RE: <span class=
Tower Hobbies
Logged in as Guest
  Printable Version
More Resources on the
F4U Corsair ARF - 60
  • 1 Active Classified Ad(s)
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> RC Airplanes >> ARF or RTF >> RE: <span class=
    Page: <<   < prev  3 4 [5] 6 7 8 9 10 11 12   next >   >>
    Login
    RE: <span class= - 12/6/2003 6:21:45 PM
    HotelSierra
    Status: offline
    Anybody far enough on their corsair to know what size engine will balance the plane on C.G.? I have built two other corsairs in the past and they both turned out tail heavy and needed quite a bit of nose weight. I know that Hangar 9 is recommending a Saito 100, but I have a feeling that it might not be heavy enough?
    (in reply to Richard L.)
           Post #: 101
    RE: <span class= - 12/7/2003 12:37:32 AM
    LDJL
    Status: offline
    Thanks for the advise.....
           Post #: 102
    RE: <span class= - 12/7/2003 3:52:54 AM
    tophat
    Status: offline
    I think they want you to add the tape for added protection in addition to the opoxy.
    I used Robart 650 robostrut's and they fit quite well.
    I fly off pavment and have had exelent luck with my H-9 P 51 with robostrut's #653 offset's mounted to the wire cut just before the bend in the coil and I feel I'm going to have good luck with these.
    almost done with mine just starting the cowel,canopy then balance and wait for weather.
    P.S if you can I think it would be better to bend the wire for the Rudder before the vertical stab as it is dificult to do after(install the wire guide 1st).
    < Message edited by tophat776@msn.com -- 12/7/2003 4:55:04 AM >
    (in reply to LDJL)
           Post #: 103
    h9 corsair - 12/7/2003 2:21:10 PM
    cstevec
    Status: offline
    Tophat is correct the tape is in addition. Rough field re-enforcement. My expirience with hanger 9 planes is that they will balance correctly with the recommended engines and CG will have to be adjusted with any thing else.
    (in reply to tophat)
           Post #: 104
    RE: h9 corsair - 12/7/2003 4:13:42 PM
    LDJL
    Status: offline
    I will use silicone and small screws for the wheel wells. (Flying off grass). Also, when the vert. stab is installed it should be done with the tail wheel link already inserted into the fuse. This way you can guide the vert. stab. into place by using the tail wheel link through the guide when you are ready to epoxy. If not, the link may not line up with the guide after you epoxy the vert. stab in place. H9 needs to correct the sequence as it can cause problems.
    (in reply to cstevec)
           Post #: 105
    RE: Corsair - 12/7/2003 5:32:25 PM
    JEanes
    Status: offline
    I looked at one of these yesterday at the LHS,,,,,,,feels REAL lite,,,,,what do you guys think about a Magnum .61 2-stroke for this plane ? Keeping it lite will help the retracts on a grass field. I am not looking for blazing speed or tons of verticle perfomance. The .61 is in the power range for this plane.
    _____________________________
    " People have more fun than anybody" !
    (in reply to LDM)
           Post #: 106
    RE: Corsair - 12/7/2003 11:37:56 PM
    PigMan Buggerus
    Status: offline
    OK so Somebody has to be putting there's together by now, besides the retracts, which may or may not be useable(I myself am going to try the stock gear), are there any other concerns, complaints, or what not? Let's hear the story!
    sorry for being pushy,
    Allan
    The Voice of the Angry!
    http://www.voxirati.com
    (in reply to JEanes)
           Post #: 107
    RE: Corsair - 12/8/2003 12:02:14 AM
    LDJL
    Status: offline
    So far, other than the post I put on this morning, it seems to be straight forward. However, I am pretty much done with the fuse and will start on the hinges next so others that are ahead of me may have run into some concerns........ anyone have anything?
    (in reply to PigMan Buggerus)
           Post #: 108
    RE: Corsair - 12/8/2003 12:24:47 AM
    PigMan Buggerus
    Status: offline
    thanks for the update!
    (in reply to LDJL)
           Post #: 109
    RE: Corsair - 12/8/2003 12:46:34 AM
    DrDeath
    Status: offline
    Hey Piggy,
    The looks and building of this model is pretty straight forward. Except for that !@#$@#($*&(&!@# way the rudder is setup . Someone else here has the right idea. Yes, it will change the way the model looks from up top, but if you want scale, build it yourself. I should have run a straight rod from the main fuse to the rudder coming out of the fuse somewhere. The 90 degree bend is a bear to do after it has been inserted into the rod. The angle isn't very easy. This is probably the only part of this model that I don't care for. So far every thing else has come together like clock work.
    Lee
           Post #: 110
    RE: Corsair - 12/8/2003 9:43:36 PM
    tophat
    Status: offline
    Finished just waiting for wheather now.
    Everthing went good exept for the rudder wire was a pain.Balanced without adding weight put everything were the manual indicated and used the saito 100.
    Cant wait!
    Randy
    Click to see fullsize image.
    Click for fullsize
    Click for fullsize
    Click for fullsize
           Post #: 111
    RE: Corsair - 12/8/2003 9:47:29 PM
    PigMan Buggerus
    Status: offline
    That is a beautiful plane! What pilot did you use, and where did you get it?
    Allan
           Post #: 112
    RE: Corsair - 12/8/2003 10:28:33 PM
    tophat
    Status: offline
    Standard 2" 1/6 scale Williams bro's pilot from hobbytown, Ft Collins CO.
    Only paid $226.00 for the ARF there and thats tax included.We dont have a local hobby shop hear so I have to drive the 45 mi or order online.Our altitude hear is 6,400 ft but they fly nice.
    Never flown at lower Elevation.
    < Message edited by tophat -- 12/9/2003 12:58:19 AM >
           Post #: 113
    RE: Corsair - 12/8/2003 10:47:05 PM
    tophat
    Status: offline
    Here are a couple of pic's i found on this plane.
    Click for fullsize
    Click for fullsize
    Click for fullsize
           Post #: 114
    RE: Corsair - 12/9/2003 12:14:20 AM
    PigMan Buggerus
    Status: offline
    Only $126?
