meierm01 -> RE: Hangar 9 60 size corsair arf (12/2/2003 4:46:10 PM)
More on the retracts - I quickly built the wing to test the retracts, and I'm not happy with them. I posted earlier that there is a small set screw at the front of the retract base that you can adjust to reduce the front to back 'slop'. When you adjust the screw to eliminate all slop, the retracts hardly deploy and lock. So, I was forced to live with a bit of slop - no biggie I guess, but with rotating gear flying off of grass, I would be happiest without any gear movement. Now, with the gear deployed, I did some 'tug' tests with the wheels on to see how much (if any) the gear would allow the wheels to move. The results - even when the gear was 'locked' it was really easy for the wheels to 'twist', due to the plastic ball links that control the rotation. And, on many occasions I was able to pull the gear right out of lock. Not good, especially if flying from grass! I'm not really disappointed or surprised, however. I had anticipated fitting some other gear onto this bird from the get go, as I had built a number of other ARFs with plastic mechanical gear and always replaced them with 'beefier' models. So, I have a set of Century Jet retracts coming today. From the dimensions, they should fit with only slight modifications to the mounting blocks (adding to the existing, or raising the existing). Both the stock H9s and the CJs are 90 degree rotating, and have similar sized mounting plates (although the CJs plate seems to be slightly smaller, which is fine). I'll post more info when I am able to test fit the CJ retracts. Other than that, the rest of the model looks great! The cowl on my kit is flawless and looks great, so anyone with problems should definitely call Horizon.
