Apair of 11.1 volt batteries makes 22.2 volts?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
42% Radiocraft Extra 330 with DA 150 and mufflers - ARF
Seller:  hatstien
Details:   $1,700.00   |  5/8/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Electric Aircraft Universe >> Electric General Discussion >> Apair of 11.1 volt batteries makes 22.2 volts?
Page: [1]
Login
Apair of 11.1 volt batteries makes 22.2 volts? - 2/14/2013 7:20 PM
ScottMcM
Score: 125
Last Login: 5/21/2013
Status: online
I recently bought my first large electric plane(pre-owned). It calls for a 22.2 volt battery. I have none, but I do have quite a few 11.1 volt batteries laying around. I have ordered the correct battery from Hobby King. While I'm waiting for it to be delivered, can I use a pair of 11.1 batteries, just to check the plane out?
_____________________________
It is better to keep one''s mouth closed, and be thought a fool, than to open it, and remove all doubt.
Hide Signatures
       Post #: 1
RE: Apair of 11.1 volt batteries makes 22.2 volts? - 2/14/2013 8:46 PM
Walt Thyng
Score: 105
Status: offline
Sure thing, just as long as they are the same capacity and (preferably) discharge rate.
You can use packs of different discharge ratings as long as your requirements don't exceed that of the lesser of the two.
Many fliers use multiple smaller packs in series to create larger ones both for flexibility of use and less expensive replacement if a cell dies.
Walt
WT in Illinois
Hide Signatures
(in reply to ScottMcM)
       Post #: 2
RE: Apair of 11.1 volt batteries makes 22.2 volts? - 2/14/2013 9:30 PM
BarracudaHockey
Score: 280
Status: online
Cells in series add voltage but remain the same capacity. (3S 2000mah + 3S 2000mah = 6S 2000mah)
Cells in parallel add capacity but remain the same voltage so if you take the above cells and wire them in parallel you will get a 3S 4000mah battery.
Andy - Helicopter Forum Moderator
AMA 77227 Leader Member- Contest Director
www.JaxRC.com
Hide Signatures
(in reply to Walt Thyng)
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.156RCU1
