RE: Hits and Misses of H-9 Corsair    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> ARF or RTF >> RE: Hits and Misses of H-9 Corsair
Page: <<   < prev  92 93 94 95 96 97 98 [99] 100 101   next >   >>
Login
RE: Hits and Misses of H-9 Corsair - 9/12/2011 10:36 PM
Pit-Viper 1
Score: 100
Last Login: 4/30/2013
Status: offline
The .82 would be a great fit. You'll love that corsair it comes with a very nice hatch that gives you easy access to everything. The one I flew had the fuel dot and air for retracts inside the hatch so you can keep the outside clean and not have to drill or cut it up.
_____________________________
Colorado-rc.com
Hide Signatures
(in reply to phatbob02)
       Post #: 2451
RE: Hits and Misses of H-9 Corsair - 9/29/2011 12:24 AM
JVB
Score: 100
Last Login: 5/19/2013
Status: offline
I had a Hangar 9 Corsair given to me. It had been through a few missions if you get my drift. I didn't really want it but said what the heck and put a DLE 20 engine in it. I can't keep the plane on the ground during takeoff. It starts flying when I give it some throttle. The balance is right on 5 inches. I'm thinking I may have a thrust problem. Where should the thrust line be on this plane. I had to change the mounting arrangement for the gas engine. Any other suggestions are welcome.
Thanks.
Hide Signatures
(in reply to Pit-Viper 1)
       Post #: 2452
RE: Hits and Misses of H-9 Corsair - 9/29/2011 12:44 AM
gibatta
Score: 105
Last Login: 5/16/2013
Status: offline
try to balance at 4 1/2", & make sure you have right amount engine trust (linear with fuse), once in the air trim your plane for straight flyght
Hide Signatures
(in reply to JVB)
       Post #: 2453
RE: Hits and Misses of H-9 Corsair - 9/29/2011 1:38 AM
Pit-Viper 1
Score: 100
Status: offline
As long as you mounted the engine flush to the firewall the thrust line should be ok unless it was repaired and not don't properly. One way you can check to see if you have a thrust issue is first to be sure your balanced lateraly.! (wingtip to wingtip) then when you're flying get it flat and level at 1/2 throttle then punch it quickly. If it climbs you need to shim the motor down slightly and if it goes down then you need to shim it up. If it flew fine where the CG was at then I would leave it alone. I always balance mine slightly nose down with the CG right on 5". If everything is fine it may be a case of a little to much elev. on takeoff which isn't uncommon. Hope this helps..
Shane
Colorado-rc.com
Hide Signatures
(in reply to gibatta)
       Post #: 2454
RE: Hits and Misses of H-9 Corsair - 10/7/2011 1:09 PM
JVB
Score: 100
Status: offline
Thanks guys. How about the vertical alignment of the engine? Is the prop shaft (engine centerline) supposed to be lined up with the horizontal cross hair lasered into the firewall? Mine is about 7mm below that line. I don't think that little bit would make much difference anyway, but you never know. I think I will move the cg forward to about 4 inches and see what that does.
Hide Signatures
       Post #: 2455
RE: Hits and Misses of H-9 Corsair - 10/7/2011 2:16 PM
Pit-Viper 1
Score: 100
Status: offline
As long as the tanks centerline is lined up with the carb correctly it should be fine. If you can move the engine mount in the slots on the firewall i would just to make it right.
Colorado-rc.com
Hide Signatures
(in reply to JVB)
       Post #: 2456
RE: Hits and Misses of H-9 Corsair - 3/11/2012 10:54 PM
shane55
Score: 100
Last Login: 3/30/2013
Status: offline
I have about 15 flights on my H9 corsair 60 and have been having a problem with noseovers and the resultant Fin damage. I see earlier in this thread that the problem can be solved by shimming the gear forward. I will try that. Today however the Ball on the U/C leg sheared off where it threads into the collet. Are these available as a spare? I'll probably need the collet as well as the theaded part of the ball stud is still in there.
Click to see fullsize image.
Click for fullsize
< Message edited by shane55 -- 3/11/2012 11:20 PM >
Hide Signatures
       Post #: 2457
RE: Hits and Misses of H-9 Corsair - 3/11/2012 11:26 PM
Dangaras
Score: 255
Last Login: 5/6/2013
Status: offline
Take the part to your lhs if they have helis. These are standard parts for cars as well I think.
Don''t be divided from the truth by what you would like to believe.
Hide Signatures
(in reply to shane55)
       Post #: 2458
RE: Hits and Misses of H-9 Corsair - 3/12/2012 12:04 AM
shane55
Score: 100
Status: offline
Thanks but I dont have an LHS, I'll have to order online. I was hoping someone might have found a replacement before......
Hide Signatures
(in reply to Dangaras)
       Post #: 2459
RE: Hits and Misses of H-9 Corsair - 3/12/2012 4:00 AM
Black Drape
Score: 100
Last Login: 5/17/2013
Status: offline
Shane55
I have had the same problem with my Corsair. My lhs has both cars and helis, but none of the balls are the same size. I had to order new gear. They are only about $25 bucks a set, but it still is a pia.
Ron
Hide Signatures
       Post #: 2460
RE: Hits and Misses of H-9 Corsair - 3/12/2012 12:05 PM
shane55
Score: 100
Status: offline
The balls are actually a fairly standard size, 3/16 inch or 4.75mm diameter. The threaded shank is standard as well 4-40 or m3. The length would have to be spot on though so that the leg rotates the correct amount. I've been looking online and seen loads of parts that look right but  they dont have all the dimensions listed. Only hope is to try emailing the websites to see if they will actually take measurements for me. I know that the retracts are fairly cheap but do these ball studs fail regularly? If they do It makes sense to source a replacement
Hide Signatures
(in reply to Black Drape)
       Post #: 2461
RE: Hits and Misses of H-9 Corsair - 3/12/2012 1:40 PM
Dangaras
Score: 255
Status: offline
They are a weak point and I also lost one. The guys at my LHS have a goid stock of parts, nuts, bots, screws, ball links, etc and got me a replacement in all of 30 seconds.
Hide Signatures
       Post #: 2462
RE: Hits and Misses of H-9 Corsair - 3/12/2012 3:11 PM
shane55
Score: 100
Status: offline
Do you remember the brand,part no.etc ?
Hide Signatures
       Post #: 2463
RE: Hits and Misses of H-9 Corsair - 3/15/2012 12:25 PM
shane55
Score: 100
Status: offline
I Think Ive Found a part that will work:    https://www.quickuk.eu/products/420/webshop_categories/general_parts/control_balls___links/control_ball_-_8mm_long_hp-036.html
The distance from the mounting face surface to the ball centre is 9mm on the failed part, while on this part the distance is 8mm. The threaded part on this is 6mm long however while the failed part  thread is 3.5mm long. 1.5mm could be filed from the end of the thread of this replacement. Then when the part is tightened in the collet, 1mm of the thread would be above the surface of the collet, making up the 1mm difference in the distance between the ball centres and mounting face. The ball is the required diameter 3/16"
Hide Signatures
       Post #: 2464
RE: Hits and Misses of H-9 Corsair - 4/6/2012 5:35 AM
Avaiojet
Score: 111
Last Login: 5/21/2013
Status: offline
Well, I tried to sell it many times in a few Threads throwing hints, but there were no takers.
So, I feel like the last rose of the summer, because I'm really late in comming into this Thread.
I decided to keep my H9 Corsair. In fact I started the conversion to chande it into a F2G-2 or F2G-1.
Certainly I'll remove all the covering to glass and paint the model, but currently I'm working on the scale rudder.
I've drawn outline plans and have to decide on an engine choice.
Probably gas because I want to swing a large prop. I'm thinking the 26cc.
I'll probably have questions about much of this. I did look over about 30 pages of this Thread.
Here's my efforts so far. I still have other pieces to make for the rudder, but I started drawing the parts for the stab and elevator.
Charles
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Avaiojet -- 4/7/2012 8:21 AM >
Charles, owner, CFC Graphics, Vinyl graphics "Model Airplane Graphics from a Model Airplane Builder." 58 years of modeling.
Hide Signatures
       Post #: 2465
RE: Hits and Misses of H-9 Corsair - 4/11/2012 11:42 PM
Avaiojet
Score: 111
Status: offline
Anyone interested in the H9 Corsair to the F2G Corsair #57, can see this Thread at this RCU link.
http://www.rcuniverse.com/forum/m_1671250/anchors_11037152/mpage_11/key_/anchor/tm.htm#11037152
Hope there's interest!!
Charles
Hide Signatures
(in reply to Avaiojet)
       Post #: 2466
RE: Hits and Misses of H-9 Corsair - 4/23/2012 7:33 PM
w1nd6urfa
Score: 100
Status: offline
Finally got round to building mine, going for a scale project with custom paint job, TF cockpit, Lado retracts and Robart scale wheels.
Click for fullsize
Click for fullsize
A designer knows he has achieved perfection when there is nothing left to take away (Antoine de Saint-Exupery)
Hide Signatures
       Post #: 2467
RE: Hits and Misses of H-9 Corsair - 4/23/2012 7:40 PM
w1nd6urfa
Score: 100
Status: offline
Question:
I got the TF Corsair decals which are the right size, and include a lot of "miscellaneous" markings which I am not sure where to place (see pics)
Any ideas?
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to w1nd6urfa)
       Post #: 2468
RE: Hits and Misses of H-9 Corsair - 4/30/2012 2:46 AM
m3_express
Score: 100
Status: offline
Nice. I was going to go with tri-color scheme as well but ended up trying something a little different... I'm using the same TF cowl and canopy.
hk
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 2469
RE: Hits and Misses of H-9 Corsair - 4/30/2012 2:53 PM
w1nd6urfa
Score: 100
Status: offline
Very nice!
I like the 3-blade prop, what motor-prop combination are you using?
Hide Signatures
(in reply to m3_express)
       Post #: 2470
RE: Hits and Misses of H-9 Corsair - 5/1/2012 6:11 AM
m3_express
Score: 100
Status: offline
I currently have one of those new turnigy SK3 320kv motors. The prop is a vario prop setup as a 15x14. I'm running it on a 6S setup.
hk
Hide Signatures
       Post #: 2471
RE: Hits and Misses of H-9 Corsair - 5/1/2012 12:37 PM
Dangaras
Score: 255
Status: offline
15*14, wow. Thats some nice pull, she looks nice with the Royal Navy roundels.
Hide Signatures
       Post #: 2472
RE: Hits and Misses of H-9 Corsair - 5/11/2012 1:50 PM
w1nd6urfa
Score: 100
Status: offline
I'm almost done and getting ready for maiden this weekend, se here's a brief build log:
I reinforced the retract / wheel bay area by inserting a U-shaped wire behind the retract mount
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 2473
RE: Hits and Misses of H-9 Corsair - 5/11/2012 1:56 PM
Dangaras
Score: 255
Status: offline
What's the U shaped wire for?
Hide Signatures
       Post #: 2474
RE: Hits and Misses of H-9 Corsair - 5/11/2012 1:57 PM
w1nd6urfa
Score: 100
Status: offline
I used the Top Flite Corsair 60 decal set which suits the tri-color paint scheme
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 2475
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.717RCU1
