Richard L.
Joined: 7/28/2002 From: Redmond, WA, USA Status: offline
I just provided Century Jet with a detailed diagram showing all necessary measurements for a set of rotating air retracts. According to CJ, the struts will be slightly longer than the ones for the Top Flite Corsair. I also requested that the air nipple closest to the retract housing be located directly on top of the air cylinder so it won't run into the rear of the gear mounting box. There is about 3/4" of clearance between the top of the wing and the top of the air cylinder. If you are planning on switching to CJ retracts, then you might want to wait for this set, which will be special made for the H9 Corsair.
_____________________________
http://www.WarbirdObsession.com/ Tamiya Panther, Tamiya King Tiger(3), Tamiya Tiger I, HL Tiger(3), HL Panzer III(2), HL Panther, HL Pershing, HL Bulldog, WSN T-34/85, HE Leopard 2A5
