Signatures
(in reply to Canadian Man)
       Post #: 3
RE: 3 tanks in series? - 2/13/2013 1:51 PM
David Jackson
Score: 111
Status: offline
quote:
ORIGINAL: Gary Jefferson
I ran the same tank configuration on a 1/6 scale F-16 with no issues
Hide Signatures
(in reply to Gary Jefferson)
       Post #: 4
RE: 3 tanks in series? - 2/13/2013 1:58 PM
essyou35
Score: 100
Status: offline
I usually run my two rear tanks in parrellel, front tank empties last. This is to ensure the CG dont shift too far back. On my setup I barely ever touch the front tank as I only fly 6 mins then land.
3 tanks in series is a lot of pressure during fueling and make sure you use the largest fuel line you can.
Hide Signatures
(in reply to David Jackson)
       Post #: 5
RE: 3 tanks in series? - 2/13/2013 2:09 PM
Gary Jefferson
Score: 100
Status: offline
Using 3 tanks in series really doesn't make much sense because you then have one main tank empty on one side of the plane. I know the tanks are close to the C.G. but I am not sure that is a good idea.
Gary Jefferson
Jetcat USA Rep
Hide Signatures
(in reply to essyou35)
       Post #: 6
RE: 3 tanks in series? - 2/13/2013 5:38 PM
JimJones1
Score: 100
Last Login: 2/18/2013
Status: offline
Doesnt matter at all. Lateral balance of a plane makes very little difference. The bites in the fuz are so close to the centre line it will make no difference
< Message edited by JimJones1 -- 2/14/2013 7:28 AM >
Hide Signatures
       Post #: 7
RE: 3 tanks in series? - 2/13/2013 5:41 PM
highhorse
Score: 116
Status: offline
3 in series seems a lot. Perhaps the best solution is a combination of the two solutions: to drain front first and then remaining two in parallel?
RCU Rocks, I''d hate to be without it !!
Hide Signatures
       Post #: 8
RE: 3 tanks in series? - 2/13/2013 5:55 PM
rossi63
Score: 100
Status: offline
What if I balance the model with empty front tank and parallel connecting tanks in cg?
Front tank.
Tanks on CG
Hide Signatures
       Post #: 9
RE: 3 tanks in series? - 2/13/2013 6:52 PM
Gary Arthur
Score: 105
Status: offline
The typical way is to have the main tank supply the UAT and the two saddle tanks supply the main tank either in series or paralell.
Balance the plane with tanks empty and UAT full. The idea is that you will drain the saddle tanks first and therefore no change in CG. Then as you empty the main tank you will get a shift in CG. Since you will rarely empty the main tank (usually land with some fuel in main tank) the CG shift will be slight. If you find that you are flying and usually have a forward CG due to residual fuel, you can move the CG back a little. Just be cautious because the one time you do run the main tank down low, you will have an aft CG.
Hide Signatures
       Post #: 10
RE: 3 tanks in series? - 2/13/2013 10:45 PM
JimJones1
Score: 100
Status: offline
You are worrying about this too much
Hide Signatures
(in reply to Gary Arthur)
       Post #: 11
RE: 3 tanks in series? - 2/14/2013 4:58 AM
Canadian Man
Score: 100
Status: offline
quote:
ORIGINAL: JimJones1
Yuuuuuuuuup
Hide Signatures
(in reply to JimJones1)
       Post #: 12
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.313RCU1
